Question about Singer 7466 Mechanical Sewing Machine
Broken needle sewing through Corderoy
I was hemming my cord trousers and everything was going great until I came to the seam edge, when the material was turned over there were 6 layers of fabric and my new machine Singer 7466 would not sew through it. The machine beeped and then the needle broke. After taking the bobbin plate off, I looked for the broken part of the needle but cannot find it. If I continue to use the machine will it damage anything underneath. Also according to the adverts the 7466 is supposed to be able to sew through nine layers of denim. If this is right, then what have I done wrong?
I am not a beginner at sewing I have had over 40 years of experience using various machines but this is the first time I have had this problem, I am hoping you can help me.
Thanks Janet
  • 323 Answers
This machine should be able to sew 9 layers with no real problems but it may be necessary to use a bridge or hump jumper to go over the big hump. Set your stitch length to almost the maximum and sew slowly(one stitch at a time). If it buzzes just turn it off, shorten the stitch length and try again. The above applies if you are using regular thread. If you are using heavy thread, you will need to use a top stitching needle size 18.( It has a larger eye)and adjust your tension as high as it will go to remove the loops on the bottom.
sewman7
Posted on Dec 05, 2008
I cant get my 1034d to sew blind hem stitch
It is not a special stitch, just a three thread overlocked seam with left needle but you do it with the blind hem foot and fold your fabric into a "z" shape, wrong side upwards and raw edge at the bottom to be trimmed by the blade as you seam. The folded edge is run against the "blade" of your blind hem foot to ensure even "bite" of the upper fold by the needle while the loopers form the seam around your raw edge below. Then when you finish and press the z fold open, you obviously want a little as possible of the needle stitch to show on the right side of the hemline. So you need to practice and adjust the position of the blind hem guide to ensure you are getting the needle to stitch just onto the folded edge.
I have only ever done it on knit fabric, as it does show and not very successful on a curved hem edge, straight edge is fine. You only want to catch a minimal amount of the fabric with the needle, lengthen the stitch length to 3 so there is less stitches per inch as it will show on the right side.
There is a tutorial here on youtube http://www.youtube.com/watch?v=aDJbFNZrCUI
Nov 13, 2011 | Brother 1034D Mechanical Sewing Machine
I need to hem a t-shirt but not sure how...ie: type of stitch,length,needle et...do I need to zig zag first then finish off with a stretch stitch ? Thanks
The best way to hem around a garment where the seam is going to receive stretching during wearing is with a stretch twin (double) needle.
Pretty easy, just turn up an even hem of 15mm right around the hem line (I am assuming that the bottom edge is even, if not, trim it up first), and press this hem allowance up, pin if you have a jersey that won't stay flat but many cotton knits are fine and the pressing will be enough.
Then thread up your sewing machine for twin needle sewing, refer to your manual if you have never done this before. You will thread two spools of same colour thread up on top of the machine and bring both threads through all threading points down to your needle, then one through each needle eye. Some machines will have a tension device where you can run each thread on either side of a tension disc, most will have twin spools on top of the machine to hold both spools.
You need a stretch twin needle, Schmetz do these in two sizes,
Stretch Twin
Size:
2.5/75, 4.0/75
Twin needles look like this.
tally_girl_65.jpg I prefer the 2.5mm gap between the needles. Dont try with a regular twin, it must be stretch needle with ball point points. On some computerised machines, you need a twin needle with a blue bridge, on mechanical machines it will have a red bridge (something to do with horizonal hooks I think). But read your manual or look in your accessory box, your machine may have come with a twin needle and if so, make a note of the needle bridgecolour, then buy that one next time.
Now, set the machine for a straight stitch and place the garment right side up, with the folded hem allowance underneath on the sewing machine and align the folded edge on your 10mm marking. Start at a side seam, and stitch SLOWLY around the whole hem line until you get back to the starting point. Stop, cut your threads and press again. Voila done. I never bother to zigzag a knit fabric, just stitch it. Knits don't fray.
Aug 20, 2011 | Sewing Machines
I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
Jun 12, 2011 | Elna Sewing Machines
My singer does'nt do dverlockWhat can I do ?
No sewing machine does a true overlock stitch, that is what sergers are for, they trim and form a stitch on the edge of the fabric using 1 or 2 needles and two loopers. Costs more for an additional machine but the finish is much more like a shop bought item.
tally_girl_14.jpgi
Some sewing machines have an overcasting or interlock stitch which looks like stitch 10 in this picture above. Your machine may have this stitch?
If not, does it have a three step zig zag? It looks like a zig zag but the needle goes into the fabric three times as it forms each leg of the zig zag. This stitch is great for neatening a raw edge and I use this a lot myself. Especially on wovens as it is always faster to seam with this rather than the overcasting stitch where the feed dogs move the fabric forwards, then backwards, then forward to make the stitch.
