Question about Bachmann James The Red Engine Train Set
The cars on my train come uncoupled
My train was running great, then the cars started to uncouple, now I can't get them to stay coupled.
Thomas engine keeps uncoupling.
Check the warranty. If still under, return it. Otherwise find a store that sells small black rubber bands, around 1/2" in diameter. Wrap one around the coupler behind the knuckle. Check to see if the coupler still opens. If it does move the rubber band either forward or backward until the coupler does not open.
Apr 23, 2013 | Lionel (31956) Thomas The Train Set
Thomas the Tank engine coupler not holding on the cars.
I just bought a new lionel o guage remote control track section. My train can run around the oval 3 or 4 times and the uncouple button will cause a coupler to uncouple properly. Then the magnet in the...
sounds like a contact issue clean all connections make sure they fit tightly when a bad connection occures it will cause metal to heat up check both sides of the circuit with an ohm meter
Sep 04, 2012 | Lionel Remote- Control Track with UCS...
How do i remove the fan and pulley on a 1987 ford ranger 2.9 v-6?
The question is: How remove clutch in order to remove fan mounted on its engine-side face.
  • Generally, the clutch drive half shaft must be uncoupled from coolant pump (impeller drive) half shaft using special wrench kit available as loaner from AutoZone (free with $79 approx deposit).
  • Best done after shroud & radiator remove after coolant drained.
  1. Uncouple coolant pump and fan clutch drive shaft(s) as follows:
    1. span across combo-pulley-sheaves-unit mounting bolt heads with large tool kit wrench, and
    2. span inline clutch coupling nut with small tool kit wrench. Then,
    3. turn small wrench (and coupling nut) CW while resisting with large wrench (CCW) to turn coupling nut until disengaged from coolant pump drive shaft.
  2. Remove fan/clutch assembly.
  3. Note direction of mounted fan hub and fan blades orientation to ensure proper re-assembly.
  4. On rear of clutch assy, remove 4 bolts to disengage and remove fan.
  5. Assemble new fan to clutch (or, preferably, new clutch and new fan) using new bolts and washers provided with fan.
  6. Couple fan-clutch assy to coolant pump drive shaft as per opposite of uncoupling step 1, above. (Turn inline nut CCW to tighten...30 ft-lb.
  7. Check that fan can be hand turned...CW.)
  8. Rest shroud over and onto fan.
  9. Replace radiator; remount shroud; reclamp hoses, and refill and air purge cooling system.
Aug 12, 2012 | 1987 Ford Ranger
CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK THRU TRACK POWER - WHAT IS PROPER WAY TO HOOK UP RED AND BLACK WIRES? LIONEL FASTRACK
Track power is not recommended for this uncoupler. Use an aux fixed supply of at least 10 to 13VAC for the supply. You have to move a jumper on the bottom of the track to do this. Then there will be four wires needed. Two for the aux power (hot and common) and the other two which go to the pushbutton switch.
Note: Same goes for Lionel FasTrack Remote switches. Run the switches from a 10 to 12 VAC aux supply. There is a jumper you remove on the bottom of the switch to connect an aux supply.
Apr 27, 2011 | Lionel 12020 Fastrack Remote Uncoupling...
We just got the Hogwarts express and it will not complete 1 loop without derailing or the cars becoming uncoupled.
Well you should probably check the radius of your curves. The Hogwarts Express has a minimum curve of O36 and on a tighter radius curve it will derail. I have found that the Hogwarts train runs better on fasttrack than standard O. You should also make sure the track is flat because if it isn't completely flat it derails. The train isn't designed well so it derails but if you run it slow you shouldn't have a lot of problems.
Dec 27, 2010 | Lionel 7-11020 Harry Potter Hogwarts...
How do you uncouple a fuel filter for a ford focus 2.0l 2005
push the two little clips in either side of the coupling and it will slide back ,
Oct 12, 2010 | 2005 Ford Focus
Laptop keyboard quit
Uncouple and couple back the entire system. If you cant do it yourself, please get it to an expert to do.
Mar 04, 2010 | Computers & Internet
I tow my '98 Dodge Grand Caravan behind my motor home. When I arrive at my destination and uncouple the van, it won't start. I have to wait an hour or so and then it will start. Sometimes after I uncouple...
SYMPTOMS SOUNDS LIKE THE FACTORY SECURITY SYSTEM IS SHUTTING DOWN CHECK WITH DEALER ABOUT THE NEW FLASH FOR THE PCM... POWERTRAIN CONTROL MODULE.....MAIN COMPUTLER
Aug 30, 2009 | 1998 Dodge Grand Caravan
Bachmann James The Red Engine Train Set Logo
37 people viewed this question
Top Bachmann Crafts & Hobbies Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Steve
Steve
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
