Question about Acer Aspire 5520-5908 Notebook
Some times my lap top( aspier 5520)make a sound(peeep)
The heat is not high>nothing strange in its work
Backlight not working on acer travelmate 5520 lap top lap top is working ok but screen is very dark
You can buy the parts to fix these on Ebay. There are two components. 1 is the light source itself. (Very fragile)
The other component is the the power inverter for the light. Both have a history of going bad. They have to be removed to be tested. Probably better to replace both as a set.
Apr 22, 2010 | Acer TravelMate 5520 Notebook
Aspier 5520 reboots constant. can open safe mode.
That you can start in safe mode tells me that your problem is caused by some software/driver you have installed lately or in worse case by a virus. You can start by starting the pc in safe mode and uninstalling what you have installed the last couple of days or if you have the possibility, restore your system to an earlier date! if it doesn't help, you should back your files up then format the hard drive and install Windows from scratch. OBS. you might have the recovery partition on your hard drive!
Feb 17, 2010 | Acer Aspire 5520-5908 Notebook
My pc get over heated & suddenly get off
The Processor fan needs cleaning or needs to be replaced.So please contact a hardware vendor otherwise if you are capable do it yourself.
Aug 11, 2009 | Computers & Internet
Have to download the acer aspire 5520G driver software and instal
Go to the Acer WEB site to download the drivers you need, make sure it is Windows XP or Vista version for your particular MODEL laptop.
Use this link :-
http://global.acer.com/support/download.htm
Apr 29, 2009 | Acer Aspire 5520-5156 Laptop
Acer 5520-5865 lap-top problem
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Problems similar to yours have been addressed before and one of my fellow member has written a good fix, pls click here.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 12, 2008 | Acer Aspire 5520-5908 Notebook
Prob. 1unit shuts off by itself/ prob 2.back is cracking again
IT SOUNDS TO ME LIKE THAT YOUR UNIT IS OVER HEATING WHICH IS VERY COMMON WITH CHEAPER LAP TOPS. YOU CAN GO GET A LAP COOLER FROM STAPLES OR A LOCAL ELECTRONIC STORE THEY ARE NOT VERY MUCH. DID YOU DROP IT?
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
No sound
Sir, I have one compaq c 700 lap top. Its sound system is not working after I formatted it. kindly guide me as to how I can be able to instal sound in the lap top.
Sep 09, 2008 | Compaq Presario 700 470024-192 Notebook
Acer 3000 Lap Top problem
it may be in hiber nation trie to go into BIOS! press f1 f2 f3 over and over when you r computer boots
Oct 05, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5520-5908 Notebook Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
