Question about Kenmore 80754 Top Load Stacked Washer / Dryer
Kenmore washer drains too fast
Is there any way to slow down the rate at which water is discharged to the drain pipe? I'm on an old septic system and the rate of flow from our machine overwhelms the drain line capacity. I'm hoping there's a setting, or a valve, that I might adjust to cause the washer to drain more slowly. thanks. -- tom
  • Anonymous Nov 03, 2008
    I have the same problem but not on a Kenmore. I've seen a lot of posts on different sites and a lot of people seem to overcomplicate the situation. I have an older house with a 1-1/2" drain tube. Washer pumps nowadays are pumping rates designed for 2" drains. Someone on this site said that constricting the flow might cause problems with the washer pump. I don't know. I was about to try that... I certainly hope not. I guess I could try cleaning the drain first. It has always been borderline and sometimes it overflows and sometimes it doesn't. It's always just a little bit but enough to leak out of the shallow pan and down the wall, what's left of it... :-D
  • 944 Answers
Unfortunately the only way to restrict the flow directly would almost certainly cause the machine to malfunction, as the drain pump and valve system is not designed to deal with significant downstream pressure. The only way I can think of would be to install a small tank (a jerrycan or similar may be ideal) that will take a full load's worth of waste water. Connect the tank to the washer, and ensure there is an air-hole/breather at the top. Fit a pipe low down in the tank through a normal (ball-valve type ideally) tap, and open that tap just enough for the new tank to drain slowly into your drain system. (some camping shop type water cans may already be fitted with a tap that may be suitable). The height of the tank would be the only thing you would have to be careful with, as the bottom drain would have to be above the outlet drain pipe, and the top inlet from the washer would have to be below the maximum level permissible (usually described in the leaflet with the washer, normally only a few inches/centimetres above the top of the washer is the maximum recommended, sometimes just below the top of the washer). Get a plumber to check for blockage in the drain line, as the amount of waste water from one of these machines should rarely be too much for a properly functioning drain unless the pipe from the machine to the main drain is too small or blocked, or the main drain is at least partially blocked. If you wish to go with my first idea, then I am more than happy to supply rough drawings of what would be needed, and I would not expect parts to cost too much - only issue would be if you had the space to put a small tank, and that you would have to ensure the tank was empty each time before starting a new load. An alternative solution would be to lead the waste from your washer into a garden water storage tank, checking first if the detergents you use are harmful to plants or the environment generally (many are not and plants sometimes thrive on this sort of water) - you can then water your plants for free and solve the drain issue. Obviously having some sort of garden is a pre-requisite for this, but it could be a good solution if this is the case. Please check local environmental regulations before discharging anything about which you are unsure, as fines can be quite steep. I believe a plumber should be your first port of call to check the drains.
Posted on Feb 17, 2007
    Problem Solver:
  • 3 Answers
I bought a $2.50 "C" clamp, put on my drain hose and tightened it to the point where the drain could handle the outflow. The idea is to pinch the hose restricting water flow. Works great.
Posted on May 06, 2013
Install an siphon kit on your drain hose
Posted on Oct 06, 2009
Smell of rotten eggs in shower drain
This is likely "sewer gas" and can cause headaches, dizziness, etc. if you remain exposed to it for a prolonged period of time. This originates mostly in the drain openings of fixtures that are seldom used - such as sinks and showers of basements, guest rooms, etc.
When these fixtures do not get used regularly, the relatively small amount of water that is designed to always be present in the "trap" portion of the drain pipe eventually evaporates. This trapped water prevents the the gasses in the sewer / septic system from passing through the trap. Without it, these gasses will rise through the pipes connected to the sewer / septic system and exit into your living space via the drain opening in the floor drain, shower, tub, sink and even toilet if left unused long enough.
It is usually resolved very easily by slowly pouring about a 1/2 gallon of water down the drain. The water now isolates the drain opening from the sewer / septic system and effectively stops odors from escaping. If you find that this is happening regularly (often from floor drains in dry basements) you should slowly pour water 1/2 gallon of water into the drain, and then add 2 to 3 ounces of cooking oil. The oil is lighter than water and will sit on top of the water surface. Oil does not evaporate and blocks the water from evaporating through it. Evaporation of the water in the trap will take place from the sewer / septic side of the trap, but it occurs at a much slower rate.
After filling the traps with water or water & oil, just ventilate and you're done!
Apr 03, 2014 | Maax Breeze: One Piece Round Shower...
Septic vs washout tub?
Waste water from the washer is not pumped out but rather is gravity fed down the drain. You cannot drain the water up higher than the washing machine's drain outlet. You would have to cut into the drain pipe - below the level of your washer's drain outlet - and put in a T that will tie into the drain pipe and allow for some type of connection to be made from your washer's drain hose.
Mar 23, 2014 | Washing Machines
My Kenmore Elite Oasis Ht Top Load washer has a slow drip from the drain pipe. How to stop?
If not during a wash it is standing water.
Remove tube and check for cracks. If so, replace. Does/did the washer "walk"? May have rubbed the discharge tube and caused the leak.
Is the down pipe in a cold external wall? May be condensation from humid air hitting cold.
If the sound is the problem, attach a string to the drain pipe so water drips directly to side of vertical pipe.
Oct 23, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
The drain pipe fills so fast that the water over flows. My last washer never did this
The drain pipe may be partially clogged with lint. The old washer pump may have been a little weaker and didn't fill the pipe so fast.
