Question about Sharp Audio Players & Recorders
I have a sharp dk-a10h ipod docking station with cd player.& i love it as soon as i start listening to it until the bass cuts out after around 5 minutes.Turn it off & back on again,& it great again. But only for 5 minutes.You can still hear the music but without the bass.& it does the same whatever source you listening to.Please help me,It one of the incest ipod docking station's i've seen.When the bass die's, there is a humming noise coming from the stereo's bass speekers.But as i said, As soon as it's switched off & turned back on again, it's fine again.Don't even have to wait when you switch it off.Its,off then on.& it's fine. Help
  • 2 more comments
  • Martin Dean
    Martin Dean Dec 02, 2008
    I knew it was a amp issue. but want to know what will fix it. a new amp or part. expensive or not? worth doing. cause im hoping it is.
  • Martin Dean
    nope.
  • Martin Dean
    I've already taken it to someone to get a answer that doesn't help me. I really do need a answer which will help to get it fixed. guessing isn't really any god to me. please dont take this message the wrong way. but i can feel this machine slipping away by the minute. & its looking like im gonna have to buy a new one. & paying out that extra money is making this tight arse really depressed. which means no one's getting anything from me this year if i have to buy a new machine. & my sisters got loads of kids. so help or they go without. ha
  • Martin Dean
    Thanks yoda, really thanks, im gonna try & get it fixed. All i need to do now is find someone with your expert knowledge
  • 1,800 Answers
Look this problem happend when someone miss around with the configuration plz try to give teh device a soft reset = restore original configurations.
1/press the ON/Stand By to enter the stand by mode
2.Whilst pressing down the SNOOZE/DIMMER button and theE SOUND/DEMO button, press the ON/STAND-BY buttonuntil “CLEAR ALL” appears.
3.Can be operate on main unit only.
plz do rate this post.
Posted on Dec 02, 2008
  • 10,594 Answers
Humming sound shows that DK-A10H has problem with Bass Amp section and when out amp IC got heated, it stops working.
It could be power supply issue or amp IC itself is defective.
  • Sharp Master
  • 19,396 Answers
THAT MEANS THAT ONE OF THE ic IN THE AMP CIRCUITS IS OVERHEATING AND FAILING AFTER 5 MINUTES.
  • Ginko
    Ginko Dec 02, 2008
    Sorry about the capitals.
    I was explaining that if you lose only the sound in the sub, that means that some component is failing.
    If this happens always atfter the same time, five minutes or so, that is because some component (typically an IC) is overheating and failing.
    The problem is probably concerning the amp final session, and the board must be repaired or replaced.
    That will also explain the humming noise, that you typically hear when the amp is failing.
    If the craddle is new get a replacement.
    If it is less than one year old, call the the phone number listed on the owners manual. You should be entitled to a repair or replacement from Sharp.
    Let me know if you need additional help.
  • Ginko
    Ginko Dec 02, 2008
    To fix it we test the board inside, if we find a faulty component, at sight , or using the multimeter. If the unit is worth we get the service manual, and service bulletin and spec sheet to test the AMP and preamp ICs, that is more complicate.
    If you know how to use a multimeter you can start (at your risk) inspecting the board for chipped or bulged components.
    If you do not see anything weird you start testing components from the amp final area of the board, where signal is sent out to speakers.
    Testing ICs is more complicate
No longer recognizes Ipod
Try to update and if that causes other problems then factory reset from settings menu... Post results please.
Dec 30, 2013 | Philips Docking Station
Sony audio docking system ipod PCB spare part
Do you know hqew.net? Know the pcb.hqew.net is the best PCB small batch customization supplier in China?
http://pcb.hqew.net/?s=544849
or
http://www.aliexpress.com/store/233890
Is custom PCB link
Jun 30, 2013 | Sony 100 watts Hi-Fi Audio Stereo Sound...
What staion do i put my car radio on
You need to manually tune your radio on FM to whatever frequency you have chosen on the tune cast.
Feb 28, 2011 | Belkin F8Z209 TuneCast Auto and Dock...
I pod charges, plays, but no sound
Easy, I had this problem too. The reason it isn't playing is because its not in all the way. I was getting very frustrated with this, so I kept trying to push it onto the dock to get it all the way down.
Solution:
1. Play a song on your ipod/iphone so you can hear it through the device.
2. Connect your ipod/iphone to the docking station(Bose) so that you hear the chime(This lets you know its charging).
3. Pick up the docking station and firmly press the ipod/iphone down on the connector.
4. Keep pressing it and wiggling around until you hear the music begin to play through the docking station.
It may take a few tries, but you will get it.
Hope this helped!
~ Jake
Oct 05, 2009 | Bose SoundDock digital music system...
Ipod cuts out when played through speaker system
i have somewhat of a similar problem with my ipod Touch and my JBL docking station alarm clock thingy. It may just be that the ipod is not compatible on some of the levels that the Igroove is. With my docking station, it wont charge my ipod touch itll only play music
Apr 11, 2009 | Apple iPod nano
I can't preset radio stations
this is how i preset my stations, im not sure if you have done this before.
fm can save 20 stations and am can save 12
1] chose your desired station
2] press & hold the play/memory button until P01 pops up and flashes
3] to save the station, press & hold the play/memory button
if you'd like to save another station, then repeat steps 1 & 2,
then press the play/memory button again until P02 pops up,
repeat step 3.
to listen to your preset station, all you have to do is press the play/memory button.
hope this helps
Mar 12, 2009 | Starlite Next Play Clock Radio with iPod...
Hello ! I am shopping for mp3 players! I am comparing ipods with generic mp3 players, it seams to have a problem all the docking station on the market is made for ipod only. Is there any adaptor that will...
There is some docking stations or players for the generic MP3 players but most don't even need them. A lot of them do have speakers attached but you can always get generic stations such as the one that IPOD offers or if you want to save some cash, just get some speakers that will attach to the player. There is a lot of products out there so shop around and even check out your major retailers such as Wal Mart
Jan 11, 2009 | Bose SoundDock digital music system...
Docking station
Hi!
I would suggest that you by-pass any docking stations and connect it directly via usb charger as most ipods do. And also, try to update Itunes and your Ipod Nano software.
Thanks and good luck! =)
Jan 04, 2009 | Apple iPod nano
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
