Question about HP DeskJet 5550 InkJet Printer
Hp deskjet 5552 how to reset?
My printer is flashing the paper feed light and power light. I have gone through the usual routine to clear a paper jam and there is not one. I've also turned it on and off however I am unabe to clear the error and as therefore cannot print. Do you know how I can reset the printer.
Thanks Lucy
  • ciuzza69 Dec 24, 2008
    my printer deskjet 5550 do not print ,when i clik to print eject the paper
  • 495 Answers
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults. Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Posted on Dec 02, 2008
The orange light keeps flashing and it says there is a paper jam but I cleared the paper jam but the orange flashing light will not go off.
1. there is a sensor at the end of the printer which shows paper jam recovery. the sensor of your printer may be jammed. clear the jam and it will work. 2. if not, there may be a small piece of paper near the sensor of your printer. clear it.
Aug 30, 2011 | HP Deskjet 460c InkJet Printer
The orange down arrow light keeps blinking. what's wrong?
This means that either the printer is out of paper or there is a paper jam.
Try to check all feeds for a paper jam. Once the jam is cleared your printer should resume printing again.
Sometimes even a small peice of paper can cause the printer jam
Oct 03, 2009 | HP Deskjet 6980 InkJet Photo Printer
Both paper feed and power lights flash after printing several pag
lean head-eject ink ruler & clean point of contact betwin cartridges and head-ink unit.
Aug 07, 2009 | HP DeskJet 970cxi InkJet Printer
Mis-feeds paper and thinks it has paper jam
the gears of the printer r worn out and they have hanve lost their allignment settings so this problem.either replace the gears.or the other solution.do not insert the paper in the tray ,keep it little bit outside and hold the end of the paper in hand when you will give a printout the printer will make a noise of picking the paper at that time just push the paper inside and then it will print properly.
Dec 10, 2008 | HP Deskjet 2330 InkJet Photo Printer
My printer has gone A-wall
i had the same problem but i finally figured it out
1. open the cover
2. pull the ink cartrage thing to the right while you push the center paper feed button
3. it should move now
Oct 19, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
5,479 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
