Question about Dymo LabelWriter 400 Thermal Printer
Import information from a spreedsheet
Good morning
I have an MO excel spreedsheet with names and addresses on them. I need to print labels for all of them.
PLS help.
    Problem Solver:
  • 7 Answers
Use the "print from a database" function that the software for the DYMO has. It will allow you to import a database (in this cae your excel spreadsheet) and "map" it to the fields on an address label, like first name, address etc.
Posted on Dec 31, 2008
How do I add an email address to "other contacts" in my gmail contacts?
That probably depends upon the 3rd party. You MIGHT try exporting your contacts list (as a .csv, or Comma Separated Values, file). You can then open that file with Excel or OpenOffice Spreadsheet and change it around however you like. Your 3rd party software may be able to import the .csv file, or you may be able to reimport it into gMail and have it automatically rearrange your contacts.
Aug 03, 2014 | Google Gmail
Can i export easy-mark label information into excel
On the File tab there is an Export/Import choice. Give it a try
May 14, 2014 | Panduit Easy-Mark Labeling Software...
When importing data from Excel 2010 spreadsheet Easy Mark says you must install Excel
If you selected an Excel spreadsheet from the Data Import dialog, you will need to select which worksheet within the spreadsheet contains the label data you wish to import. If you don't have Excel installed you'll need at least Excel Viewer as Easy Mark relies on the users system to view the worksheet.
Oct 17, 2013 | Panduit Easy-Mark Labeling Software...
How do I import addresses from excel to my Dymo LabelWriter 4XL Thermal Label Printer?
You first need to install DYMO Label. If you already have installed it, click Address Book > Import to import addresses.
Sep 05, 2013 | Zebra TLP 2844-Z Thermal Label Printer
I need to print mailing labels imported from excel to word in columnar order instead of in order by rows across the page.
hi Samajane,
I understand the you excel file has data that is stored column wise. Well you can first convert the column wise data to row wise data and then import it to you word.
To convert the column wise data to row wise data.
1.Select the data in your worksheet.
2.Right Click -> Copy
3.Create a blank worksheet.
4.Goto Edit - > Paste Special
5.Check the Transponse Option
6.Press OK.
Now you have converted your column wise data to row wise data and now u can import it to your word and print mailing labels
Dec 14, 2009 | Microsoft Windows XP Professional
I have several address stored in Excel. Now I
You don't need to print labels in Excel. You can use the mail merge feature in Word to do so. Use the Excel file as the data.
Nov 06, 2009 | Microsoft Excel for PC
How do you print envelopes?
More information is required so I will only assume you are using Excel as a database. Excel is a spread sheet program used by accountants or for mathematical formulas and ledgers. Access is the Database program, however, Excel has functions which is faster to sort and work with address, phone number, zip codes. I will confess, I use Excel as Database because it is quick and easy. I do not know what version of Excel you are using so I will describe it from Office 2007. From Excel make sure you have headers above each column i.e. First Name in Cell A1 Last Name in Cell B1 Address in Cell C1 ect.
Make sure your data is correct and case sensitive as you would like it. If you want zip+4 select the Colum and right click to format the cells using special and select Zip or Zip+4.
It is easiest to use Microsoft Word for the next step rather than format the cells, add page breaks, and customize the print size.
Save your document as an Excel document where you can find it to import it into Word.
Open word and select Mailings then Start Mail Merge and Step by Step Mail Merge.
Select Envelope and next. Select envelope options to change envelope size, font and print options.
Click on Next Select recipients.
Click on browse under select an existing list.
Select the Excel file with your address information.
From the Select Table check the First row of data contains column headers.
Click on the OK buton.
Arrange your envelope then Preview it and your good to go.
If you have an older version of word selects Tools and click on Mail Merge.
Select Get Data.
Pull down Excel for document type.
Select entire Spread Sheet.
Layout your document and complete the merge.
On old versions of word it may not recognize the Excel file. If this happens open the Excel file and save it as a Database File (.dbf) and it should work.
I hope this helps since I did not have enough information from your question.
Jul 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Changes from 1 to 3 pages for Excel Print Area
verify the page dimension in your driver together with the header and footer dimensions
Mar 11, 2009 | Zebra GK420 Thermal Printer
IF formula for letter grading in excell spreedsheet
If you can email to forward me your email address (should this be agreeable), I can send you a copy of an excel sheet that automatically computes the grade and have the final grade in 1.0, 1.25, 1.50, 1.75 etc. You can then substitute the A, B, C.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Nov 02, 2008 | Microsoft Windows XP Home Edition
How to create labels from excel data sheet
sir u just have to write all info row wise then ur issue will be resolved good luck
Oct 21, 2007 | Microsoft Windows XP Professional With...
Dymo LabelWriter 400 Thermal Printer Logo
751 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
