Question about Nokia 6600
Nokia 6600 wont start up
Hi, my nokia 6600 wont start up, i think its a hardware fault as before it went completly i could only get it to boot up whilst it was on charge, now it wont eve do that. The only signs of life i get out of it is when i plug the charger in the white screen comes on with the blue nokia symbol for a few seconds then its just left with the charging symbol. I just need to get it switched on one more time by any means as im about to get a new phone, unfortunatly all my numbers are saved to the phone and not the sim!!! Is there anyway of taking it apart just to get it to fire up one last time, thanks
Nokia 6600 on off sweetch print is diameg
Posted on Dec 27, 2008
    Brigadier General:
  • 7,752 Answers
It is a software issue on the phone you need to take the phone and have the firmware reflash in the phone to get it up and running again as usual.......any mobile repair shop in your area should be able to do that for you.
Posted on Dec 26, 2008
Total power loss left overnight 2 bars on batt in morning no power wont charge no signs of life tried replacement batt fully charged still dead
it is definetly a hardware problem the charging pin would have got short circuited try to go to nokia care and repair it
Aug 22, 2009 | Nokia N95 Cellular Phone
Mobile fault finding
You need to go to a better service centre and ask to reinstall the firmware, this will fix it
Apr 23, 2008 | Nokia 6600
How to Format your nokia 6600 mobile phone....
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}A. Blank screen phone unable to boot-up. B. Phone is only able to boot-up to “Nokia”screen (may flash “Nokia” 4 times also).
C. Install a program but unable to uninstall it.
D. Unable to delete certain files on C drive. WARNING: Thiswill ERASE EVERYTHING on your phone
If you have any files that are important to you, makebackups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMCmemory card (if possible).
3. Switch-off your 6600 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting”screen displayed
5. After a few minutes, the format will be complete. Your6600 will now be at its original factory settings.Disclaimer: I will not beheld responsible for anything that happens to your phone as a result offollowing my guide. Use this guide at your own discretion and risk.
Feb 12, 2009 | Nokia 6600
NOKIA 6600 wont charge and turn on
hey,
how about check your charger .. maybe there is a problem with your charger... try another nokia charger
Cheers
Aug 28, 2008 | Nokia 6600
APPLICATION CLOSE...
There might be a problem either with the program you are using or with nokia 6600 .if you are using facing problem with program try to reinstall that file,but if you think that your mobile is having problem than you can format your mobile or flash your mobile .When you flash your mobile ,it will become new as you you purchased means factory settings....
A. Blank screen phone unable to boot-up. B. Phone is only able to boot-up to “Nokia” screen (may flash “Nokia” 4 times also).
D. Unable to delete certain files on C drive. WARNING: This will ERASE EVERYTHING on your phone
If you have any files that are important to you, make backups.
2. Backup your contacts list and personal files to MMC memory card (if possible).
-Green dial key,
-Star key (*)
-Three key (3)
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.Disclaimer: I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
If this answers your question please rate this as fixed.
If you need more help just add a comment and I'll be glad to help you further... Thanks
dilipbagdi - johny_inmexico@yahoo.co.in
May 11, 2008 | Nokia 6600
Nokia 6600 Cellular Phone Problem
-Green dial key,
-Star key (*)
-Three key (3)
Low feed backs hurt my ratings and I tried my best to help you with your problem,Show your Appreciation by rating it:
email id-johny_inmexico@yahoo.co.in
May 10, 2008 | Nokia 6600
problem in your software reflash
visit www.ajayanblogspot.com
Mar 21, 2008 | Nokia 6600
Unlock codes for nokia 6600
Hi
You can reformat your unit.. just follow this instructions. just off the fone then, press together the key no. 3 Astiris and phone in.. press in sustained position then turn on the power switch then you can see your fone is starting to refurmat...
To Unlock your Unit...
Jan 07, 2008 | Nokia 6600
Not formatting Nokia 6600 completely.
Hie jack_ridar , Try to charge your battery fully using another mobile or use a fullly recharged battery which is compatible with nokia 6600 and then try to format it again and i hope it will help. All the best. Thipa
Aug 31, 2007 | Nokia 6600
I think my LCD is broken
put you sim card in to the phone and if you here the nokia welcome sound the the problem is in on lcd,if not try to flash your phone. if you have a pin number on sim card after 1 minute type it
May 06, 2007 | Nokia 6600
Nokia 6600 Logo
141 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
