Question about RCA HD52W59 HDTV Projection Television
How to find the convergece amps
I have a 52" model R52WH76YX51, and was wondering how to find and replace the fuse for the convergence.
  • 934 Answers
On that chassis the only fuse affecting convergence is a 400ma pico fuse near the flyback transformer. If this fuse is open the signal board will never send the "ON" command to the convergence supply so the convergence will be dead.
If the pico isn't open then suspect the amps themselves or possibly an open resistor or two.
Posted on Dec 02, 2008
I have an phillips dptv 33 O the red blue & green are out of alignment
The tv have a problems known a convergence picture problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergece ICS and some or all of resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 11, 2011 | Philips 55PW9363 55" Rear Projection...
I can't find auto converge choice in menu of rca 52" rear projection tv.model # R 52 WH 74.
You have 3 pico fuses by your fly-back transformer. One of them blew that controls your convergence circuit. Your TV now thinks that it is a Basic CRT set with 1 tube. Find the bad fuse and replace with a 1/2 amp pico fuse, and re-solder all the pins of your fly-back transformer. Your menu should have the convergence option again.
Apr 27, 2011 | RCA HD52W59 HDTV Projection Television
Sony model kp57ws510 rear projection. convergence problem. convergence button on front of tv does nothing
There are a set of convergece chips that need to be replaced. If they have been replaced and you still have the convergence problem you will need to change ceramic fuses in the power supply or on the board where the STK chips are located
Mar 04, 2010 | Televison & Video
Blue bleed on screen
Ur convergence is dead.U know how to solder?Tries this Website.Tv Repair ur tv model convergece repair kit and repair it.
Sep 07, 2009 | Televison & Video
Lost convergece and not on the tv menu
Simple problem to fix for a professional; pretty hard to do yourself. There are bad connections on the flyback transformer and a fuse is open. Where do you live; i'm due for a road trip.
May 12, 2009 | RCA R56WH76 Projection Television
Big Screen problem
What did you put in. convergence amp or convergence power. this is a rca hd52w59? i always ask the question in customer menu under setup can you see the option of convergence. if not this is the fl231 fuse problem. consult the article fl231 under tips and tricks section of my profile. the curved picture is an indication complete loss of convergence power. there is a board that does provide convergece power. The convergence on this set is controled by three diffrent boards. power,amp and the small signal board. the small signal board is the most expensive and most complicated to replace ussally a tech has to replace that.
Nov 08, 2008 | RCA HD52W59 HDTV Projection Television
Toshiba tv model # tp55h60
Convergence amp ic bad
Feb 04, 2008 | Toshiba TP55H60 55" Rear Projection...
Can not convergence
Check for poor solder connections on both StK392-570 convergence Ics (Mitsubishi p/n # 267p150010) If there are none you may have to replace the amps - but that should restore normal convergence..
Dec 08, 2007 | Mitsubishi WS-55809 55" Rear Projection...
HDTV convergence going bad
convergence is tricky.. there are three seprate boards that it is split with.. do you have NO convergece at all.. could be convergence power color... convergence amplifer board.. it it could be the signal board.. there's even a chance it could be a descrete fuse... shoot me some more info..
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
65 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