The sewing machine made overcasting stitch can be used to sew knit fabrics, attach rib around an neck line and neaten raw edges but it is always going to take longer than a serger and there is no trimming function so its never going to look like a shop made overlocked item. However, you can sew knit fabrics with a sewing macine with a bit of patience as long as the machine has some "Forwards/backwards" type stitches as these put elasticity into the seams - if you seam knit with a straight stitch, seams can break when under tension during wear.
And use a twin stretch needle and straight sttich to sew the hems, this looks a bit like a cover stitch and has a bit of give in it too.
Hope this helps you a little. You can find some good sewing general info on www.sewing.about.com or invest in a good sewing book. I refer to my Vogue Sewing Manual and my Singer Sewing Secrets often. Or take a sewing class, its a great way to learn new things, get enthused and have fun.
Apr 08, 2011 | Singer 3116 Simple
When sewing hems and coming across a thick seam, the pressure foot seems to not allow the material to run through, keeping it stalled while the needle continues to pump into the material eventually...
I don't think you can adjust the feed pressure on this machine. I have the same machine and the same problem and my solution is the same as you've already mentioned - raise the foot and move the fabric by hand. I would do it by turning the wheel by hand until the seam is clear of the foot to prevent breaking a needle or sewing my fingers.
Feb 06, 2011 | Brother XL-2610
What are he different feet used for?
The main types of feet are:
1. ZigZag foot. This has a wide gap for the needle to move from side to side and the two pointy ends of the feet curve upwards. This is used for ZigZag and decorative stitches,
2. Straight Stitch foot. This has a small round gap and one side is usually wider than the other. It's used for straight stitching.
3. Rolled-Hem foot. This has a spiral in the middle and is used for rolling and sewing hems neatly.
4. Zipper Foot. This has no gap as the needle goes to one side or the other of the foot. It usually has two attachment points for snapping on to the shank, depending on which side of the zipper you are sewing.
5. Invisble Hem foot. Used for making invisible hems. It's hard to describe how it looks. Mine has extra white plastic parts around it and some kind of screw to make adjustments as to width etc.
6. Buttonhole foot. My buttonhole foot is white and has numbers along one edge. The size of the buttonhole can be altered, using the numbers as a guide.
7. Edging foot. This has a strip of springy metal on the left side and is used to guide the material into the path of the needle in order to sew close to the edge to prevent fraying.
8. Rolling foot. This has rollers and is useful for sewing thicker materials or quilts etc. It is similar, but not as good as a walking foot.
9. You might also have a Teflon ZigZag foot, it's the same as the zigzag foot but made of white plastic. It's used for sewing vinyl and leather materials.
I think that's it, hope this helps!
Nov 16, 2010 | Singer Quantum XL-1000 Computerized Sewing...
Im trying to hem a pair of jeans when i start it jams up im using a number 16 needle ive checked everything twice ive even called the help number and they couldnt help me i just dont understand what the...
If you think its the way the material is being moved, I would check the pressure on the presser foot. On my machine, there a knob with 1,2,3 to adjust, its vertically above the foot on the top of the machine(Check you manual). Sometimes the jeans hem is just too thick on the side seam. I just skip that part, or move the needle through that part by using my hand on the wheel, so the stitsches look ok, but it should do the rest of the hem fine. Try the thinnest part of the hem first; good luck
Sep 14, 2010 | Kenmore 12912
I've just got janome 634d serger, how can i make the bottom of a T-shirt ? Thank you so much
If you want the bottom of the T to look like RTW with the double row of stitching, you cannot do this on a serger.
You can achieve the effect by using a twin needle, two spools of thread, bobbin and a straight stitch.
Make sure the double/twin needle will pass through the presser foot and opening in the needle plate below the presser foot.
Practice on a double layer of a scrap of the T shirt material as the tension may need to be slightly looser than the normal setting.
Apr 05, 2010 | Janome MyLock 634D Mechanical Sewing...
Sewing machine needle breaks when I get to the edges where the fabric is thick and overlaps. The needles don't break anywhere else. Do I just need a bigger needle?
I will stop at the overlap and slowly go through the fabric by turning the wheel manually and carefully handling the fabric with both hands, for example, when hemming bottoms of pants where the seams are
Dec 13, 2009 | Singer Sewing Machines
Coverstitching on White Speedylock serger
Your machine cannot do a cover stitch. Check the Brother website, they make a cover stitch only machine, it works much better than any of the serger/cover stitch combination machines, and it is a lot less money.
Nov 19, 2007 | White Sewing Speedylock 1600 Mechanical...
Singer 7466 Mechanical Sewing Machine Logo
46 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
