Question about Dryers
Light not working in Durabrand 8 bottle wine cooler
I took out the light bulb/fuse and it reads ''MX12V3W''
checked a couple of home improvement places but they are not sure if it is a fuse or a bulb
  • Henrym01 Jan 22, 2009
    The light in the front won't come on, and when I took it out people don't know if it is a fuse or a light bulb. I am tired of trying to locate the mystery bulb.
    Welcome Back:
    Visited the website for 2 consecutive days.
Xenon Festoon / 3 Watt / 12 Volt / T3-1/4 / Clear purchased on ebay.
Posted on Jun 07, 2016
That is a bulb. A three watt, 12 volt xenon bulb. Good luck finding one. I have seen them on the web, but you have to buy a box of 100.
Posted on Mar 30, 2009
My Koolatron Wine Cooler, model WC08 will not turn on. Any ideas what I should check first? I checked the outlet. It is fine.
There has to be an internal breaker that went off or fuse. You may have to remove it from the casing to get to it.
Jun 26, 2016 | Koolatron WC08 8-Bottle Countertop Wine...
Edgestar wine cooler blowing fuse on the left side circuit board
If you have replaced the circuit boards it's probably associated with a wiring short circuit or compressor failure. Suggest you get a professional technician to further investigate the fault. In the interim check for a short to the frame of the unit, an internal light or for moisture issues or a condensation issue from water.
Mar 25, 2014 | EdgeStar ES TWR325ESS-32 Bottle Dual Zone...
2000 jeep grand cherokee none of the rear lights work
Check BackUp Module, generally is located in the rear quarter panel (drivers side).
Dec 23, 2012 | 2000 Jeep Grand Cherokee
Interior lights problem on a 2006 Lexus SC430
Only one light inside light works on my Lexus SC430 and I have been told that I have to replace the whole part which is about $700 because it is computerized. Is this true
Aug 10, 2012 | 2006 Lexus Sc 430
Headlights shut down on 1995 dodge ram
There should probably be a relay for them too.
May 09, 2017 | 1995 Dodge Ram 2500
Light bulbs wont work in dash
If all your lite bulbs are out, or don't work as you say in your dash, there is normally only two places this can be. Number one, make sure that your dimmer for your dash did not get accidentally turned off. Meaning a lot of cars and trucks as you know, you can turn down or turn up the brightness of your dash lights by a couple methods. Some have like a dial on there dash area, to turn, or some are on the actual light switch that turns. If this is all on and working good, then the only other place it normally would be is a fuse. And that should me marked as dash lights and in your fuse panel. Check in your operation manual for location of fuse box. Or if you know where this is, then open up and look for a fuse that would say, dash lights or interior lights. I hope this helps. MIke
Oct 14, 2011 | 1994 Isuzu Pickup
Dryers Logo
364 people viewed this question
Top Dryers Experts
