I need to replace a broken handle on the following appliance:-
Liebherr Premium Bio Fresh.
Model No KB4250
Index 21D/001
Serial no 9983182/04
This is a spring loaded handle can you advise where I can purchase.
SOURCE: Broken part
just say I'm sorry and ask them wher it was purchsed , surley the store can order a part
SOURCE: Liebherr bio fresh fridge/freezer model
This ice maker can be cycled manually to help determine the problem. To
cycle this ice maker, pull the front cover off of the ice maker. You
will now have access to the module which has some test terminals marked
on it (I'm sending you a picture). Using a well insulated jumper, place
it between T-H and the ice maker should start to cycle.
Be careful this
is a hot (live) check. If the ice maker starts, after about 5 seconds
remove the jumper. It will take a few minutes for it to break the ice
free and if it cycles completely and refills the ice maker will need to
be replaced. This indicates it's not starting on its own. If it just
stops on the ice, the mold heater may be open. You should be able to
feel the bottom of the ice maker to see if it's getting warm but be
careful, if you touch the mold heater, it can be very hot. If the mold
heater is not hot, again the ice maker will need to be replaced. If the
ice maker never cycles with the jumper, there may not be any voltage
getting to the ice maker. Some voltage checks will need to be made and a
technician will be needed to make these checks.
Hope this helps.
SOURCE: Cuccumbers and tomato freezing in
Hi, There can be many reasons why your
refrigerator is freezing your food. To see what could be happening
and to figure out how to possibly fix your problem. Take a look at
this tip which contains many of the causes and solutions to fix the
problems.
Refrigerator
is Too Cold and Freezing Food
heatman101
problems.
Refrigerator
heatman101
