My acer aspire 3003wlmi notebook will not power up even when connected via the mains lead. There is an orange light flashing on the battery indicator light
    Novelist:
    Scholar:
  • 70 Answers
Solution: Buy and install a new battery pack.
Reason: The battery pack has a special circuit to keep it from being over-charged and over-heating. This circuit will keep your system from running. The orange light is supposed to tell you that your battery is low and is charging. Your battery is not charging and needs to be replaced anyways. You can remove the battery and try to run it without it but usually there is a circuit that will not allow that either.
Posted on Dec 02, 2008
  • 849 Answers
It means the power adaptor has out of order and bettery gone empty.
Acer aspire 5100
Remove the main battery, it is probably loading the power supply down. If your computer starts up, replace the rechargeable battery.
Apr 14, 2012 | Acer Aspire 5100 (5100-5674) PC Notebook
I HAVE AN 3003WLMi ACER LAPTOP, WITH 256 DDR AND 60 GB HARD DISK , HOW MUCH MORE DDR RAM CAN I EXPAND TO. THANKS
Here is what I found:
You can upgrade your Acer Aspire 3003WLMi upto a maximum of 2.0 GB, with maximum of 1GB per slot in 2 memory slots. The Acer Aspire 3003WLMi takes the PC2700 DDR SDRAM SODIMMs Memory Type.
From: http://www.buycomputermemory.com/memory/AcerAspire3003WLMiMemoryRAM.html
Dec 13, 2010 | Acer 3003WLMi Notebook
Battery Wont Charge on my Acer Aspire One Notebook Orange light flashes when power on button is pressed I have checked that the charger is working fine but notebook won't come on as battery is so flat. I...
Try this:
Drain the static on the computer by removing the battery and the power adapter. then press the power button for 1 minute and release. Then plugged the battery back in and turned on the computer, if the computer won't come on plugged the Adapter back to the computer and try turning it on.
If problem persist it is possible that the battery already busted and you need a replacement.
Hope it would help.
May 10, 2010 | Acer Aspire One PC Notebook
Battery Wont Charge on my Acer Aspire One Notebook, Orange light flashes when power on button is pressed, I have checked that the charger is working fine but notebook won't come on as battery is so flat. I...
Hi there as per your information there is a chance of battery damaged. So i suggest you use your battery in others laotop for confirmation. If your found the same problem then buy a new battery . Thanks & waiting for your feedback.
Mar 17, 2010 | Acer Aspire One PC Notebook
Battery flashes orange when Acer Aspire D250 is off & disconnectd
flashing light is normal..when batt is being charged.....
Dec 07, 2009 | Acer Computers & Internet
I was using mu Acer Aspire 7720G last night while
either plug in the back of the laptop is shot or you need a new hardrive
Nov 05, 2009 | Acer Aspire 7720 Notebook PC
Acer Aspire won't power on with fully charged 9 cell battery!
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Mar 08, 2009 | Acer Aspire One AOA110-1626 Notebook
Acer Aspire One 6 Cell Battery Problem
you got a bad battery. If your old battery works fine, and the new one wont hold a charge, Take it back to the store and get another.
Dec 29, 2008 | Acer Aspire One AOA110-1626 Notebook
Acer aspire 3634 LMi
Do you get any beeping or flashing status lights when you try to start it up?
Nov 15, 2007 | Acer Aspire 3610 Notebook
Flashing Orange Light
the flashing orange light is an indicator to tell you that your wireless adapter is working and has a connection to your router, if you are not wireless, press the button that is flashing and it will dissable your wireless connection,to turn back on press it again.
Aug 04, 2007 | Acer Aspire 3003LCi Notebook
Computers & Internet Logo
124 people viewed this question
David Payne
David Payne
