Question about Omega Pacific "Doval" Carabiner
Is it safe to use a 1700 weight limit carabiner as a anchor for r
Is it safe to use a hammer in bolt that i got from the hardware store to use a an anchor bolt
the guy at the hardware told me it was fine
the sizes are 3/8 and 1/2 inch bolts
    Scholar:
  • 63 Answers
I wouldn't do this without checking with a professional climbing place. That's almost a ton! Don't listen to just anyone at a hardware place or you might get injured or killed!
Posted on Dec 04, 2008
Zanussi rear counter weight screw mountings broken
If this is a GE top load washer, I have see it a few time's. You can go to your local hardware store and get 2 new 4 inch bolts and nut set. and reattach the counter weight. The old bolts were just screwed to the frame. With today's appliance's they use 1/32 to 1.16 sheet metal... it don't take much to strip that out.
Next time post brand and model number...make's it easier.
Mar 07, 2014 | Washing Machines
How to I remove anchors- get a toggle bolt out of drywall?
unscrew the bolt until the toggle falls off into the wall cavity. Then just pull out the anchor and spackle over the hole.
A molly bolt is a similar type of wall anchor. It's often confused with a toggle, but a molly's "bendable" legs are part of the anchor and will remain in place when the bolt is removed. Sometimes you can straighten those legs out by unscrewing the bolt partway, then pushing it back into the wall cavity. If you're lucky, you might be able to pull the anchor out through its own hole. If not, you'll have to use a punch and hammer to pound the head just below the drywall surface, then spackle over it.
(http://www.thisoldhouse.com/toh/asktoh/question/0,,1585873,00.html)
May 07, 2013 | Home
UNDO ELEMENT TV STAND
Safely face down on padded surface with no weight on screen---locate up to 4 machine bolts that anchor the base stand to the set and remove.
Nov 06, 2012 | Televison & Video
We have drilled a 3/16"
If you used the correct drill size, the anchors should fit in the hole by softly taping them in with a hammer. Make sure the anchors are inserted before you attach anything to them. When the screw is used with them, they will expand and hold in place.
Aug 09, 2011 | Sterling Plumbing 1500D-31S VISTA PIVOT...
The studs that rest on the tiolet bowl keep breaking - where can I get replacements? In Australia?
if it is the tank they are tank bolts, any hardware store sells them or eBay. if it the toilet where it anchors to the floor then they are flange bolts same as before. Hope this helps Tim
Apr 30, 2011 | Kohler Home
How to stop seat from wobbling doesnt seem to have screws that fo into seat just a place for seat to sit on and then some cap to put over but nothing seems to tighten it.Im tired of falling off the toilet
First lift the covers off where the bolts should be (they should lift towards the tank). Are the bolts in place? If not, go to your neighborhood hardware store and look for replacement hardware. (Most stores will have staff willing to help you find the right parts.) Is the bowl damaged so that the holes seem large compared to the holes in the seat anchor points? Are the seat anchor points damaged?
The bolts should have nuts (and possibly washers, but not all models use them) underneath the bowl. Screw down the bolt while holding the nut from turning (so you need an adjustable wrench or appropriately sized wrench). Again see the local hardware store for the hardware if you do not have the nuts. Keep the seat centered as you tighten the bolts. (Alternate tightening until it is stable - do not tighten one bolt all the way down before doing the other side. You risk overtightening and cracking the bowl.)
I hope this helps.
(if the seat is damaged, you may want to replace it. If the bowl is damaged you must replace that.)
Jun 10, 2010 | Kohler - Toilet Seat - Moondance -...
Need to hang a shelf to a wall with metal studs?
In order to support any true weight (like books) you will need to use wood blocking between the metal studs. Measure space between the studs, cut blocks to fit and mount at location where brackets will be.
For lighter weight applications, you can use an expansion anchor (but not the cheep little plastic ones that are often provided). A common name for this anchor would be a "molly anchor" and they are available at all hardware stores in a variety of capacities.
http://www.lowes.com/lowes/lkn?action=productDetail&productId=230779-37672-376056&lpage=none
Sep 14, 2009 | Measuring Tools & Sensors
How to anchor a Big Max shed
No anchor is necessary. The weight of the shed plus any contents will keep it in place unless you encounter a tornado or hurricane.
May 06, 2009 | Elite Rubbermaid Frameworks Outdoor...
How should I pick my carabiners?
Depending on your style of climbing, you will want different kinds of Carabiners. There are basic types: your oval and D-shapes are your most basic Carabiners. Sometimes you'll want a locking Carabiner, especially for belay, or for anchors. Most Carabiners that you have will probably not be locking Carabiners. There are different types that are easier to clip. There's bent gates, straight gates, wire gates. It depends on your style and if you're weight conscious, or how durable you'd like them to be.
Dec 01, 2008 | Arc'Teryx Theta Ar Bib Women's
Which kind of carbiners shoul I use
The best carabiner shape for any kind of static rigging is a symmetric shape - oval is the best. Most carabiners are asymmetric "D" - which is stronger but will cause the line to shift when loaded - the oval shape is better because nothing will shift to one side of the carabiner when loaded. You could use standard aluminum carabiners or even locking ovals (Petzl and Omega make very nice locking ovals), but I would also suggest using steel carabiners - they are cheaper and stronger and since weight isn't an issue they are better.
Dec 01, 2008 | Black Diamond Equipment Primrose Climbing...
Omega Pacific "Doval" Carabiner Logo
505 people viewed this question
Top Omega Pacific Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
RatanbssBD
Level 1 Expert
Are you an Omega Pacific Rock and Ice Climbing Expert? Answer questions, earn points and help others
