Question about Bulova Watch
How to change date on my police watch
My police watch has 3 sep dials for 24 hr time, date and day how do i cahnge
  • senthil_mani Dec 11, 2008
    i want to change the Date to my "POLICE" watch because wrong date display in my watch.
    Master:
  • 416 Answers
Follow this link and find your model to download the instructions
http://www.bulova.com/service/instructions.aspx
Posted on Dec 04, 2008
How do I set a Danbury pocket watch with date display
If it is this pocket watch, then the crown (the bit you turn to wind the watch) has 3 positions. Position 1 is when the crown is pushed in all the way. Position 3 is when the crown is pulled out as far as it will go. In between position 1 and position 3 is a place where the crown will stop, this is position 2.
To set the day of the week, pull the crown out to position 3 to set the time. When you set the time, the bottom dial with also turn to set the hour on the 24 hour clock, if you turn the crown enough to cycle through a whole day the day of the week dial will also turn. Keep turning the crown until the time is set on the proper day of the week.
To set the date, pull the crown out to position 2, and turn it clockwise until the hand on the date dial points to the correct date.
Hope this helps!
Sep 01, 2012 | Watches
Change 12 to 24 hr & date
Hi bobwesley,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Nov 17, 2010 | Timex 1440 Nylon watch
How to set date on it?
Thank you for contacting FixYa.
Pull the crown out to position No. 3, turn clockwise to go to hour and minutes hands; the small dial showing days of the week will move, and the 24-hour dial will also move correspondingly.To set the date, pull the crown out to position No. 2 and turn clockwise until you have set the desired date; push the crown back to position No. 1.
Multifunction watch:Pull the crown out to position No. 3, turn clockwise to go to hour and minutes hands; the small dial showing days of the week will move, and the 24-hour dial will also move correspondingly.To set the date, pull the crown out to position No. 2 and turn clockwise until you have set the desired date; push the crown back to position No. 1.
Aug 25, 2010 | Fossil BQ9177 Wrist Watch
I'm tryng to set the date without changing the day and time. I've tried to just pull the pin out half way but its not working. How do I do this? My watch has three dials on the face - 1)date, 2) day and 3)...
mcdevito75 here, It takes practice, the crown does have 2 positions, slip a fingernail just under the crown and lift to it"s first position this will allow you to change the DATE (number) once you get the correct Date, push tje crown back in, NOW! pull the crown out to set the DAY itself and the time. On some watches the crowns first position allows both the day and date to be changed by turning the crown in it"s first position clock wise and counter clock wise.
Jul 04, 2010 | Bulova Watch
How can I change the date without turning 24 hours ?
mcdevito75 here, Most day / Date or just date watches with a stem (winder) even if they are quartz have a 2 position stem. Smply slip a fingernail under the crown and lift to it"s first position, this should allow you to change the date with haveing to go the 24 hours but remember the date cahnges at 12--1 Midnite, Best bet, change the date to the date before the date you want then go the 24 hours this way the date will change at midnite and not 12 noon.
Jul 02, 2010 | Festina 6503-I Watch for Men
Set 24 hr hand
first click changes the date if you turn one way, but turning thr other way should change the 24 hour hand.
Nov 30, 2009 | Watches
I can't set the day
Hi go to www.invictawatch.com select service (top of page) from drop down menu select instructions, then select instruction manual, scroll down to required page.
Nov 14, 2008 | Invicta Watches
Date setting of Frederique constant
hi
never change week or date when day is on "sun" or "mon" also never change date or week or day when time is between 9 pm and 5 am.
to change day, move time back and forth between 10 pm and 2 am.
moon will change only after 24 hr round (not during quick day change)
hope this helps
eli
Oct 17, 2008 | Watches
Anne Klein chronograph watch
The button advances the numeric day. After the numeric day is advanced one full month, the month dial advances to the next month. I just about got a blister pressing the button enough times to advance the month from January all the way around to December. Then I had to advance the numeric day to the current numeric day. The previous person told you by turning the dial 24 hours you can advance the alphabetic day of the week by one day (Sun, Mon,etc.).
Sep 04, 2008 | Casio G-Shock G7100D-1V Wrist Watch
Bulova Watch Logo
3,520 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