Maybe someone can use an awger on the drain ptpe ...have to clean down to the J trap at the floor.
Hope this helps
Jun 27, 2011 | Frigidaire ATF6000ES Front Load Washer
The water drains too fast and overflows
Here is a tip that will help you with that problem...
Changing or Upgrading your Old Washing Machine
http://www.fixya.com/support/r4696582-changing_or_upgrading_old_washing_machin
heatman101
May 14, 2010 | Kenmore 23822 Top Load Washer
Water will not drain out of washer
Disconnect the discharge hose from the washer and look for a clog at both ends of the hose. Also, look down where the discharge port is on the washer and clear out the clog there also. If you see no clogs, then make sure your discharge hose is not crimped at such an angle to prevent water from flowing through. Also, make sure your discharge hose is not running on the floor and that it goes vertical straight 4.5 to 5 feet from the floor and then loops directly into the discharge pipe. Give that a shot. Still no water drain? Then the water pump needs to be replaced.
Feb 19, 2010 | Kenmore 80754 Top Load Stacked Washer /...
We live in a mobile home, and whenever i do laundry thos terrible stench like seafood smell shows up in the hall. there is no leak under the trailer, is it something in the pipes that i can pour in the...
In mobile homes you have one drain pipe out. old water in the pipes can make a sludge and after a day or two can smell. My shower drain is open and i can smell the water when my washer drains too. White vinegar helps. Or if you have a septic tank your drain field may be clogged up and backing up into your pipes where they slowly drain.might be time for pumping your septic tank.
Sep 19, 2009 | Washing Machines
Sewer Gass after using Bocsh 300 washer
When you have problems with sewer gas smells around a
fixture, there can be a number of causes.
1. Sewer gas coming back up into the home
a. Blocked vent.
b. No vent.
2. Leaking drains that cause rotting below the floor.
3. Moisture that causes mold buildup.
4. No trap on your sink.
5. One roof vent on septic system.
6. Toilet needs to be reset and calked.
Sewer gas can come back up into your home, when the
trap completely empties after a letting the water out
of a fixture, when the trap dries out, or when it is
sucked out by another fixture flushing. When water
goes into a pipe, it first has to push the air ahead
of it, if there is no place for it to go, it comes up
the trap. This causes a buildup of pressure if there
is no vent.
If there is a vent, the pressure is relieved up to the
roof, carrying with it all of the yucky smells. When
the water runs down the drain, the air behind it has
to be replaced, if its not, the pipes will try to ****
it from some drain...typically the shower drain, but
sometimes the floor drain when its close to a washer.
When vacuum draws air in through the trap on the
laundry tub it also takes the water out of the trap,
leaving an opening where the sewer gasses can come
back up from the septic system .
Think about your pipes as if they are a drinking
straw. When you put a straw into a glass of water,
the water fills the straw. But if you put your thumb
over the end of the straw and pull it out of the
water, the water (or liquid) stays in the straw. This
shows you, air has volume. When you remove your thumb
from the end of the straw, the water flows back into
the glass. This is the principal of a vent.
So if you only have the smell when a fixture is
running, the trap is refilling after the fixture and
blocking the sewer gasses from coming into the home,
but your vent is probably not functioning.
In addition, if you have only one vent up through the
roof on a septic system, you can get sewer gas smells
coming up through your home. As the wind blows
across the roof, it pressurizes the plumbing system.
Since the septic tank is full of water, the wind
cannot go into the septic tank. So it bubbles up through the
traps into the house. Installing a vent on an
opposing roof pitch, helps to relieve the pressure buildup,
since the wind then is only hitting one side of the
roof.
Floor drains are succeptable to this type of pressure.
If your drains are partially clogged it can work
similar to a clogged vent. Since there is no place
for the water to go, it forces the air, which is much
lighter up through traps, bringing sewer gas into the
home.
If your fixture is not set right or is wabbling, the
traps or wax ring that seals it underneith may not be tight.
When this happens, if you empty the fixture, sewer gas
will come under the sink into the room.
Each of these senarios will require a different
solution. The key to solving your problem, is having
the right questions to ask when the plumber comes out
to look at it. The previous information should
provide you with a basis for the questions you need.
Make sure before you call a plumber to check
cleanout covers and pipes to see if they have
openings to the sewer. If you have an opening
without a trap, you will get sewer gasses.
In conclusion, if you don't have a vent inside the
wall which equalizes the air pressure inside the
pipes, if you are on a septic system with only
one roof vent, if the vent is clogged off due to
sludge and soap scum, if you don't have a proper trap
on your sink, or if the drain is clogged, sewer gas can escape
into your home.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Discharging water to fast.
You drain may not be blocked but it could be slow. Get some drain crystals from walmart. Go by package directions.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Non-stop draining at whatever cycle selection
Is your drain pump constantly running? If it isn't, check the standpipe (drain pipe) and make sure you don't have your drain hose shoved down in the pipe too far or the top sealed off. The stand pipe needs an air gap to properly drain, or it can siphon water from the wash tub. Symptom: Washer continually tries to fill or slow fills, but water won't stay in wash tub. Double check your drain line to be sure. It could be a simple fix.
May 16, 2007 | Kenmore 46462 Front Load Washer
Kenmore 80754 Top Load Stacked Washer / Dryer Logo
1,636 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
