Question about Yamaha 2500 Watt Industrial Inverter Generator YG2800i
Trouble with idle speed
I have a Yamaha EF1000is Inverter/Generator. I am having trouble with the idle speed when the choke is all the way in. What can be done to adjust this.
  • 169 Answers
Go see my answer to the other copy of this question here.
Posted on Dec 02, 2008
What means the green light
the circuit breaker has not trip and its generating power
Jan 29, 2016 | Yamaha 1000 Watt Inverter Generator...
Does the yamaha EF1000is inverter generator 1kva
it seems to be the standard that the rating or model ??1000 or ??1500 or ??2500 or ??5000 or??5500 or ??6500 is the kv rating of the gen-set regardless of straight or inverter
so if yours is EF1000 it will be 1000 watts or 1 kv
remember that most electric drills are 1000 watt units so a unit this small is mostly good for lights, charging batteries, small compressors for tyres
Jul 04, 2015 | Yamaha Electrical Supplies
How do I replace broken starter rope
I cannot see it obviously. Clear the are from its cover and recoil another rope to the crank winding. Keep in mind to put the crank wheel under its spring tension before attaching the new rope.
Jul 02, 2015 | Yamaha EF1000iS Portable Inverter...
Yamaha EF1000is inverter generator, never tused, won't start
Try searching for a fuel shutoff somewhere near the bottom fuel line exit for the fuel tank on somewhere on the fuel line.
Nov 12, 2017 | Yamaha 1,000 Watt Portable Generator...
1985 maxim x 700 has trouble starting sometimes and wants to idle at 4000 rpm or stalls when adjusted, just rebuilt the carburetor still won't idle correctly
Hi, Dlmninja and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
bike idling high
82 1100i surging bit 4000 rpm
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Jul 21, 2011 | 1985 Yamaha XJ 700 X Maxim
2000 Yamaha YZ 80 poor idling
Hi, Shaundavies6 and the usual suspects are:
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yz 80 2001 model Carburetor tunning Trouble
Life On 2 Wheels
Yamaha YZ80 service manual repair 2001 YZ 80 YZ80LW Download Manuals... $8 cheap
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Oct 24, 2010 | Yamaha Motorcycles
My EF2400iS surges under low loads. Seems to smooth out with larger load. Any suggestions? Throttle motor or control box?
Idle speed screw may need adjusting slightly to increase idle speed. Also Main jet and Idle mixture Screws may also be out of adjustment
Aug 23, 2010 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Yamaha EF1000is, Will no run without choke on
It is starved for fuel. PROBABLY needs to have carbureator cleaned and adjusted OR the fuel filter may be clogged.
Nov 02, 2009 | Yamaha 2500 Watt Industrial Inverter...
I have a Yamaha EF1000is Inverter/Generator. I am having trouble with the idle speed when the choke is all the way in. It chokes itself out. What can be done?
Not sure exactly what you mean but here is what I know:
1 - You shouldn't have to use any choke at all once the engine has started and warmed up, if you have to apply some choke to get the engine to run correctly then you have a carb problem. Clean and service the carb and see if that makes it all better.
2 - The idle speed is set by a small screw on the body of the carb itself, if it's set too low the engine can shut off rather than idle. Make small adjustments until you get it right.
3 - Dirty air cleaners can cause problems with idle
4 - fouled and/or misgapped spark plugs can cause idle problems
Please rank this answer,
Carl
Dec 02, 2008 | Yamaha 2500 Watt Industrial Inverter...
Yamaha 2500 Watt Industrial Inverter Generator YG2800i Logo
611 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Roland W VanLue
Roland W VanLue
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
