Question about Brother MFC-5440 Printer
Printer keeps restarting itself all the time, and does not print at all
I have a Brother MFC-5440 that worked fine for about 8 months. After that, it suddenly started to just keep restarting itself in all the 3 modes (copy, scan and fax). I unplugged it for couple days and plugged it back in, didn't work. Reinstalled the drivers on the PC, didn't fix it. I would really appreciate it if someone can help me on this one. thanks
  • Pmikig Jan 05, 2009
    Printer restarts itself. Brother lab suggested to replace the main board (obviously...) A new one costs almost the same as fixing it. Any ideas?
  • Mark Jones
    Mark Jones Dec 09, 2015
    Anyone found a solution to this? - I have the exact same problem. Updating the firmware did not solve it.
Try downloading the latest firmware. Ti might sort it out for you.
Posted on Sep 13, 2007
4 Suggested Answers
SOURCE:
diddydaveh
  • 154 Answers
SOURCE: I can't scan on my Brother MFC 5440 CN
Hi, remove the softsware that came with the Brother, and then re-install as per the manufacturers instructions
Posted on Jan 10, 2009
  • 1684 Answers
SOURCE: i get vertical lines on scans and copies when
Check out this page on our web site at:
http://www.ccl-la.com/dirty_scanner.htm This page shows you what to do to get rid of the lines on scans and copies.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 12, 2010
etaf
  • 779 Answers
SOURCE: Brother MFC 5440 CN, Can the color be turned off?
You may be able to select black only from the driver properties
One of the options is to use grey scale
goto printers right click on the printer Properties you may find the option within those settings
NOTE however, each time you switch the printer on it may use the colour as it starts and calibrates
Heres a link to the user manual http://welcome.solutions.brother.com/bsc/public/eu/gb/en/doc/manual_index.html?reg=eu&c=gb&lang=en&prod=mfc5440cn_all&dlid=&flang=English&type2=-1
direct link to the manuals For basic information about the product. http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000240/BH3_UkEngSoft_D.pdf Software User's Guidehttp://welcome.solutions.brother.com/BSC/public/files/dlf/doc000075/BH3FB_UkEngUsr_B.pdf
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Posted on Mar 31, 2010
I have changed all cartridges. Colours work fine, but cannot print black. Help, please!
try to clean the prinhead 2-3 times,if the problem persist you need to change the print head
Feb 24, 2011 | Brother MFC-5440 Printer
Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | Brother MFC-440CN InkJet Printer
Black will not prtint. All the colors print fine on my Brother MFC 465CN. Have already: 1. Changed black ink cartridge 2. Reloaded printer driver Almost seems like some deeper issues where it...
GENERAL PRINTER TROUBLESHOOTING ADVISE:
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. If the printer has a cleaning option either on the printer itself through the menu system or on the computer through the print driver, you can use that afterwards. Some printers will let you re-run the cleaning utility several times. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expects you to have is not installed. Double check that the ink is correct against the manual or written instructions inside the printer. Not every cartridge that fits the printer necessarily works.
Nov 08, 2009 | Brother MFC-465CN InkJet Printer
I have a brother mfc-665cw and it shows "unable to init. 4f" on the screen.
Hi there
Good luck
Nov 04, 2009 | Brother MFC-5440 Printer
'1) Lost' Black print 2) Can no longer scan more than one page
Lost Print solved by repeated cleaning. No solution to the single feed problem yet.
Jun 22, 2009 | Brother MFC-5440CN All-In-One InkJet...
Brother 5440
Make sure the cyan color is pushed down all the way and make sure to run the cleaning and other test prints
Aug 23, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-5440 Print Head
To remove it you pretty much have to take apart the printer, tip up the lid and try and get the scanner cover verticle and then slide to the left it should detach and then undo all the screws you see on the top were the pinter head is, and i would recommend Alcohol Swabs (IsoPropyl Alcohol), Then just reverse the dissassimbay directions
Thanks Mitch
P.S. Don't forget to rate me
P.S.S. If you follow my directions you do so at your own risk, I am not liable for any damages that occur
Aug 21, 2008 | Brother MFC-5440CN All-In-One InkJet...
Balck ink not working
brother mfc-5440 ~ same exact issue on not printing the black AFTER purchase new cartridge (again!) ~ i should have checked here first.... NO MORE BROTHER printers in our future & will tell all our friends, too....
Mar 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Brother MFC-5440 Printer Logo
1,022 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
