Question about Sony DSR-11 DV / Mini DV VCR
DSR 11 MONITORING AUDIO ON SEPERATE PLAYBACK SCREEN
I need to more settle an argument with a Mr know it Mohamed Sheik in our office.
I live in Durban South Africa.
He is claiming there is a setting in the dsr 11 recorder that allows you to see the audio levels superimposed on the screen whilst recording is taking place.
I told him this is not true as the dsr 11 is not like the dsr 45 which gives you this function.
Plse settle this argument for me as we have almost boxed over the issue today and I will pick up a bad reputation if he is correct.
regards
Andreas Mathios
A greek with some values
  • mathios Dec 02, 2008
    Thanks guys
  • 4,234 Answers
The DSR 11 does NOT have the capability to display audio levels on the screen.
Dan
Posted on Dec 02, 2008
  • 51 Answers
You are correct
you can display data codes only on this unit
the manual can be found here
http://www.sony.ca/dvcam/manuals/DSR-11.pdf
I HAVE AN HP VS15 FLAT SCREEN PANEL BUT I NEED TO KNOW WHAT CORD I NEED IN ORDER TO HEAR OUT OF THE SPEAKER. PLEASE HELP
You need a audio cable with mini-stereo phone plug at both ends, see the picture.
You can get it at Radio Shack or Office depot.
http://www.officedepot.com/a/products/247878/Cables-To-Go-Stereo-Audio-Cable/?cm_mmc=Mercent-_-Google-_-Networking_and_Cables-_-247878&mr:trackingCode=356F0179-71F3-DF11-887D-0019B9C043EB&mr:referralID=NA
One end goes into the Green jack on the monitor, the other end goes into the green jack aduio line out on the PC.
Please leave rating if it helps.
Jan 21, 2011 | HP vs15 15"LCD Flat Panel Monitor
Skipping Video During Playback
Most likely problem is tape path alignment, although a worn pinch roller can cause this.
Feb 22, 2010 | Sony DSR-11 DV / Mini DV VCR
DSR-11 will not record in DV SP mode.
dear, u need to change the memory cell of ur dsr-11 ,
Jul 29, 2009 | Sony DSR-11 DV / Mini DV VCR
Playback problem DSR 11
if you plug & unplug cable after turning off ,perhaps you can the conector firewire on the vcr inside there are 4 yellow cables if not the conector defect.try to push the cable firewire litle up down side just to make sure
Apr 29, 2009 | Sony DSR-11 DV / Mini DV VCR
When I try to play PAL tapes, there is no picture
You also need a PAL television or monitor to be able to view them. If you don't have a PAL compatible monitor or TV it will not work because the resolution and scanning is very different than an NTSC monitor. Your canon camera is probably designed only for NTSC use if it was sold in North America and can't be used for PAL use.
Jul 31, 2008 | Sony DSR-11 DV / Mini DV VCR
Hissing sound
you can check the monitor audio with earphones if the sound hissing when your recording that means it came from the audio, usually wierd defects cause by bad contact conector.
Jul 12, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
DSR 11 playback problem
Pete, we are having the same problem with 2 dsr-11s.
The fix for us was the "auto repeat" switch on the back of the unit. It was "on" please turn it off.
The other idea was that the tape tension is very sensitive in the units, try exercising the tape (though exorcise might be good too) by fast-forwarding then rewind the tape start to finish. Tape that were tightly wound at the factory can cause this proble as well. Good Luck. Greg VA
Apr 29, 2008 | Sony DSR-11 DV / Mini DV VCR
Microphone
In playback, do you have a volume control for "Input Monitor", or under advanced control for microphone, do you have a box to "monitor"
Jan 04, 2008 | Creative Labs Sound Blaster Live! 5.1...
DSR-11 pixelates on right side of Screen
most likely problem is a misadjusted exit guide post. cleaning would not solve the problem; if you have a service manual and know how to adjust the guide, you can do it yourself. otherwise, it's a job for a technician with the proper test equipment.
Dec 20, 2007 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-11 Will Not Recognize Timecode
I think you may have misconfigured something because the problem is not in your DSR-11 try connecting it to a monitor and you will see the time stamp and picture as proof of what I am saying. The problem I think is that your Mac is not processing the time stamp correctly. Try this link first it helped me: Remember follow the instructions ezactly: http://forums.creativecow.net/readpost/35/856108
Sep 11, 2007 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-11 DV / Mini DV VCR Logo
158 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
