Question about Dayton G73 Utility Heater
Runs constantly. The thermostat would not turn off the heater. Both wires on the thermostat had the insulation burned off for about three inches on the thermostat end. Thirty minutes after I removed the thermostat I tested it with a continuity meter. It seemed to be OK. The Riveted on terminals are slightly loose.
  • Anonymous Nov 10, 2007
    Hey i was just thinking about buying one of these for my garage. I looked at it and it has hi and lo, but does it have an off position?? i dont want it running constantly, just once or twice a week, thanks kevin (kshaly@netsacpe.net)
  • kshaly Nov 10, 2007
    Hey, i was thinking about getting one of these for my garage, and i looked at the pictures, and it appears to have a Hi and Lo setting, but does it have an "OFF" setting?? I only want to use it once or twice a week, don't want it running constantly?? thanks, kevin
    Novelist:
  • 114 Answers
REMOVE THE T-STAT AND SEPERATE THE WIRES ... TAPE THE WIRES SO THEY DONT TOUCH ANYTHING. TURN THE POWER BACK ON ... IF IT RUNS IT HAS A INTERNAL SHORT. IF I DOPESNT REPLACE THE T-STAT. WITH A NEW ONE ... ALL PARTS ARE AVAILABLE AT W.W. GRAINGERS
Posted on Apr 28, 2007
My electric dryer has no heat.
You probably have a bad thermostat or burned out heating elements. Once in a while the problem is a broken or burned-out wire terminal in the heater circuit. To track down the problem, you'll need to use an ohmmeter or other continuity tester. You can find a circuit diagram inside the control panel; this will identify the wires by color so you know which ones go to the two heater elements and thermostats.
Note: two-terminal dryer thermostats are supposed to be closed (less than 0.1 ohms resistance) when cold and open above the trip point temperature. You can test the trip point by heating the thermostat in an electric skillet with known good dial calibration - just be careful not to burn the insulation on your meter's test leads on the skillet. Three terminal thermostats are rare, but they would have one contact open and one closed to a common terminal; the open/close order reverses at the trip point.
Mar 12, 2011 | Kenmore Dryers
Not getting enough hot water
You posted under Rheem 40 gallon tank-type electric water heater.
You have some hot water so that says specific things:
-Upper element is working.
-Electricity to water heater and circuit breaker are good
-You don't report a leak so TP valve is good
-You are not experiencing overheating event
-ECO reset button is not tripped
-Insulation and covers are in place so thermostat not exposed to cooler temperatures that would cause thermostat to misread temperature and cause overheating.
That leaves 6 suspects listed in order of difficulty:
1) Leaking faucet or broken water line that is running hot water all the time and tank cannot keep up.
2) Thermostats set too low. Turn power OFF, open covers and check each thermostat.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
3) Loose screw, loose wire at upper thermostat, lower thermostat, or lower element. Turn power OFF and tighten screws, and look for signs of high heat and burning, especially on lower element.
4) Upper or lower thermostat. Replace both thermostats for $28 and see if that corrects problem.
Parts available at home center, hardware, or plumbing supply
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) Defective wire between upper and lower sections of tank: If this is the case, and water heater has 2" foam insulation, then tank usually replaced since insulation is too dense to drop another wire. Call for manufacturer for warranty information. Do a full troubleshoot using multimeter.
http://waterheatertimer.org/Water-heater-manufacturers.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
6) Lower element is burned out. Test lower element. Replace lower element. Rheem elements are 4500 Watts and are available at home center, hardware, or plumbing supply
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-element-and-clean-sediment-out-of-electric-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I am only receiving half of the normal amount of hot water.
You have electric water heater.
Electric water heaters are fully repairable by homeowner, excluding hybrid type.
Rheem electric water heaters:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Rheem fury series manuals and models
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Age of Rheem water heater is shown first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements in case you need to buy new generic 4-bolt type 4500 Watt element from hardware store.
A) If your water heater receives very cold incoming water, it may not heat fast enough to keep tank warm.
Add a tempering tank.
http://waterheatertimer.org/Tempering-tank.html
Add insulation over entire water heater except TP valve. Insulate pipes completely.
Read more information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
B) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects:
C) Water heater has some hot water.
This tells us upper element is working.
And that water heater electricity is working.
And that reset button is not tripped.
And that heater is not experiencing run-away overheating event.
That gives us 3 solid suspects.
1) lower element is burned out. Test lower element using inexpensive multi-meter from Home Depot.
Replace element with same wattage shown on label, and clean out sediment:
This will restore water heater to full 99% efficiency.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad. Replace both thermostats for about $25.
If you want to test thermostats and all parts before replacing anything:
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
geno_3245_185.jpgRheem 4500 watt element
Dec 14, 2010 | Rheem Water Heaters
The water want stay hot very long
Age of Rheem
water heater is first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements.
B) If cold outside temperatures are not to blame, your water heater may have a bad thermostat or bad lower element.
C) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
D) Water heater has some hot water.
geno_3245_183.jpgRheem element
Dec 14, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
What to do if water doesn't get hot even though I have increased the thermostat settings... the heater isn't even4 months old and it has done this from day one
Electric water heaters are fully repairable by homeowner.
Reliance is AO Smith company
http://www.aosmith.com/OperatingUnits/Detail.aspx?id=138&ekmensel=c580fa7b_12_0_138_3
http://www.reliancewaterheaters.com/prod/elec.html
Age of Reliance water heater is shown on serial number located on side of tank: first digit is letter. Next two digits are numbers: for example C06 means 2006.
Serial number also shows model number & wattage of elements in case you need new element from hardware store.
B) If cold outside temperatures are not to blame, your water heater may have a bad thermostat or element.
