I have an LG HT503PH Cinema system and LG 37inch LCD TV and have two queries as follows :- 1/ Am I able to connect to the cinema system and play music from my Ipod? If so how since just plugging the ipod into the USB Port on the cinema system does not seem to work? 2/ The cinema system is connected to the tv through the tv's HDMI 1 port. When I play a dvd the TV switches to HDMI 2 automatically. I can hear the sound via the cinema system but the TV shows a no signal image. If I change the tv to HDMI 1 (thinking that should sort the problem, after all the HDMI cable is connected to HDMI 1) the dvd stops and I still get a "no signal"? Hope you can help with these. Cheers Andy
  • whiting1tom Dec 11, 2008
    I have bought the 42" LCD screen LG and the same HIFI system and the same problem is happening.
    I will be on the case to LG tomorrow
  • Anonymous Jan 14, 2009
    i also have problem with hdmi switching when press play please help
How do you turn Simplink off?
Posted on Jan 22, 2009
Hi!
I had exactly the same problem. What you have to do is to turn the SIMPLINK off! I know it is ment to work on LG TV with LG DVDplayer, but it looks like it does not!!!
I will call lg service and let you know what I found out.
Apparentely there is a conflict between both controls.
Posted on Dec 31, 2008
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
I hvea 42 plasma tv. I have bought a cinema
Please checked Sound System with your remote menu it should be B/G,D/K,I,M which is not proper.
Dec 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Is it possible to connect an LG 5010 tv to a
Yes, you can connect any home system into the TV by either using a scart or HDMI connector to produce the picture on the TV. The sound will still be present through the cinema system
Nov 22, 2009 | LG 42LC2D 42 in. LCD HDTV
How do i connect my non hdmi xbox 360 to my panasonic scbt205ebk home cinema and panasonic 42v10 plasma so that the sound comes from the home cinema system. i also have sky hd
If you use a component system (1 yellow video wire, 1 red audio wire and 1 white audio wire)
You will have to connect the audio wires to your cinema system and the video directly to your set.
The unfortunate part of this is that when you want to use your system, you will have to change the input of the TV AND the Cinema system.
The same would be true if you wanted to use the DVD connectors (YBPBR). You would connect the video to the TV and the audio to the Panasonic unit.
The system you have is meant more for just playing DVD's and not a total cinema system. This is why there are limited (extremely limited) video inputs. The system is mostly for output of sound and of a the built in DVD video.
Aug 05, 2009 | Panasonic Televison & Video
UNLOKING CODE NEEDED FOR LG HOME CINEMA
You can use the "LG5000 hack" to get it region free.
The procedure is same as in the HT503TH.
"1) Download
http://www.digitalfaq.com/downloads/dvdhackarchive/lg5000.zip
2) Burn the folder 'RMTM0000' to a CD-R making sure that the directories stay in order.
3) Insert the disk to your player, disk will be ejected shortly and menu will appear.
4) Select 0 for all regions and press ENTER and then PAUSE on remote to confirm.
5) You have multiregion theater.
6) Have Fun!"
Jan 15, 2009 | HomeTech HT503 Main / Stereo Speaker
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
LG HT503PH home cinema system - two front speakers work with tv and shy but not back speakers. When I test, all speakers work. Connection used - optical. What am I doing wrong?
Press the VSM button on the remote control until the display shows PL11 MOVIE or PL 11 MUSIC I personally prefer movie, that should give you simulated 5.1 on all speakers It works for me on both my TV and my xbox 360 which are connected.
Oct 20, 2008 | Audio Players & Recorders
Getting audio from LG TV to play through Samsung Home Cinema System
May 20, 2008 | Audio Players & Recorders
TV sound to Cinema system?????????????
Thi is not possible so I exchanged the TV for another one, This TV does not have AUDIO OUT function.
Mar 28, 2008 | Panasonic Audio Players & Recorders
37pf7531 tv
If you have a later Philips home cinema model: HTS3100, 3300, 3500, 3154, 3357, 6510 & others, the sound from the TV will go through the existing scart connection.
Just select TV on the home cinema remote control.
For any other models, use a scart - twin phono lead (red & white), from the TV to one of the inputs into the home cinema.
Scarts 1 & 2 on the TV will have different results. Try both.
Nov 29, 2007 | Philips 37PF7531D/10 37 in. LCD Television
1,270 people viewed this question
 Grubhead
Grubhead
