Question about Canon PIXMA iP6700D InkJet Photo Printer
Foam piece ripped now feeder doesn't work
I had a paper jam, and when I removed the jam a foam piece (long piece that went along where the paper output/ink cartridge area is) ripped and I had to remove it.  Now I can't print because it keeps giving me the error message of "no paper".  Where can I get another foam piece and where exactly do I need to place it?  Thanks for your help in advance!
    New Friend:
  • 57 Answers
It'd be cheaper and easier to get a new printer. Most modern desk jet printers are sold as throw-aways. There are few if any replacement parts for them.
Posted on Dec 02, 2008
How to clear a paper jam in the document feeder
Open the covers and remove the jammed sheet. ALL the pieces have to come out if you rip it while removing it. A little corner of paper left behind can trigger a sensor to show a jam.
Aug 13, 2014 | Office Equipment & Supplies
Canon MP830 had a paper jam that forced a black sponge/foam piece out. Prints ok now. Do I need the sponge/foam piece?
Hi!
You must replace it because the sponge absorbe your waste ink from your cartridge. If you don't replace it, your cartridge will not long last.... thanks
Sep 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error code 5C00 what is this and how do you repair this erroe
This error is shown when there is any kind of foreign material or packing material stuck inside the printer which restricting the printhead to move freely. To resolve this issue, please follow the instructions mentioned below:
1) Confirm that the printer is powered off.
2) Disconnect the power cord from the printer or at the wall outlet or both.
3) Open the paper output tray and then lift up the scanning unit cover until it locks into position.
CAUTION: The orange protective tape may prevent you from opening the paper output tray. If that is the case, please refer to the illustration in step 3 to ensure the white foam piece is removed along with the protective tape. skumar_sreen.gif
4) Pull the orange protective tape (A) and remove the white foam (protective material) (B). skumar_sreen.jpg
5) If the the white foam was not removed along with the orange protective tape, check for it on the right, inside the printer. a) With the printer powered off and unplugged, slide the print head carriage to the left. b) Looking inside the printer from the left, locate the white foam in front of the purge area. Note: It is recommended to use a thin latex glove as there may be ink mist on the white foam or surrounding print area. skumar_sreen_0.jpg
c) Cautiously remove the white foam with your hands. Be careful not to touch any other components in the printer.
6) After removing the packing material, look for and remove any other paper debris or foreign objects from the extreme left and right sides of the carriage area.
7) Close the scanning unit cover.
8) Reconnect the power cord and then power on the printer.
Aug 30, 2011 | Canon MP560 All-In-One InkJet Printer
Something is jammed in the printer feeder and I
I opened up the back and found that a piece of foam protection had bent upward into the moving parts that control the paper feeder. I folded the foam piece back to it's proper place and that fixed the problem.
Jan 24, 2010 | Canon Pixma MP480 All-In-One InkJet...
Paper comes out torn and see loose piece of foam
OK
Remove the ink cartridges and print-head then remove the long skinny piece of foam and wash it and dry it - don't wring it out but press it between sheets of paper towel. You'll see lots of ink come out of it.
Using more paper towel, clean out all the ink you can find inside the printer - there will be lots. Look at the end where the print-head parks and you'll see 2 more sponge pieces. Don't remove them but use plenty of towel to absorb as much ink as you can from them.
Once you think everything is clean look for any loose bits of paper inside and remove them. Then, refit the now dry piece of foam. It's not as hard as it looks as the thing is shaped so that it will only fit in one way. Make sure it is properly seated then refit the print head and the carts and switch on.
I've had this happen twice in the last year on my ip5200 - particularly when using scrap paper.
Dec 31, 2009 | Canon PIXMA™ MP510 All-In-One InkJet...
Printer jams. gray foam released in paper path.
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Try this I found it doing a search on your machine, that foam was called a blotter, and it should work without it, good luck
Dec 19, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Foam fell out of printer now printer jams
There are no foams inside the printer for normal operation. Unless this is the one that was inside it during shipping but you were not able to remove it. In any case if you are not having any problems then you are good to go. dont worry about it.
Aug 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon d660 imageclass copier
Hello himsmyboy!
Sikna says
The ADF separation pad is the cause. To remove it lift the cover fully up then use a knife to get under the black tape tab at the top right of the large white foam pad. Pull the tape and the white foam pad loose but not completely - leave the bottom attached. Now you can see the ADF separation pad from below. Use a small screwdriver or spring hook to remove the spring and you will be able to wiggle the ADF separation pad out. First take a good look at how it fits in so you can put it back! The problem is caused by the small black foam pad under the white rubbery tape on the ADF pad assembly. I carefully removed the tape from the back edge to expose the compressed black foam pad. I then cut a matching size of 1/16" foam I had in my shop which was actually HP 98A doctor blade seal foam and just stuck it on top of the old compressed foam. (other similar foam should also work) Then I replaced the white rubbery tape and rubbed the edge down well. I then reinstalled the restored ADF pad and the spring which holds it. Last I just pressed the large white foam pad back into position - being sure to pull it with a slight tension as I pressed into place. This fixed the ADF feed and it worked like new again...
Sikna out...
Jan 15, 2008 | Ricoh Aficio SP-C210SF Printer
Canon PIXMA  iP6700D InkJet Photo Printer Logo
244 people viewed this question
old marine
old marine
