Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
No air gap for dishwasher. Do I need it?
We just moved in and replaced dishwasher because old one had bad pump. Noticed that we are still not getting clean dishes out. I noticed that there is not air gap coming up to the top of my sink. Could that be the problem? Do I really need one?
  • 3 Answers
That is a sink overflow hole that should have nothing to do with your dishwasher or disposal. You wont have that feature any kitchen sink that has to accomodate a disposal at the bottom.
If your machine is cycling properly, it could just be that it is a kitchenaid, like mine, and they just are not as high quality as they used to be.
Posted on Feb 12, 2008
Water is puddeling on the bottom of my 18 yr. old GE dishwasher
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Sep 22, 2009 | EuroTech 24 in. EDW194E Built-in...
Potscrubber 900 Dishwasher won't drain
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Aug 27, 2009 | Dishwashers
Dishwasher won't drain?
HI. check the following areas for fualts.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jul 15, 2009 | General Electric Adora GHDA670N Built-in...
My G E Power1 Dishwasher is holding in alot of water,I know a little is normal.There is a lot and the water it feels slimmy.Just 2 yrs old well takeen care of.HELP
Check the following areas for faults. This is an apparent drainage issue.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
Jun 24, 2009 | GE Dishwashers
SHU9922UC doesn't get rid of water
HI, check the following areas to address this poor draining issue.
2. Broken belt
3. Pump
Jun 19, 2009 | Bosch SHU9922UC Built-in Dishwasher
Dishwasher stops after 10 minutes inlet/drain light flashing
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
GE Nautilius Dishwasher - Water will not drain out after washing
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Apr 23, 2009 | GE Nautilus 24" Built-in Dishwasher
Standing water in dishwasher
Check your "air gap". This is the device that sticks above the countertop and prevents any water backup from getting into your dishwasher. The problem may well be a partially clogged air gap.
Remove the decorative cover and there should be a plastic dome that can be removed. Firmly grip the plastic dome and move from side to side while pulling up. Once you get the dome off you will be able to see if it is clogged. This can be done without removing the drain hose from the bottom of the air gap. This solved my problem which was the dishwasher not completely pumping all the water out. After cleaning the air gap it drains properly.
Mar 12, 2009 | Bosch SHV4803 Dishwasher
Dish washer wont drain
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Feb 02, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
KitchenAid KDS-16 dishwasher, leaking from fill air gap
Peace,
If you want to try it okay .
but i think there are more variables and
you need hands on service tech with experiance!
Sep 06, 2008 | Dishwashers
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
850 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
