Question about Whirlpool GH7145XF Microwave Oven
Microwave builtin fan while not shut off even when the door is closed and the microwave is off
  • Whirlpool Master
  • 9,156 Answers
This is almost certainly a bad upper door switch or a broken switch mount. You can find exploded views for this model at http://tinyurl.com/gv383 The involved parts are on exploded view 5 with reference numbers 10, 11, 12 & 13. We have important safety info, disassembly info, and door switch diagnosis and replacement info at our site which is available via our FixYa listing: http://tinyurl.com/yzjozk
Posted on Jan 30, 2007
SOURCE:
How do I get my emerson microwave to turn off after the timer is finished?
There are a couple of microwave ovens out there where after it has finished cooking, the light and fan continue to run until you open the door. Then the fans shuts off, but the light remains on. When you close the door, then the light shuts off. If the light and fan go back on when you close the door, then you have a bad door switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 20, 2014 | Emerson Microwave Ovens
Roper Microwave fan won't shut off
THE FAN AND MICROWAVE TUBE RUN OFF THE ELECTRONIC TIMER. OPENING THE DOOR SHOULD SHUT IT ALL DOWN AND WHEN YOU CLOSE THE DOOR AGAIN YOU SHOULD NEED TO PRESS THE START BUTTON AGAIN. IF NOT, ITS SOUNDS LIKE AN ELECTRONIC RELAY IS LOCKED CLOSED ON THE TIMER BOARD.
Aug 28, 2007 | Sharp R-1610 Microwave Oven
Fan & Light stays on???
On a few new model microwave ovens, this is a "feature"! It's purpose is to cool the microwave parts down, and to remind you that your food is cooked. Once you open the door, the fan will shut off and stay off when you close the door again. But if not, or if you microwave oven didn't use to do this, then you have a bad door switch.
Sep 08, 2014 | Microwave Ovens
When door is shut some type of internal fan kicks on...
Hello Derrick Baker - Typically no fan should come on without starting the microwave. There is one exception! For an example, if the microwave becomes too hot from something that is cooking on the stove below the microwave, the fan will come on and will cycle off once the bottom of the microwaves cools back down. If the fan is turning on when the door is closed, more than likely, a door switch as failed. At this point, I recommend connecting with a certified technician to move forward accurately to assist with the repairs.
Mar 09, 2013 | Frigidaire FMV157GM Microwave Oven
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
Model jvm1870 when door is closed light does not turn off and automatic fan kicks on even though nothing was selected. Thank you for helping me. Michael
sounds like switch that is triggered when door shuts,is not triggering.check around door opening for switch and push in by hand to see if it is working
Oct 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our r-1491 microwave fan won't shut off, even when
its just the door switches playing up on you,,but is it worth getting it fixed? after all a new microwave onle costs from £50 up today,,
please dont try fixing it yourself unless you realy know what you are doing in there, there is 1000's of volts hiding in there even if its been switched off for days, and them volts will kill you,
have you ever seen a stun gun working???it realy hurts you,,,,,this microwave has the stun guns big brother inside of it,,and it wont stun you,,it will kill you,, is it realy worth that for a fuw bucks?
Oct 24, 2009 | Sharp R-1491 Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Whirlpool GH7145XF Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
