Hp deskjet 5552 both the paper feed light and power light are flashing. There is no paper jam, I have taken it appart and looked everywhere. I've also turned it off and on. however as yet no luck - Do you know how I can reset it so I can start printing again.
  • lucy357 Dec 02, 2008
    I don't have anything in the print queue - however have now tried to print again and nothing has happened. do you have any other suggestions?
  • 495 Answers
Restart your job from the print job queue and then i think, your problem will be solved.
Posted on Dec 02, 2008
  • Manoj Rout
    Manoj Rout Dec 02, 2008
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    There is a technique known as cold resetting.
    Normal
    0
    false
    false
    false
    font-size:10.0pt;
    To do this, switch off your HP printer and then hold down
    the 'Go' key for around 20 seconds while switching the printer back on again.
My inkjet printer is not feeding paper properly. Pages feed at an angle even if they are square in the tray.
I would check for little bits of paper stuck on the roller. Did you have a paper jam prior to this problem? Using a good flash light, look for, and remove any little pieces that you might find.
Oct 19, 2010 | HP DeskJet 712c InkJet Printer
Paper won't feed yellow light flashes on my hp deskjet f4440. Followed every instruction I could find without improvement...
I had same problem. It ended up being a paper jam altho I could never see anything jammed in the paper paths. Perhaps it was a tiny piece of torn paper that I couldn't see. Anyhow, I fixed it by taking a piece of 8.5x11 cardstock and manually pushing it into the paper feed path in between the rollers. It did not go all the way through so I pushed it in and pulled it back out a few times. Apparently it dislodged whatever was causing the jam and the doggone yellow light finally stopped flashing!!! good luck.
Sep 17, 2010 | HP Office Equipment & Supplies
Both paper feed and power lights flash after printing several pag
lean head-eject ink ruler & clean point of contact betwin cartridges and head-ink unit.
Aug 07, 2009 | HP DeskJet 970cxi InkJet Printer
Hp2200D Won't print - "jam" light comes on - but no jam
Have you cleaned the feed roller? If it's dirty it'll spin but won't pick up any paper. Look at the paper after a "jam." Can you see any black roller marks on it? That's a sure sign of a dirty roller. If you suspect a dirty roller, clean it with a little alcohol on a cloth.
Mar 10, 2009 | HP LaserJet 2200D Printer
HP Business Inkjet 1200 Lights flashing
Check the paper sensor has not come loose. Lift the lid, it is on the right hand side of the rollers with the red and blue wire. Press down lightly to make sure is hasn't come loose.
If not, reset the printer:
While the printer is on, press and hold the configuratuion button and press resume (paper feed) button 3 times.
Wait 20 second and press the power button.
Disconnect the power and wait 20 seconds.
Connect the power and switch the printer on.
Feb 24, 2009 | HP Inkjet 1200dn Printer
Paper jam?
There is most likely some paper jammed inside the printer. You just have to carefully look everywhere you can see to see if there might be a little bit of paper stuck somewhere.
Often blowing gently (and dryly) into the printer will dislodge whatever is stuck.
Jan 13, 2008 | HP DeskJet 3650 InkJet Printer
357 people viewed this question
k24674
