Question about Sony KV-36FS12 36" TV
No remote will work
We got a slightly busted TV, everything works fine after we plugged components in the back that had detached from the motherboard. However, it had no remote with it and we have yet to get one to work. We have used a Sony remote that came with our receiver, and a Philips Universal. Neither did anything. Is the Infared broken, or do we need a specific remote?
    Sergeant:
  • 308 Answers
RMY168 is the remote that should be used with that set Sony Part Number 141838711 should cost about $26. It is unlikely that the remote receiver is bad unless the set was dropped or mishandled, in which case the thin, cheap printed circuit boards Sony has been using lately could be cracked, keeping the remote receiver from working. In that case you'd better have a tech look into it.
Posted on Jan 30, 2007
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
Feb 09, 2016 | Sony Televison & Video
10yr old Sanyo tv working fine then "mute"flashed on screen,tv went mute and wouldn't respond although everything else works normally.Not a flat panel-
try reseting the tv and remote.....unplug tv from the wall plug for 5 mins. then remove batteries from remote.....from left to right at the top of remote hit all the buttons on remote then put batteries back in try that......
Jan 16, 2016 | Sanyo Televison & Video
I have a 32" LCD
Tries tv and cable box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The cable box to reboot and upgraded it software.Than go in to the tv Menu go to Audio Setting go down and do a resetting back to the tv factory setting.By doing these steps u have a great chances to get ur tv audio sound back.Not have the same problems after this than the tv Tuner signal board it is shorted in the audio ICS modjulation sections.Tries websites like Shopjimmy,com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 16, 2011 | Televison & Video
Hello, my samsung s42sdyd04 never shows pictures but the led light turn on as i use the remote but still black screen?
In this case the remote is detected by the TV processor but it fails to act as there are issues in the driver or the processing section..It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Jul 14, 2011 | Televison & Video
Toshiba xv55 tv stand by light on cannot power up using remote or switch on tv
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
Jun 17, 2011 | Toshiba Televison & Video
TV remote sensor starts blinking midway and the TV goes off
Jun 13, 2011 | Televison & Video
Dropped my 32" tv...the table
It sounds like you tv need degaussed and you also could have it setting to close to speakers. Unplug the TV for 30Mins, from the wall and when you plug it back in and turn it o0n the degaussing circuit built inside the TV should fix it.
Mar 31, 2011 | JVC AV-32D305 32" TV
Someone sat on the remote control for my Yamaha rx v557 and I have no tv picture--do have sound. System is set up to Direct TV. I can change channels and hear everything fine, but can't get a TV picture It...
If it was the remote that changed the function then likely the mode has been changed. You probably need to have it changed back to the input you plugged your DirectTv into, such as video1 or component, or cable/sat. etc, etc...
Dec 14, 2009 | Yamaha RX-V557 Receiver
Panasonic Home Theater won' play sound from TV
plug evey thing back how it was befor u unpluged the components to consolidate wall outputs.
May 11, 2008 | Panasonic Home Theater System System
Sony KV-36FS12 36" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
