Question about Rockbox RBX-125W Car Subwoofer
What is the sub box size i should use?? - Rockbox RBX-125W Car Subwoofer
  • matty house Jan 30, 2007
    sorry i should put the size eh? lmao it is a 12" rockbox
    Problem Solver:
  • 9 Answers
That depends on what you are looking for Sealed or ported the formula to figure our Cub foot size is LxWxH \ 1728 This will produce a number such as .823863896928365489236489623984823748923749 .8 is the cubic foot of the box. U might have to see what you want, Bandpass has deeper smoother bass -=to me=- but cant be heard as far away but sounds better in the car. Sealed will hit harder, sound kind of punchy but will be able to be heard down the block by the 15 year old who will pop your trunk lock in a heartbeat.
Posted on Feb 17, 2007
  • Elijah Bell Feb 17, 2007
    O i forgot the Pic
    Wrong one.
2 Earthquake balls 12 subs specs for a vented box
Go to crutch fields website for sub box sizes and wiring it depends if you want vented ported enclosed sub box for your sub as to box sizes.
Oct 12, 2014 | Car Audio & Video
Tip
Box size and airspace for 10 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 10 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be around 26 liters, meaning that you will end up with a box of 11 inches high, x 11 inches wide, x 11 inches deep. <br />Enjoy! <br />
on May 29, 2011 | Car Audio & Video
L7 15 not sounding right.how do I wire the sub in a ported box
It's quite simple, positive from amp to positive of speaker, negative to negative. Make sure it's getting sub frequencies only and not full spectrum signal. Next (if everything checks out so far) see if the box dimensions and ports are correct for your sub. The sub and box combo will have lots of factors when considering tuning of the box and port size. You can find all sorts of info on the website for your sub. Qtas, max excursion etc etc etc. They might even list a few total volume and port dimension sizes for the sub you have and your taste in music. It's quite a science to get it right. More than buying a sub and buying/building a box to get great performance. When you get it right though... music to your ears (and chest)
Feb 20, 2014 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
What puts out more power when subs are ran in series or parrelall
Depends on your amp, ohm rating of your sub, box dimensions and ports or chamber size, size of vehical.
Run the subs in 2 ohm if the subs and the amp can handle the demand. Look for the Qtas of the sub. You'll loose 1/2 of the control to stop the sub if you run it in two ohm. You'll blow the works up if any part of this equation isn't up to the task of a 2 ohm load.
If your budget, space allows, run it in 4 ohms at the max RMS of the lessor (sub and or amp) and add more amps for more subs for more effect. A very well designed box/enclosure with an average component list can make a wonderful sound. It will usually beat a bigger budget sub/amp setup in a generic box. Theres lots of science that goes into a great sound. Dig into it and have fun
Feb 19, 2014 | Kicker CVR10 Car Subwoofer
What size box should i build fro two pioneer 12inch speakers 1200watts each
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches.
Mar 17, 2011 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Need to know airspace required for this sub
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 13 inches x 13 inches x 13 inches
Jun 19, 2010 | Lanzar MAX12D Car Subwoofer
Is it better to have your sub box ported or sealed
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches. 15 inch, the box will be 16 x 16 x 16
Jun 12, 2010 | Car Audio & Video
What type and size of box should i use with this
May 26, 2010 | Phoenix Digital PD-131 Car Subwoofer
What size enclosure is recommended for 2 10" kenwood tornado subs?
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 11 inches x 11 inches x 11 inches
Apr 19, 2010 | Kenwood 2 10 " SUBS SUBWOOFERS 500W POWER...
Box recomendations
It depends on the size of the subs- 8z 10z 12z 15z? whether or not you port the box is up to you- a ported box is generally louder than a sealed box -as you are coupling and tuning the sound from the rear of the driver with the sound generated from the front of the sub- but the box is also generally larger as well.Then aside from your preference of ported/sealed you have to account for the recommendations of the manufacturer as to whether the sub/speakers are meant to be placed in a ported or sealed enclosure. Most 10 inch subs do well in a box that yields .75 cubic feet to1.0 cubic feet.most 12z do well in 1.0 cu feet to 1.5 subic feet and 15z do well in 1.5 to 2.5 cubic feet. I have a set of 15z that require 4.25 cubic feet per sub-so its important to look into the manufacturers recommendations. The easiest box to make would be a sealed enclosure-and the sound quality generally yields a tighter more accurate bass sound along with increased power handling capability- try going to rockford fosgate .com and look into the woofer box wizard its a program that calculates air space for whatever size box you have room for-hope that helps you-good luck
May 11, 2009 | Car Audio & Video
Rockbox RBX-125W Car Subwoofer Logo
136 people viewed this question
Top Rockbox Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Rockbox Car Audio and Video Expert? Answer questions, earn points and help others
