Hi, I have a sony vaio vgn-tx46gp, and the hard drive has died. Are the easy to replace ie me doing it? Thanks
    New Friend:
  • 57 Answers
Usually about 4 screws is all you have to replace.
however, you'll have to fdisk it, or use the install disk that came with your computer.
Posted on Dec 02, 2008
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Replace hard drive on sony VGN-SZ760N laptop
It's not so easy here's a video tutorial...
http://videosift.com/video/Why-I-will-never-buy-a-Sony-laptop-try-to-replace-the-HD?loadcomm=1
If you just need to recover the data use an online data recovery service like http://FreeDataRecovery.us
Sep 07, 2012 | Sony VAIO VGN-SZ750N/C VGN-SZ760N...
How do I replace the hard drive on my sony Vaio VGN-NR120E?
To replace a hard drive, you'll need to backup any data you want to keep, uninstall the old hard drive, install the new hard drive, and then restore the backed up data.
The specific steps necessary to replace a hard drive differ depending on the type of hard drive you're replacing.
Jun 20, 2011 | Sony VAIO VGN-NR120E/S Notebook
How to get to hard drive in Sony VGN-S580P in order to replace with Solid State Drive
Unfortunately Sony doesn't make it easy, its requires quite a bite of work to pull it apart to swap it out. Here is a guide on how to take it apart: http://www.insidemylaptop.com/how-take-apart-sony-vaio-vgn-sz-series-laptop/
May 17, 2011 | Sony VAIO VGN-S580P Notebook
Hi my Sony Vaio VGN-CR23_B not been installed this with the webcam and not find the driver ....
if your camera module is this : VGP-VCC6 Camera Module
then this driver will work for you :
http://download.sony-asia.com.edgesuite.net/vaio/downloads/Original_Drivers/073Q/VGN-CR2/IE/Drivers/Camera.EXE
known models :
VGN-CR25G, VGN-CR26GN, VGN-CR23M, VGN-CR25S, VGN-CR22G, VGN-CR25T, VGN-CR23G, VGN-CR24G, VGN-CR26MN, VGN-CR23S
Feb 28, 2011 | Sony VAIO VGN-CR320ER Notebook
How to remove the hard drive from sony vaio vgn-t370 p
Hi fcorey1.
You may remove or replace the Hard Drive by referring to the Service Manual.
You may download the Service Manual for the VGN-T370P Notebook from the below link:
http://www.eserviceinfo.com/download.php?fileid=28689
Please open the above link to download the Service Manual.
Hope this helps.
Please feel free to contact for further information and assistance.
Sep 05, 2010 | Sony VAIO VGN-T370P/L Notebook
I need to replace the hard drive in a Sony Vaio How to take out and back
Try this manual, it will explain and show everything to you. Look in the index to the left when the file comes up and click on HDD.
http://tim.id.au/laptops/sony/vgn-sz.pdf
Sep 21, 2009 | Sony VAIO VGN-SZ120P/B Notebook
Sony vaio vgn sz 460n Problem
your hard drive has failed as far as i can tell you will need to replace it take it to a sony store for verification
Aug 07, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Sony vaio vgn cr200e drive
Western Digital Scorpio WD5000BEVT Mobile Hard Drive - 500GB, 2.5", looks nice. I haven't seen any larger yet.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4322423&CatId=1277
Jan 16, 2009 | Sony VAIO VGN-CR220E/P Notebook
Replacing Hard Drive in a Sony VAIO SZ330P/B
Turn your Vaio upside down and look for an easy access panel or release lever to remove the hard drive carriage. You will probably need a small Philip's screw driver to remove the carriage, but I don't think you need to remove the keyboard.
Aug 10, 2008 | Sony VAIO VGN-SZ330P/B Notebook
Computers & Internet Logo
David Payne
David Payne
