Question about Zanussi ZM24ST Microwave Oven
ZANUSSI ZMB32CT COMBINATION OVEN
DISPLAY FREQUENTLY SHOWS "E15" SWITCHING OFF AND ON AT THE MAINS CLEARS THE FAULT BUT IT REAPPEARS AFTER ABOUT A FEW DAYS
  • Brookstreger Mar 01, 2009
    Same model. ZMB32CT. Same problem. Keeps switching off showing error E15. Switching off at the mains clears it but it is happening more frequently.
3 Suggested Answers
Skill Will
  • 53 Answers
SOURCE: How do i change the lightbulb in my Zanussi ZCM32T Combination Oven
hi
two VERY important things... first, turn off the breaker (power) to the unit, and second, do NOT touch the bulb with your bare hands (use thin gloves or rubber gloves), you don't want to get any thing on the bulb, like grease. I don't know this exact model but, to remove the bulb, there should be a grill on top of the microwave, take that off and there should be a panel above the bulb inside, remove that and you should be able to reach the bulb now.
Posted on Mar 21, 2008
SOURCE: connecting an zanussi oven to the mains
Is the problem with the plug?
Posted on Jul 11, 2012
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
The display window is stating the oven is in "demo mode". We did have a power failure prior to this function happening. What can we do?
I had the same problem after a power cut and eventually thought of switching it off at the mains and turning back on after a couple of seconds... it worked. Just needed to reset the clock and off I went!!! ;-)
Feb 05, 2011 | Panasonic NN-T888S Convection/Microwave...
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
Clock frequently goes blank and needs to be reset
You have a faulty display module due to one or more components leaking. Some models have a seperate display module that can replaced without the complete board having to be replaced. If not, the board needs to be replaced. You need to ask your spares suppliers that have info. on that model.
May 21, 2010 | Hotpoint RVM1325WW Microwave Oven
Touchpad is not working
Hello :
If touch pad has gotten wet, then allow to dry for several days. Avoid spraying cleaning liquid near touch pad.
Check for insect infestation. Insects (cockroaches most frequently) will appear under clear surface of touch pad or under readout window; they like the warmth of the circuit boards.
Place window mesh over vent to keep insects out.
good luck .
please rate !
Mar 29, 2010 | GE Microwave Ovens
Keeps flashing a 'mains low' message on display. Have already tripped the main and the message in no longer constant but comes up whenever you try to use the unit.
What else is on the same circuit?? You may have to check on another outlet and see if you get the same message.If not ,that's the problem>too much pulling on 1 circuit.
Mar 26, 2010 | KitchenAid KHHS179LSS Convection /...
Switching off the sound of my Samsung Microwave
1 Press the Sound button. The display shows "ON".
("START" will flash)
2 Press the Sound button to turn the volume off. The display shows:
"OFF".("START" will flash)
3 Press Start. The display returns to the time of day.
Lastly, you can find a copy of the manual here:
http://downloadcenter.samsung.com/content/UM/200507/20050727140356453_DE68-01945A[GB].pdf
Sep 01, 2009 | Samsung MW1030WA Microwave Oven
Zanussi ZM24ST Microwave Oven Logo
443 people viewed this question
Top Zanussi Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Zanussi Microwave Oven Expert? Answer questions, earn points and help others
