Missing black cup off rear leg
Need to know where in dublin i can get this part. need it to steady the
machine.
    Genius:
  • 1,122 Answers
Go to sears .com click on parts,put in your model number and get your part,you can also go to repair clinic .com to compare prices,mike
Posted on Dec 02, 2008
Missing measuring cup for Bialetti tuttopasta machine
Here are the measurements for basically every pasta maker:
Full Load
Liquid: 2 eggs and water to total 7 oz.
Flour: 3 1/2 cups flour with a small amount of olive oil (1 tsp?)
Half Load
Liquid: 1 egg and water to total 4 oz.
Flour: 1 3/4 cups flour with a small amount of olive oil (1/2 tsp?)
Dec 01, 2013 | Ronco Automatic Popeil Pasta Maker
Machine viabrates badly whether empty or loaded. Machine has been checked for balance.
Did you pull the packing strap from the rear legs it is sometimes a yellow pin. lean unit forward look at rear of machine pin holds the legs up for shipping pull that out.set machine down lean unit forward to balance rear legs should be good to go...If I helped you Please vote need more help just ask Good luck...
Feb 03, 2011 | Maytag PAV2300 Top Load Washer
I have a Keurig B30 and noticed the bottom part of the coffee holder is missing - the piece that pokes the hole in the cup. Can I get a replacement piece?
i think you are talking about the black funnel part, the replacement k cup holder, i know of this great site that sells all kinds of replacement keurig parts i hope this helps http://stores.ilikenew.com/-strse-14/coffecoffee,-tea,-shakes,-diet,/Detail.bok
Oct 10, 2010 | Coffee Makers & Espresso Machines
I need a replacement K cup holder system for the Special Edition Brewing System
Jul 31, 2010 | Keurig B60 Coffee Maker
I need a replacement K-cup holder. Where can I get one???????
Call Keurig's 800 number and tell them you ordered it online and it was missing - they'll send you one for free!
Dec 20, 2009 | Keurig Elite B40 Coffee Maker
Spidem Divina - one cup and 2 cup lights flash together
Hi
Caution light usually means something is out of place. Nothing will work until everything is in place and locked.
Steady water light means it needs to be primed, (run water by opening the steam knob). It won't heat until the boilers are primed.
Jun 19, 2009 | Saeco Spidem Divina Deluxe Fully Automatic...
Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
Jun 24, 2008 | Speed Queen AWS75NW Top Load Washer
Leveling a washer tub how to do so
first get a level. second, some have self leveling rear legs, just lean the machine forward and set down slowly. the rear legs are now level. if you dont have self leveling rear legs, the legs screw in, so just screw them in or out as well as the front legs untl it appears level by eye. now place the level on the washer. check it front to back and side to side. try rocking the machine to see if there is any movement. if there is adjust the legso it stops rocking, all the while keeping an eye on the level
Sep 27, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
