Question about Konica Minolta Office Equipment & Supplies
Hi, I have a Konica Minolta magicolour 2300w, and tried to replace imaging drum unit but did not know how because i lost instrition. Please could someone help or forward instrution to my email and i would be very greatfull thanks
  • 837 Answers
Konica minolta 2300w change toner
You will find the step-by-step procedure on the following link, on the page 57 (48)
http://printer.konicaminolta.net/drivers/manuals/2300w/user_es.pdf
If you need anything else, let us know.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 21, 2014 | Office Equipment & Supplies
Konica minolta bizup c550 printing black copy what will i do?
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Aug 15, 2014 | Konica Minolta Bizhub C 353, Bizhub...
My konica minolta 2300dl tells me my drum is low. do I need toner? Where do I go to get toner?
If it tells you the DRUM is low it has nothing to do with toner, it probably meens you need to replace the DRUM unit (aluminium blue/green cylinder in the device) dont forget to reset the timer after replacement
Jan 04, 2011 | Konica Minolta OEM Konica Minolta...
Price of Konica Minolta imaging unit for Bizhub 162
You do not replace the Imaging Unit as a whole on this model. The Imaging Unit is made of of 2 parts. The Drum Unit and Developer Unit. If your "replace imaging unit" indicator is on then typically what happens is your local Konica Minolta or Independant service shop would come out and replace the Developer (aka Starter) in your developer unit and replace the drum unit part of your imaging unit. This must be done in sequence with resetting the counters in the service mode. If not done properly the counters will not reset or the new developer will fail to calibrate properly so copy quality will be poor or you will end up with a COF32 code. That being said, all I can tell you is that a fair price to perform this scheduled maintenance on the 162 is about $350.00. This will vary depending on local labor rates and how much the dealer marks up their parts. My current cost on the drum unit and developer is about $100 so you can use that as a general guideline in case some dealer tries to rip you off.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 20, 2010 | Minolta Konica Imaging Unit for DI350...
My konica minolta 2300 prints purples instead of red i have replaced all toner cartridges so the toner levels are ok
it could be problem in color registration.Try to do color adjustment, but also check the trnsfer belt and drum
Jun 05, 2010 | Minolta magicolor 2300W Laser Printer
Konica Minolta Magicolor 2300W firmware needed
firmware is located on secure web site try having a Konica Minolta tech come out and flash the firmware
Apr 15, 2010 | Minolta magicolor 2300W Laser Printer
Driver
Here is the link to download your driver.
Thanks
Mar 12, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Magicolour 2350
Try updating the drivers for the printer from the manufacturers web site. I doubt the issue is related to the printer itself, otherwise it would fail to print magenta all the time.
Jul 25, 2007 | Minolta magicolor 2350 Laser Printer
119 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
