Back to:
Tags:
SanDisk MobileMate SD Plus 5-in-1 Media Card Reader  Hard Drive
Sandisk Card Reader will not work
posted by davidm8985 on Jan 29, 2007
I recently had problems downloading images from my new Canon PowerShot S3IS camera and someone mentioned that it would be easier to get a card reader.
So, I bought a Sandisk "5-in-1 card reader/writer" hoping to bypass my problems with the digital camera software. Instead, now I have run into a problem with the card reader...
I have installed (and reinstalled) the software from the disk that the card reader came with. The button on the card reader is ONLY supposed to be lit up when a card is "correctly plugged in" - instead the light won't go off as long as it is connected to the computer. With a card or not.
The when I plug the card in the light stays lit. If I push the button then nothing happens. If I open up the program on the computer it says "The SanDisk TransferMater Monitor is already running. Connect or insert your media card to launch the application"
I have also plugged in all of my cards (I bought 3 new ones with the camera". Still no luck. I will probably post my problems with the digital camera software also. I just want to get my pics to my computer - didn't expect it to be so difficult.
Comment by davidm8985, posted on Jan 29, 2007
Windows XP
Comment by davidm8985, posted on Jan 30, 2007
The light just stays a straight green. It does not change colors or blink (although the manual says that it should go to orange and/or blink at times). Even when there is no card it stays green. The computer doesn't have anything pop up or anything like that. When I doubleclick the program in the taskbar or in the start menu it just says to insert the card.
also.. the manual says that you can go to the sandisk website and they have troubleshooting material on there. I went to the site and they list all kinds of model number card readers... there was probably about 10 of them.. and my model number was not even listed. This model number is sddr-99 if that helps.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
tomj23
Rank:Guru Guru
Rating: 86%, 1561 votes
What operating system are you using?
Comment by tomj23, posted on Jan 30, 2007
XP should automatically recognize your card reader and install the drivers for it.
I too have a Sandisk 5-in-one and it always has an amber light on while connected to the PC. A green LED should come on when you plug in a functional card. In fact when Windows detects the card it should open a box asking what you want to to do and if it should remember this action.
Any of this describe what you're seeing?
I just went to the Sandisk site and it is pretty useless when it comes to the card readers. I?ve never had a problem with card readers being defective, typically the issues are with memory card, how they are inserted or the USB port the reader is plugged into.
-Insure you are inserting the memory card in the correct slot and oriented in the correct direction. I?m embarrassed to say I?ve made this mistake a couple of times.
-Next ensure the card reader is plugged directly into a computer USB port, not a hub or extension cable. A hub, especially an un-powered one can cause all kinds of problems.
-Next I would make sure the USB port you are using works correctly. The simplest way is to plug use another USB port (again a PC port) that is currently running another functional USB device.
-I have had occasions where network drive mappings or other USB devices have interfered with the reader. Try unplugging your computer from your network, and unplug any external USB drives including USB thumb drives. Then attach your USB reader with card already inserted, start your computer and test.
-If you still have not luck try to get hold of another memory card try it in your reader. You might even try another memory card type, after all the contacts in the reader could be damaged. Try formatting it with your camera and seeing if that works. I once had a card that had been corrupted and behaved oddly in the reader. A format fixed the problem for me.
If after doing all this I would suggest you take it back to the retailer and ask for a replacement. If you do this within a week or so they generally will comply. If not call Sandisk, tell them what you?ve done and as for a warranty replacement.
Let us know how things work out and please don't forget to rate this post.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Sandisk Card Reader will not work:
I don't want to Accept this solution
Can you Help with these Hard Drives problems?
Hard Drives
i cant opnen da freeagent drive wem i click on it try to...
Hard Drives
my portable hard drive no longer is recognized in xp pro...
Hard Drives
i just purchased a maxtor basics portable hard drive so i...
Hard Drives
I plug my simpledrive into the wall and the usb port. It...
SanDisk MobileMate SD Plus 5-in-1 Media...
I have a SanDisk ImageMate CF, Model #SDDR-91, Part Number...
Loading problems.
Repair Service
Find Hard Drive Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
