How to connect a humax foxsat-hd to a panasonic dmr 75eb recorder,to a panasonic th42px60b plasma tv,also will i get better result using component cable instead of scart lead. please can you help thanking you patrick
  • 76 Answers
You plug the humax into the panasonic dvd recorder and then from the outputs of the dvd recorder plug it into the panasonic plasma inputs
Is component video better than RGB? Well, yes and no, RGB provides the widest bandwidth and is the best choice for connecting audio visual devices like a Freeview box, digibox or Sky+ box to your TV, home cinema or home theatre system. DVD is however different, to reduce the amount of storage required DVDs are recorded using component video, it is therefore better to connect a DVD player via a component video cable to your TV, plasma or LCD TV etc.
Thanks if you have any questions please do not hesitate to ask
Posted on Dec 02, 2008
Humax cable and Channel connections
see the connections:God bless you
Jul 16, 2012 | Humax Televison & Video
I have a Panasonic Tx l37S10B tv set, & a PanasonicDVD recorder,DMR-EX768EB. To ensure I receive true HD i have bought a Humax Fox T2 hd Digital receiver. I use these items to receive & record HD...
You didn't fully expain how each device is connected to the others. I don't think you have this set up correctly. Your DVD cannot record in HD so there is no point sending an HD signal to it - it can't process it. This is how I would set it up:
1. Install a 2-way splitter on the input cable
2. Connect output 1 from the splitter to the Humax receiver
3. Connect the Humax receiver to the TV with an HDMI cable
4. Connect output 2 from the splitter to the DVD
5. Connect the DVD to the TV with SCART cable.
This will enable you to watch HDTV via the digital receiver and also provide an input from source (dish/cable) to your DVD player so that you can record.
If you've already set it up this way then it should work. I suspect you've connected the Humax to the DVD and TV and also the DVD to the TV.
Please try this setup and post back if you need further assistance.
Nov 04, 2010 | Panasonic Televison & Video
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
Connection to Bose V30 System
check hdmi setting from ur tv and ur dvd connection
Nov 08, 2009 | Bose Lifestyle V30 Home Theater System -...
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Setting humax foxsat hdr remote to control panasonic tx32lxd60 tv
Had the same problem with my panasonic - it would appear that none of the codes will actually turn the TV off because they need a longer signal to turn off. I eventually found that code 0650 works for mine - input the code as instructed in the manual and then selected OK - holding down the standby button on the humax controller then turns the TV off. Try all the codes and see which gives most control functions. Hope this helps.
Jan 01, 2009 | RCA 3-Device Universal Remote with...
Hd tv
Projection TV's have a very nice picture, but they still do not look as sharp as a plasma, LCD or CRT. It is an HD picture, it is just the problem with projection TV's (depending on just how bad the picture is), it should still look good, but it will not compete with the others types of TV's
Jun 15, 2008 | Panasonic DMR-E85H DVD Recorder
Hook-up and use.
You will be able to do HD video if you use the component video (RGB)jacks. Do not user the composite video (yellow) or S-video these will only give you SD video. The gold plated jacks perform a little better then the plain jacks.
Sep 21, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
229 people viewed this question
Top Televison & Video Experts
