Question about Logitech Z-5500 Computer Speakers
Problem with right rear speaker outlet
Hello I've got my eye on a second hand set of Z5500 speakers which are going cheap due to a fault described as "right rear speaker outlet is noisy and makes a popping sound sometimes" I understand all of the speakers are fine and the problem is wth the subwwofer. Is this the sort of thing that could prove costly or complicated to repair. Don't want to waste money if the repair is impossible/ impractical. Thanks
  • 624 Answers
These are fairly pricy speakers and I would hesitate before recommending you buy them UNLESS they are dirt cheap, like $40 or less. Odds are good that the issue is related to mechanical wear like defective wiring, a jack, where the cable connects to the speakers or even a worn volume switch. The problem is that if it winds up being a defective amplifier or volume switch then your deal becomes less of one. Replacing a volume switch isn?t too hard but finding a suitable part and installing is will take some time. If that isn?t the problem then you?re left with the built-in amplifier which is not typically repairable by the average home user. Hope that helps.
Posted on Jan 30, 2007
SOURCE:
How to connect speakers logitech z 5500 to the TV Samsung UN32F5500 32-Inch 1080p 60Hz Slim Smart LED
Hello there!
I have seen manuals of both the systems. You have two options to connect Logitech z5500 speakers to Samsung UN32F5500 TV.
1. With Optical Audio Cable.
2. Stereo Ear Phone Connection.
Simply plug in Green earphone cable of Logitech Speakers to Green Audio out Jack described on Page 7 of the TV manual. If you are using stereo EP you may not experience 5.1sound separation. And it is also mentioned that you should not use other two audio cables of the tri-EP-cable provided with Logitech speakers.
Have a nice day!
Mar 12, 2014 | Audio Players & Recorders
No power when plugged in
If it is new take it back or read the manual. If it is second hand, then you may want to check to see if the internal fuse is intact. These power speaker units usually have an internal fuse to back up the one in the mains connector.
Apr 19, 2013 | Pyle PPHP153MU 15 1000W Powered Speaker...
My problem at my z5500 is that the light from the display is not working and also one channel is not working at all is the front left side channel.
im not sure i understand your problem??? however if you are having sound problems
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 17, 2011 | Logitech Z-5500 Computer Speakers
My door speakers wont play but my box does
Hello
Check the speakers first. Then check the wiring. There are Front Right, Front Left, Rear Right, Rear left speakers and supply, antenna, etc are connected by one pin to a socket. Check this pin&socket for rigid connection. Unplug and replug it two or more times, so that if there is any loose contacts with this socket and pin connections will be rectified. If this does not help you, check the internal connection of this socket, This is actually a skilled work, you have to open your player. The fault is surely with this socket and pin connections itself. Work out with concentration. Check the door speakers first before doint anything further. If you fail to detect the fault, let it retified by any auto-electrician. No internal circuit fault to this set is there. OK.
Sep 03, 2011 | Kenwood KDC-519 CD Player
Loud static noise coming front right speaker on home theater system. I've removed all cables and all speaker wires except that one and still get the noise. I've tried plugging the unit into another...
Make certain you have not started some kind of test signal going by looking in the the user manual, if not by all means send it back. Phone or E-Mail the makers helpline first they should sort any problems and confirm you have set it up right.
Jul 04, 2011 | Audio Players & Recorders
Logitech Z5500 5.1 speaker system Hi, Any suggestions on how to troubleshoot this problem? there is no sound coming from the subwoofer or the speakers, but when I connect my mp3 player to the pod...
Try pulling the power from the unit for a few minutes, the reconnect. Make sure you've got the surround settings correct. If that doesn't do it, you've likely popped the amp or the amp's power supply in the sub box.
Jun 16, 2011 | Logitech Z-5500 Computer Speakers
Hi....I need a wiring diagram for the stock amp in my grand am gt...its a 2003
Monsoon System Pinouts
Pin Wire Color Function
E1 LT GRN Right Front Speaker Output (+)
E2 TAN Left Front Speaker Output (+)
E3 GRY Left Front Speaker Output (-)
E4 LT BLU Right Rear Speaker Output (-)
E5 DK BLU Right Rear Speaker Output (+)
E6 BRN Left Rear Speaker Output (+)
E7 YEL Left Rear Speaker Output (-)
E8 BLK Ground
E9 BLK Ground
E10 DK GRN Antenna Relay Coil Supply Voltage
E11 ORN Battery Positive Voltage
E13 BLK Left Front Tweeter Speaker Output (+)
E14 YEL Left Front Tweeter Speaker Output (-)
E15 DK BLU Left Front Midrange Speaker Output (+)
E16 LT BLU Left Front Midrange Speaker Output (-)
F1 DK GRN Right Front Speaker Output (-)
F2 LT GRN Right Front Speaker Tweeter Output (+)
F3 PPL Right Front Speaker Tweeter Output (-)
F4 PPL Left Rear Tweeter Speaker Output (-)
F5 RED Left Rear Tweeter Speaker Output (+)
F6 DK GRN Right Front Midrange Speaker Output (-)
F7 ORN Right Front Midrange Speaker Output (+)
F8 PPL Gain Control Signal
F9 -- Not Used
F10 YEL Right Rear Tweeter Speaker Output (-)
F11 WHT Right Rear Tweeter Speaker Output (+)
F12 -- Not Used
F13 LT BLU/BLK Right Subwoofer Speaker Output (-)
F14 DK GRN Right Subwoofer Speaker Output (+)
F15 DK BLU/WHT Left Subwoofer Speaker Outlet (+)
F16 LT GRN/BLK Left Subwoofer Speaker Outlet (-)
or it is here 3rd one down
http://www.grandamgt.com/forum/forumdisplay.php?f=76
May 08, 2011 | Audio Players & Recorders
Z5500 speakers , can it be opened
Hi , And happy new year , You speakers can be opened , but the second you open them, you will lose your warranty , if thats ok with you , then go ahead and unscrew it and get the nut back...if you dont want too lose your warranty , i suggest you leave it in there..
I hope this helped but , Merry Christmas and happy new Year :)
Dec 23, 2009 | Logitech Z-5500 Computer Speakers
Z5500 : No Vocals Coming in 5.1 Movies
The same thing happened to me and i just had to reset the system by turning it off and then holding input+settings for like 5 seconds until it shows what firmware version you've got it meqans it's reseted and that should solve your problem.
Apr 03, 2009 | Logitech Z-5500 Computer Speakers
Repalcement Logitech Z5500 Control Center?
My Control center turns on but i can get any sound not even from the test system, Logitech cant help.
I went the a shop and check it on ther system still no sound :(
any ideas
Nov 17, 2008 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 Computer Speakers Logo
85 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
