Question about HP Officejet 5610 All-In-One InkJet Printer
HP Officejet 5610 cannot receive fax automatically
I am not able to receive fax automatically. When there is a fax coming in, i need to press FAX button to receive fax. How do i set the fax to come in automatically.. please help! Thanks
  • ttballdavis Dec 03, 2008
    I too can not receive a fax, unless I am at the printer, how do I set it for a number of rings.
MerlinTech
  • 197 Answers
SOURCE: HP Officejet 5610 Fax Failure
you may need to reinstall the driver set, which can get corrupted with power glitches.
www.hp.com for fresh drivers
Posted on Jun 21, 2008
  • 35 Answers
SOURCE: I want to set my HP office jet 5610 on to auto answer
You must set Auto Answer to on. More info can be found on page 68 of the user guide found here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=441125&
Posted on Nov 11, 2008
  • 71 Answers
SOURCE: set up HP 5610 to fax lost manual
this link will get you to the HP web site page for manuals on your printer. http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&dlc=en&product=441125&
Posted on Sep 07, 2007
SOURCE: HP Officejet 4315v will not ans fax automatically
my office jet prints, scan and you can call it it picks up but will not allow the fax
Posted on Jan 16, 2008
emissionwiz
  • 77201 Answers
SOURCE: Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
Posted on Oct 10, 2008
I can not receive fax but i can send fax the printer hp officejet5610 was at the client he receive the error that says fax fail brought the printer to my workshop the printer gives the same error please...
Hi, Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code.
  1. To modify the fax header, use the following steps:
    1. Press Setup on the product control panel.
    2. Press Basic Fax Setup , and then press Fax Header .
    3. Type personal or company information using the keypad, and then press OK .
    4. Type the phone number, including area code, for your HP fax product, and then press OK .
Regards,
Riztech
May 23, 2011 | HP Officejet 5610 All-In-One InkJet...
My HP J6480 All-in-One will fax out but I can't get it to receive incoming faxes. I have cleared the fax log, but it still won't receive incoming faxes
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab11
Jul 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp all in one 5610 wont receive fax and phone line does not go on double ring . incoming fax shows phone off hook when trying to receive fax.no ready appears
hi,
ab2
Jul 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Fax will not receive faxes
You have to go through your menu to fax functions & change it from manual to automatic.
Jul 02, 2009 | HP Officejet 5610 All-In-One InkJet...
FAX
If you have fax on hp officejet 5610.
You can recive fax .
start>steeting>printers and Fax> Setup Fax.You need windows XP CD for this Fax installation.IF manufacturer given software u r not need to install again.Just review the fax configuration by rigt click on fax icon then go to properties.
IF it helps
pls RATE ME
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Need confirmation of fax sent and received
You can setup the printer to print a confirmation page on send. Push the setup button - then push right arrow until you see print report and press okay - press right arrow until you see fax confirmation and press ok - push right until it says on send and press ok. Hit cancel to go back to default and now you will get a confirmation for all sent faxes.
Jan 16, 2009 | HP Officejet 5610 All-In-One InkJet...
Can not recieve fax. currently just hooked to phone line
Receive a fax
Depending on the Auto Answer setting, your HP All-in-One can receive faxes
automatically or manually. If you have set the Auto Answer option to Off, you will
need to receive faxes manually. If the Auto Answer option is set to On (the default
setting), your HP All-in-One will automatically answer incoming calls and receive faxes
after the number of rings specified by the Rings to Answer setting. (The default
Rings to Answer setting is five rings.)
Receive a fax manually
If you set up your HP All-in-One to receive faxes manually (the Auto Answer option is
set to Off) or you answer the phone and hear fax tones,
1. Make sure the HP All-in-One is turned on and you have paper loaded in the input
tray.
2. Remove any originals from the document feeder tray.
3. If you are currently on the phone with the sender, instruct the sender to press
Start on their fax machine.
4. When you hear fax tones from a sending fax machine, do the following:
a. Press Fax on the control panel of your HP All-in-One.
b. When prompted, press 2 to select Receive fax.
c. After the HP All-in-One begins to receive the fax, you can hang up the phone.
Jan 14, 2009 | HP Officejet 5610 All-In-One InkJet...
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
If you need printed confirmation that your faxes were successfully sent, follow these
instructions to enable fax confirmation before sending any faxes. Select either On
Fax Send or Send & Receive.
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send &
Receive
Prints a fax confirmation report for every fax you send and
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
You can try resetting the printer.
Step 1. Unplug the power cord at the back of the printer while the printer is still on
Step 2. Press and hold the # and 6 button on the printer while the power cord is disconnected. And keep holdig the two buttons until you plug in the power back again.
Note : do not release the # and 6 when you plug the power cord back in. keep holding the two buttons until the printer would turn on then turn off or the printer would say anything about "reset"
Step 3. Try sending a fax after the successful reset of the printer
Jun 21, 2008 | HP Officejet 5610 All-In-One InkJet...
HP 5600 all in one
For this, you need to configure your HP All in One in "answer fax calls automatically" mode.
Follow the instructions as below :
Press Setup on the panel
Press 4 then press 2 ( This selects basic fax setup and then selects auto answer )
Press > to select ON
Press OK to accept the setting.
You may like to change number of rings before auto answering the fax. You can do this by :
Press Setup
Press 4 then press 3 ( This selects Basic Fax Setup and then selects rings to answer )
Enter appropriate nuber of rings by keypad or by < OR >
Best of Luck,
rajesh_im
Feb 13, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
808 people viewed this question
Seeker5211
Seeker5211
