Question about Boss BV6000 Car Video Player
DISC ERROR IN BOSS BV6000
Hi
I have purchsed new boss bv6000 audio system. when i m inserting any disc(dvd,vcd,mp3), I m getting DISC Error Message. Can you please expalin how can i solve this issue.
I m in India, Can you please give the authorized service centers in india.
Thanks & Regards
Mohan
2 Suggested Answers
SOURCE: Boss DVD - 2000B
eject the disc that is in the unit first
Posted on Dec 03, 2007
SOURCE: I have recently purchased a
did you get this problem fixed. I'm having the same problem
Posted on Dec 13, 2011
Sony mini hi-fi system MHCVX33 Audio-VCD, i want to change (Track CD to DVD Mp3 format)
Not possible. DVD to MP3 is a transitional change using a software program like that from Wondershare.
Feb 02, 2015 | Sony Audio Players & Recorders
How to repair dvd player v zon says wrong disc
Hi Vzon DVD Player,
Before you fix anything, you need to troubleshoot the problem first to know what needs fixing. Since DVD players can play different kind of media formats like Audio CD, VCD, mp3, etc, please try the following
1. Turn on the DVD player and set the program to DVD. some player needs to be setup due to multiple functionality (can play mp3 on flash drive, etc..)
2. insert different Media CD as mentioned above if your player will play them. (if they play, try to insert the DVD you want to play)
3. Try different DVD disc
4. If all the above don't work, try to clean the laser head using the standard disc cleaner.
5. retry the DVD disc
6. If the player still don't play your DVD, probable issue would be the laser head or the disc motor.
7. Please bring them to you nearest Electronic repair shop for further assessment.
Good luck and thanks!
Aug 20, 2011 | Coby TF-DVD7107 Portable DVD Player
Getting "Bad Disc" message after Loading message...
If you've had it a long time and used it often, could be the lens is dirty or something wore down and it should be trashed since newer players have more features like usb ports.
Oct 17, 2008 | Astar PD-3060 Portable DVD Player
DVD PLAYER 3166 SHOWING NO DISC
I AM HAVING A DVD PLAYER 3166 . MY DVD PLAYS CD /VCD/MP3/JPEG AND USB. BUT WHEN I INSERT A DVD VIDEO IT SHOWS NO DISC ERROR. BUT CD IT ACCPTING.KINDLY HELP ME OTHER WISE TELL ME WHERE SHALL I GET IT REPAIRED . PLEASE GIVE ME THE PHONE NOS OF PHILIPS CUSTOMER CARE THANKS, G.SEKARAN, CHENNAI
Aug 26, 2008 | Televison & Video
Sony DVP-NS315 cant play only Video Disc
If you are using just a "yellow" ended cable for the video, maybe your custom settings are set to use "component"? I have been using this same dvd player for a while with the component video out and it works fine. I hope this helps.
Sep 30, 2007 | Sony DVP-NS315 DVD Player
LG DVP7772 Portable DVD Player with Screen showing disc error
its aged and old, all pordable dvd players stuff up eventually, get a new one.
Jun 14, 2007 | LG DVP7772 Portable DVD Player with Screen
"no disc" message
sounds like you have a problem with the laser.laser has to focus a lot sharper to play dvd thus will play vcd but not dvd.Try cleaning first and if this doesnt work would suspect laser faulty,.
May 29, 2007 | Cyberhome CH-DVD 300 DVD Player
DVD display indicates "no disc"
Try a lens cleaner cd, as when the lens gets misaligned or if it's quite old, it will find it harder to read a DVD as the tracks are much closer together than that of a VCD as they are cd's and their tracks are wider apart and easier to read.
Jan 11, 2007 | Sony Multi-System Mini Hi-Fi system /DVD...
Boss BV6000 Car Video Player Logo
106 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
