Question about Acer Extensa 4620 Notebook
Dear Team, I am not able to add printer because In my laptop print spooler service is not running, when i am tring to start service,then service start then automatically stop
CLick your start button,click on run.
In the run programme type MSCONFIG.
In msconfig click the startup tab and make sure that spools is ticked.
Click services tab and make sure that any spools or printer spools buttons are ticked.
Restart your computer and repeat process to ensure that they are still ticked on start up.
Try this and feel free to email me edward_t_wright@hotmail.co.uk if any problems.
Posted on Dec 02, 2008
PRINT SPOOLER SERVICE IS NOT RUNNING MSG DISPLAY WHILE ADD PRINTER AND COULD NOT COMPLETE THE OPERATON
You need to go into services and turn on Print Spooler.
Start Run Type services.msc Click ok Scroll down to print spooler. Right click the entry Click restart.
Check that its startup type is set to automatic as well Right click the entry for print spooler Click Properties Select Automatic in the Startup type dropdown box. Click apply Click ok.
Aug 09, 2011 | Canon LASER SHOT LBP-2900 Printer
Unable to add printer there is spooler problem
1. Click Start -> Run 2. Type services.msc 3. Services window appears, Scroll down and look for Print Spooler roadfox_3.jpg
4. Click on Print Spooler, Click on the Drop down box set it to Automatic
Jun 04, 2011 | HP DeskJet F380 All-In-One Printer
On command to print with my epson lx-300+, message reads, "No Printer". When searched on fax and printer and double-clicked "Add Printer", a message came out saying, "It can't...
Hi Basti here,
Try this...
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
May 23, 2011 | Epson LX-300 Matrix Printer
I have a Kodak ESP 5, when I go to add a Printer my laptop a HP Pavilion, it tells me Local print spooler service is not running. Were can I find this service.
start->run->services.msc->press enter
u will get a list of services->scroll down and look for printspooler(printer service)
Sep 17, 2010 | Computers & Internet
I am running vista ultimate 32-bit but i often received this error message:".....the local print spooler is not running...." when attempting to install a remote oki B4400 printer. Why is that?
Print spooler is printer service if this service is not running, it might not allow you to add or see any printer drivers
Try enabling print spooler service. Follow the instructions
Click on Start->Search->type "services.msc" hit enter. Service windows will open up, on the right side pane search for "Print Spooler"
-> double click to open service and select start type as "Automatic"
click on apply and click on "Start" botton to start the service.
Now try to install the drivers
Snapshot for more information.
Hope this helps
May 21, 2010 | Computers & Internet
I'm getting the error message whenever I try to select a printer that ''Windows can't open add printer. The local print spooler service is not running. Please restart the spooler or restart the...
If u r using the XP operating system, follow the steps to restart the spooler :
1. Click Start and then click Run and in the run window type services.msc and then press Enter.
2. Locate Print spooler from the Services window which is opened now.
3. Right click on it and select Start.
May 08, 2010 | Office Equipment & Supplies
Print Spooler service not running
Go to Start, Control Panels, Administrative Tools, Services.
Windows 2000: Go to Start, Settings, Control Panel, Administrative Tools, Services.
Right click on the print spooler and select Properties.
Click on Dependencies to view a list of all the system components that the print spooler depends on.
Under Services, go to each of these dependencies and check the properties. In each case, ensure that the Startup type is set to Automatic, and that the Service status is set to Started.
Nov 19, 2008 | HP Compaq nx6310 Notebook
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Resolution:
Pls Rate as Fixya if this helps, Thanks!!
Jun 26, 2008 | Dell A940 All-In-One InkJet Printer
Printers vanished and can't add printer
Your shell extensions have a software conflict. The offending piece of software will have to be determined and removed, or at least stopped, before re-booting the computer. You may be able to repair the problem using the System Restore option.
Oct 10, 2007 | Adobe Acrobat Distiller Server V6 for Win...
Acer Extensa 4620 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
