Question about HP PSC 2110 All-In-One InkJet Printer
Im trying to remove the cartridges ffom my printer but they are not budging ..what do i do ??
  • 4 Answers
This is the way to properly remove the cartridges:
Step 1: Open top of printer
Step 2: Lift up the flap on top of the cartridges by first pushing down, then pulling out, then pushing up
Step 3: Slightly push up cartridge and pull out
Step 4: You now have the cartridge out im trying to remove the - 936d5e3.jpg /> 936d5e3.jpg
I hope this helped! :]
Posted on Feb 13, 2009
Put the b&w cartridge in the color carrier and put the color cartridge in b&w carrier. Now both are stuck
You are going to have to figure out what is catching and try to work around it. Sometimes using a thin plastic stick can help to work cartridges past any obstructions.
Jun 14, 2015 | HP PSC 1410v All-in-One Printer
HP Photosmart C3180 carriage permanently stuck on right. How to fix this?
If the carriage totally stuck on the right side of the printer, Unplug the printer from Power outlet.
Open the front access door. You will see the cartridges. Remove the cartridges. Check for any paper stuck in the Carriage Rod. Try to manually move the carriage 5-6 times left to right and it should move without any trouble. Put the cartridges back into the Cartridge slot and power on the printer
If the Carriage does not move manually, there could be chances the printer needs mechanical repair as its broken.
Sep 16, 2012 | HP Photosmart C3180 All-In-One InkJet...
My printer is continuesly telling me that i have a paper jam , which i dont & im unabe to print what im doing -____-
my printer X5470 is telling me that I have paper jam, which I dont im unaba to print,what im doing
Jun 14, 2011 | Lexmark C533DN InkJet Printer
I have a paper jam in my MFC -7420. I removed a sheet from the back but there is more stuck in the front. The message says to open front cover and remove drum. I have opened the front cover but...
Don't try to remove the drum by itself while it's still in the machine,
just simply remove the drum and toner cartridge together.
There is no lock you should just be able to pull the cartridge out.
Jun 09, 2011 | Brother MFC 7420 All-In-One Laser Printer
Cannot remove toner cartridge from Brother HL 2170W
Had the same thing happen to me today. When you open the door to pull out the cartridge, there is an arm (less than an inch away from the green tab) on the printer which should connect to the door. When you open the door it retracts a wheel which releases the toner cartridge/drum assembly. This had become disconnected from the door.
Oct 03, 2009 | Brother HL-2170W Laser Printer
Need to take new cartridge back out. It won't budge.
  1. Check cartridge make sure you removed tape covering electrical contacts. do not touch contacts with fingers or metal objects.
  2. Check printer contacts bake sure there is no tape paper or obstruction blocking contacts.
  3. Replace cartridge then turn printer on.
  4. Not working remove cartridge.
  5. using a pencil eraser gently clean contacts with eraser both printer & cartridge.
  6. wipe residue off with a non static lent free dry cloth.
  7. Repeat #3
  8. Still not working try new cartridge the one you have may be bad.
  9. Still not working contact be & we will try something else.
Please rate if fixed or helped. Thank you. Good Luck! I'll standby if you need more help.
Mar 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canon copier D761's printer cartridge is jammed
That door above the cartridge needs to be open all of the way, maybe even push it back gentley to make sure. Should be at 90-92 degree angle. Then the cartridge will come out.
Jan 08, 2009 | Canon imageCLASS D761 Copier
HP PSC 2110 All-In-One InkJet Printer Logo
Ben Johnson
