Vizio tv without manual or remote control. colour and sound diff
Tv came from US to Nigeria. different systems so need to download manual. have got a picture with poor colour and sound
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
Posted on Feb 19, 2008
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
SOURCE: Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
Posted on Sep 07, 2009
SOURCE: Picture but no sound on my Vizio L37 Flat Screen
i have a 50 in vizio and the sound just went out. the picture still works but no sound anyone have any ideas on how much to repair it?
Posted on Oct 11, 2009
ALIENAMERICA
  • 88 Answers
SOURCE: U-verse remote code for a Vizio HDTV
1343 is the closest one I've found that works, it will turn the TV off and on, control the volume, and enables mute. The only other thing it doesn't do is change the video input, I'm still working on finding that. If this helps, please give me some kudos.
Posted on Dec 13, 2009
Need help programing my vizio tv to a blackweb universal remote
You don't program the TV to the remote, you program the remote to the TV
Find the Vizio codes on the paperwork that comes with the remote. There will probably be several codes. You need to try each one. Before programming turn the TV on manually. After put in each code try turning the TV off with the remote. Then try to turn back on and try volume up If OK everything else should work. Occasionally 2 different codes will turn off the TV in the test above. Use the one that allows the most functions to work
FINALLY not every "Blackweb" remote will control every TV You may need to get another one that specifically says it can control Vizio.
Jan 11, 2018 | Vizio Televison & Video
A remote code to connect a sharp ht-cn300 surround system to a vizio remote control
0059,0027.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 23, 2014 | Televison & Video
Directtv control code for Vizio
Your Direct TV manual should list all the mfg. codes for the remote. If you do not have the manual you should be able to read it and/or download it on the Direct TV website.
Jul 04, 2014 | Directv RC32 Remote Control
Vizio sound bar code
034,028,075,018,072. Check these codes. If you wish to get more codes to different other brand remote controls, check this link. Code list and setup proceedings to some popular model remote controls are given in detail.
Feb 26, 2013 | DISH Network IR Remote Control
I want to set my samsung home teather remote to my vizio tv the remote is a ah59-02291a
hi,
Need the model number of the samsung Home home theatre system to give to correct code.
OK
Aug 13, 2011 | Televison & Video
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
I have a vizio t.v. & remote the dogs ate our other remote and now we cannot find the numbers to program our vizio remote to our other components
what componet are u trying to hook it to. We have comcast cable and a universal remote and they keep the codes online for all tvs depending on what you use for tv services you should be ale to search that website for comcast just google comcast remote codes it will show a few diff remote styles and once u choose one it will let you download a manual with instructions and codes for all kinds of devices and options
Feb 16, 2011 | Vizio Televison & Video
I have a Vizio TV and just bought a InVoca 3 voice activated remote control. I did not see any manufacturers codes for my Vizio that I have to enter into my InVoca 3. Can I use my Invoca 3 with my...
For the InVoca 3.0 I used a Goldstar TV code for a Vizio TV.I'm not sure what the 3 digit code was but you can search Goldstar codes on theremote shown in the manual with a 2 digit code 33. You also can train it fromyou remote but I did not try that method. They might have different manualsbecause my manual has more instructions than the online version one.
Aug 17, 2010 | KNG America InVoca 3.0 Remote Control
I bought a sanyo tv hdmi 1080p from california while on vacation and took it to Nigeria where I live. However when connected there was no clear picture no colour and no sound. What could be responsible?...
There are several different television standards in the world.
American TV's will only work correctly in North and South America. Japan and South Korea use a similar system but not identical.
The channel frequencies are different and the channel bandwidths are different.
The color systems are also different - NTSC/ATSC, PAS, SECAM.
Even the sound frequencies are different.
For more info go here:
http://countrycode.org/tv-standards
Jul 07, 2010 | Televison & Video
Direct tv remote to visio tv
I can help you with your Vizio TV & DirecTV remote control.
This is a list of all the Vizio TV control codes for DIrecTV remote controls:
11758, 10864, 10885, 11499, & 11756.
Complete instructions on entering DirecTV remote control codes are here.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Code Search
DirecTV Remote Control Onscreen Setup
May 13, 2010 | Universal Remote Control DIRECTV Universal...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
