Question about Printronix Line Matrix P5210 Printer
P 5210 problem
Good day !
Have a problem with P 5210. Display shows: "Testing Hardware. Please wait" , printer doesn't work ofcourse .
Thanks.
  • 31 Answers
Have you tried reducing the machine to the basic unit and restarting it (take out any options and just reset the memory sticks). If it restarts, with a minimal configuration (like troubleshooting a PC) then just add things back, one by one until you find the culprit.
Posted on May 29, 2009
While ON the printer, control panel display showing Testing Hardware Please Wait, mean time in logic card for every 10 Seconds CR1 & CR6 LED OFF
you have some loose connections. make sure your connection to the computer is ok, if required change the cables.
Dec 21, 2010 | Printronix P5000 Printer
I just installed a new Kodak ESP 5210 printer. It will not print out documents, it will copy and scan though.
OK, did you install the Easyshare software first before installing the printer? I've experienced technical problems with my Kodak camera when I do not have the Easyshare software installed.
Also, how did you install the Kodak ESP 5210 printer? Did you use the driver from the Kodak.com website, or the CD that came with it?
Good luck on getting the Kodak ESP 5210 printer to work on your computer system.
Dec 18, 2010 | Office Equipment & Supplies
My HP 5610xi is giving me the "Cartridge Error: Refer to the device documention. I've replaced the cartridge with three new ones and still get the error message. I re-loaded the printer drivers. Any...
It is hardware problem show it service center.just try with this thing but i m sure it is hardware problem,
Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 18, 2010 | HP Officejet 6310 All-In-One InkJet...
Printer error has occurred. 5700
This is hardware error and you need to show it service center. Following things you have to do.
Replace one of the following:
- ASF unit
- PE sensor board unit
- Logic board
Thanks.
Have a good day
Dec 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
AGFA Drystar 3000
System software damage, need to reinstall with the backup disk.
Dec 12, 2009 | Office Equipment & Supplies
IBM 6400 Stuck At Testing Hardware
Hello Edward,
Have you tried reseating your memory yet? If so try disconnecting your 10/100 card and turn it on. If this doesn’t work you can also try resetting your defaults.
If none of this works, it might be that you CMX has lost some of its boot configurations and needs to be reflashed or possibly fixed. Depends.
If you have any questions please contact me, we offer free technical support and carry new and used IBM Printers and Parts.
Thanks,
Rory Cardenas
Midrange Repair and Parts
3821 W.127th Place
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 13, 2009 | IBM 6400 Model 010 Matrix Printer
are you running twinax or etherent on this unit?
Jun 09, 2009 | IBM 6400 Model 010 Matrix Printer
Ink system failure hp7160
try resetting the printer.
see if it helps..
or else get it serviced
Apr 27, 2009 | HP Photosmart D7160 InkJet Printer
My printer is not printing
After multiple trys I finaly got it to work by doing the following:
Turned off printer, disconnected network cable and power cable. and reconnecting Network cable, power cord and turning on. This was done about 5 times or more before it worked.
Mar 19, 2009 | Fujitsu Office Equipment & Supplies
Printronix Line Matrix P5210 Printer Logo
239 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
