Question about Yamaha 2500 Watt Industrial Inverter Generator YG2800i
I have a Yamaha EF1000is Inverter/Generator. I am having trouble with the idle speed when the choke is all the way in. It chokes itself out. What can be done?
  • 1 more comment
  • Anonymous Apr 03, 2009
    have to choke to keep it running after warming up.
  • bliffle Apr 22, 2009
    The EF1000is was running, then sputtered and died. I added gas and tried to restart and the only way it would go is if I used full choke and then it runs poorly and dies anyway after a few seconds.
    I let it sit overnight and it started up immediately but only ran 5 minutes before it died. With full choke I can start it but it soon dies. Then I have to let it sit for several minutes.
    Oil level seems to be OK so I don't think it's the low-oil shutoff.
    I thought maybe it was clogged fuel line but when I cracked the small bleed screw under the carb gas flowed down the transparent tube.
  • Ed Greene
    Ed Greene Dec 06, 2016
    0pen carb and clean out bowl and jets with air or carb cleaner. and change oil. fill till it runs out.
  • 169 Answers
Not sure exactly what you mean but here is what I know:
1 - You shouldn't have to use any choke at all once the engine has started and warmed up, if you have to apply some choke to get the engine to run correctly then you have a carb problem. Clean and service the carb and see if that makes it all better.
2 - The idle speed is set by a small screw on the body of the carb itself, if it's set too low the engine can shut off rather than idle. Make small adjustments until you get it right.
3 - Dirty air cleaners can cause problems with idle
4 - fouled and/or misgapped spark plugs can cause idle problems
Please rank this answer,
Carl
Posted on Dec 02, 2008
Another possibility would be that the muffler is clogged preventing exhaust flow ...
Remember one-cylinder four-stroke technology is basically:
1. **** ; 2. squeeze ; 3. bang ; 4. blow
That last part is just as important as the first three.
Aloha!
Posted on May 17, 2009
2 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: Trouble with idle speed
Go see my answer to the other copy of this question here.
I have a Yamaha ef1000is generator for less than a year. WhenI push in the choke after starting it shuts down
If you have not properly shut down the unit after use you will have likely had fuel remaining in the carburetor. The fuel will have evaporated while the unit was not in use leaving a film behind. This residue will plug and interfere with the fuel passages and metering orifices of the carburetor. If the unit runs with the choke on it is likely the carburetor is dirty. Be running the engine the carburetor will possibly clean itself. Make sure you remove any old fuel from the machine and replace with fresh. Allow the unit to run for an extended length of time attempting to return the choke to the run position. If you are able to return the choke to the run position you are on the way of solving this problem. You may need to run it additional time to completely purge the residue.
Additives are available to clean the carburetor and as a last resort if running with fresh fuel doesn't' return the motor to normal you may try it. For best results after mixing and running with the additives leave the unit overnight which may help to remove the remaining residue.
The shelf life of gas containing ethanol is about 30 days. In the future it is best to run the unit dry leaving ot fuel in the carburetor.
All else fails you will need to have the unit serviced by a small engine service center.
Nov 19, 2015 | Yamaha Electrical Supplies
Why does it surge with choke pushed in?
I guess your air cleaner needs cleaning , take air cleaner off and try it. Its starving on gas, may have water in gas tank and would cause this also or plug fuel filter if it has one..
Nov 12, 2015 | Yamaha Inverter Ef2000is 2000 Watt...
Yamaha 1100 2006 v star engine will not idle
Hi, Anonymous and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
2004 Vstar idle only on full choke problem
2003 Star 1100 Custom won idle without choke aftermarket exhaust
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarOwner%20Manual.pdf
May 29, 2014 | 2006 Yamaha V Star 1100 Classic
What mean underspeed fault in generator GESAN 200KVA
Could be the idle is set too low. Check your manual for location of the choke. The choke lowers and raises the idle speed. You want to engage the choke when starting the motor so it gets a little more mixture, then slowly reduce it. If the choke is stuck or in the wrong position, the idle will be too low. If you can't find the manual, do a search online and download it.
Apr 21, 2014 | Electrical Supplies
Ef 2400 Is Yamaha generator Over Revs
Take it to a dealer, there is a solid state module inside that controls the charging and idle, also a wiring diagrams are available with owners manual, go to Yamaha web site also..
Apr 12, 2017 | Yamaha EF2400iS Portable Generator
Yamaha EF1000is inverter generator, never tused, won't start
Try searching for a fuel shutoff somewhere near the bottom fuel line exit for the fuel tank on somewhere on the fuel line.
Nov 12, 2017 | Yamaha 1,000 Watt Portable Generator...
Generator will start and run with the choke on but stalls when you push the choke off.
Carburetor needs cleaning. You can try adding a gas preservative to the fuel and see if that helps, otherwise start by removing bowl on carburetor and cleaning.
Sep 22, 2010 | Yamaha EF2400iS Portable Generator
Yamaha EF1000is, Will no run without choke on
It is starved for fuel. PROBABLY needs to have carbureator cleaned and adjusted OR the fuel filter may be clogged.
Nov 02, 2009 | Yamaha 2500 Watt Industrial Inverter...
Generator only runs with the Choke all the way out. Stops when pushed in.
Only a suggestion. Sounds like the carberator has trash in it. You need to try to clean out the carb and check out the gas tank to make sure that that there is no trash in the tank. When opening the choke lever that allows another way for the fuel to get to the engine in order for it to run.
Aug 11, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Dec 02, 2008 | Yamaha 2500 Watt Industrial Inverter...
Yamaha 2500 Watt Industrial Inverter Generator YG2800i Logo
1,715 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Roland W VanLue
Roland W VanLue
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