Water heater is 240Volts since you have more than 1 thermostat.
Dec 13, 2010 | Reliance WATER HEATER CO #9-40-DKRT 40GAL...
How much clearance do i need to leave on top of the water heater between the insulation and the chimmney? is the insulation fireproof?
Gas or electric?
1) Electric heater can be completely covered with insulation except TP valve. Set electric heater on insulated surface. Insulate pipes completely right down to tank.
2) Gas heater is different.
No insulation over combustion area, or gas valve, or air inlet or. No insulation on top of tank that will interfere with venting of dangerous combustion products including odorless CO gas. Foam insulation on pipes should stop 10" short of tank top. No insulation within 6" of the 3-4" inch galvanized vent pipe.
Here's photo with gas water heater insulation tips:
http://waterheatertimer.org/images/Insulate-gas-water-heater.jpg
3) Tankless gas. No insulation on box. No pipe insulation within 12". No insulation near vent pipe.
4) How much clearance between heater and chimney?? Not sure what that means. Is that the water heater vent stack? Or where vent stack goes into chimney stack? No insulation on gas flue pipes. Or within 6 inches of 3-4" water heater vent pipes
5) Is insulation fireproof? Everything burns if it's hot enough. If you throw insulation into backyard fire, paper and foil will burn away and insulation kind of falls apart in the heat. Fiberglass insulation cannot be set on fire with a match. Foam pipe insulation will burn.
Dec 02, 2010 | Thermwell Water Heater Blanket
Hot water runs out in 5 minutes it use to last 20minutes
Electric water heater can be repaired by homeowner.
We know 3 things for sure:
- electricity is ok
- upper element is ok
- tank does not have overheating problem
Here are the suspects:
- Burned or loose wire
- Upper thermostat not working
- Lower thermostat not working
- Lower element not working
What to do:
1) Turn off power, open water heater covers and look for signs of burned or loose wire, especially on lower element. Burned wire on lower element says lower element is burned out.
2) Test lower element.
Lower elements burn out when sediment builds up inside tank.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) If wires are ok. And you do not want to test parts, then replace upper and lower thermostat for 25$. If problem persists, replace lower element.
4) If you want to test thermostats and elements before replacing anything:
5) When finished, be sure to put insulation and covers back on tank so thermostats don't receive cool air and misread tank temperature. This will prevent overheating of tank that causes red reset button to trip.
Nov 23, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a Reliance 501 water heater, when I take a shower now I only get about 5 min. of hot water is there something on the heater I have to reset? Thnx Mike
Electric water heater is fully repairable by homeowner.
Following information will tell you how.
1) Background on your heater:
Reliance is AO Smith company.
Age of water heater is shown in serial number. First character is letter. Second 2 characters are numbers, which are year of manufacture. For example 05 is year 2005.
The 501 manual is not shown on Reliance website:
2) Two things known for sure:
- electricity is OK
- upper element is working because there is some hot water.
3) Three things can cause problem you describe:
- Loose wire located from upper thermostat to lower element and thermostat.
- Upper or lower thermostat is bad
- Lower element is burned out
4) How to troubleshoot and repair
- Turn off power, open covers and look for loose and burned wiring, especially on lower element.
- When finished, put back insulation and covers so thermostat not exposed to cooler temperatures.
- Burned wire on lower element is evidence that lower element is burned out.
- If you do not want to follow testing steps below, next step is to replace both upper and lower thermostat for about 25$ and see if problem persists.
- If problem persists, replace lower element.
5) Test lower element, before replacing anything
6) Troubleshoot electric water heater
7) How to replace lower element and clean sediment out of tank:
Nov 17, 2010 | Reliance Water Heater #6-50-DJRT 50GAL...
The red button keeps poping causing the hot water heater to shut off. I have to constantly reset it.
The red reset button or ECO or energy cut off turns off power to electric water heater.
The ECO responds to temperatures in excess of 150 degrees F.
Preliminary work:
You can use thermometer to check water temperature immediately after ECO trips.
Compare water temperature against the thermostat setting.
There are 4 things that can cause ECO to trip:
1) Bad thermostat is sticking and letting element continue heating water, or ECO is reading incorrect temperature.
2) Factory installed insulation and cover missing from tank, and thermostat is exposed to cooler air and misreads tank temperature.
3) Element shorted to ground in center of element. This completes 120V circuit to ground which will cause element to continuously heat the water.
4) Loose wire near ECO causing high-heat electrical event.
Solution:
Check for missing insulation.
Check screw terminals for signs of high heat and burning >> tighten screws.
Replace both thermostats using detailed instructions given on link below.
If the problem continues after replacing thermostats, more troubleshooting is needed:
For more self-help information about your electric water heater:
http://waterheatertimer.org/Do-it-yourself-water-heater-timer.html
For more help, add a comment and I will respond
Nov 04, 2010 | Water Heaters
With fresh batteries, the thermostat works fine, but after two or three days, the thermostat fails to turn on the furnance after the temp drops below the setting. Replace the batteries, and it works for a...
If you have a spare wire (unused) in the thermostat wire sheath you can eliminate the batteries as the power source.
Turn off the power to the furnace.
Open the thermostat and look for terminal "C". If it is not being used,then
look inside the furnace for the thermostat wire terminals. Black or blue are probably not being used. Take one of these wires and strip insulation back 1/2 inch. Connect this wire to the COMMON (C)(-)wires from the low voltage transformer.
Open the thermostat and connect the same wire to the "C" terminal on the thermostat.
Dec 22, 2009 | Honeywell Programmable Thermostat Heater
Dayton G73 Utility Heater Logo
229 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
