Clarification Thank you for the response. We haven't try yet using ADF. It happens when we copy in glass.
  • 168 Answers
Ok so if the copy is streaking of the glass then it is more than likley the drum you can also try printing a report add functions report settings select a report then ok if the report comers out with streaks you eliminate all optics problems then it is most liklly drum. if the toner is smearing and not fusing to the paper it could be the fuser
Posted on Dec 10, 2008
Officejet 9600: vertical lines (4) in center of page when copying using ADF. No lines when copying from glass. I tried the cleaning procedures on your trouble shooting pages. They did not help. How ca
John:
When using the ADF, the scanner doesn't move. The long rectangular platen glass on the left side of the machine is used, not the large glass. I believe that if you clean the long, thin piece of glass on the left side of the platen, your lines will disappear.
May 21, 2014 | HP Officejet Pro 8600 e-All-in-One -...
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
Copy off glass copy is good. copy from ADF copy is blurry
The problem is either dirty glass for the ADF which you can clean, or the ADF cannot feed the paper you are trying to scan through accurately. Most smaller all in one printers use the same scanner element for both the ADF and flat glass scanning so the fact that glass scanning is fine points to the two problems listed above.
Mar 29, 2011 | Office Equipment & Supplies
I have Brother MFC 7820N when I send a fax the pages been received has a black vertical line in the middle of the page. If you could tell me please what kind of maintenance i have to do to eliminate this...
Most likely the cause is something stuck to your ADF scanner glass but let's do a few tests first.
Make a COPY with your machine using the document feeder. Now make a copy of the same document by laying the document down on the glass. One or both of these copies should have the black line. If they do not then there is nothing wrong with your machine. If the copy made from the Document Feeder has the line but the copy made from the Glass does not then the trouble is with your ADF scanner glass which is quite common. Just look to the left of your large main glass. You should see a thin strip of glass runing front front to rear. This is your ADF scanner glass. On some models this glass is contained inside the ADF feed unit. Just cleaned the glass thoroughly with a soft cloth and some glass cleaner.
Now if by chance you get the same line from both then you may have debris on the scanner mirrors. The scanner unit that travels back and forth under the glass would need to be cleaned if this is the case. The glass would need to be removed and then you can clean the small mirrors in the scanner using cotton tip swabs.
Most likely tho it is just the ADF scanner glass. This is true because this glass has documents traveling over it and sometimes specks of dirt, whiteout or other materials get deposited on it.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 21, 2010 | Brother MFC-7820N Printer
Hp LJ 4345 mfp vertical line down printed copies
Dirt.
Open the ADF, the top of the scanner/copier.
The ADF glass is the thin strip of glass on the left. Damp cloth with windex or any glass cleaner. Scrub the strip of glass.
Dec 04, 2009 | HP LaserJet 2840 Printer
Black copies canon laser class 510 only when using the adf. copies fine from the glass.
Are the copies solid black or black lines ? If there are black lines, try cleaning the **** glass under the ADF ( above the large glass ).
Oct 09, 2009 | Canon LaserCLASS 510 Printer
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
When I use the adf to copy something there are always two lines on one side of the paper (to mark the copy). How can I change the setting for this problem. It does not occur when not using the adf. Thank...
Hi;
If you are only getting the lines when using the ADF , but not when placing the document on the glass then there is some type of debris on the scan glass.
This is a small strip of glass that is independent of the copy glass. This glass should be to the left or right of the copy glass. Just glean this well with alcohol or windex and try copying again from the ADF and see if the problem is gone.
Good Luck
Andrew
Jun 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Every Fax we send has stripes going down it making it hard for the receiver to read our faxes. It doesn't happen when we receive fax, print or make copies.
You say it makes copies without the stripes. Do you use the automatic document feeder (ADF) when you make copies, or open the top and lay the paper on the platen? If you get stripes when using the ADF, the ADF scanner area needs to be cleaned. It's the smaller glass area to the left of the main platen glass. Use a damp cloth and remove any dirt or debris.
Jun 15, 2009 | Canon PIXMA MX310 All-In-One Printer
Black lines across copies
try the drum, replace and make a copy
Aug 18, 2008 | Sharp AL 1631 Copier
50 people viewed this question
k24674
jasbo
jasbo
