Question about Dell Inspiron 6000 Notebook
Mutiple screens after startup
After I start up my dell inspiron 6000 laptop I get my desktop x 4 ( in 4 small identical screens)
  • Lisa Musarra Jul 29, 2007
    Thank you I am still having the same problem, as I never have time to speak to dell about it I have my laptop hooked to an external monitor as my second screen and I can drag the windows that are too small to see over there and they are full size! So you could do that for the time being but it is still not a solution!
    New Friend:
  • 144 Answers
This is a common problem for some motherboards. Its easely fix by a professional, if you have no experience on laptops hardware dont try it.
You justa have to open de laptope case and find the GPU and CPU chips. Then see were is thermal mass, then wipe it clean and apply fresh mass.
That solves the problem. its related to overheat, bad manufacture of the board.
Posted on Oct 21, 2013
Help this doesn't solve the problem, it just changes the wallpaper on the desktop of the 4 screens. Someone said maybe I have something wrong with my video card?? Sometimes when I restart a couple of times it will restart normally but now I cannot get one screen. I have four identical squares of whatever I am running on my screen, separated vertically by a black band about 2" wide.
Posted on Jan 31, 2007
  • 624 Answers
From your description it sounds like you've got an image set as your desktop background and it set to "tile" mode. If this is the case you can change it as follows: -Click on Start, settings, control panel -Double left click on Display. -Click on the Desktop tab -If you want to remove the background image just highlight None from the list of backgrounds. If you just want to display one, small image click on pull down arrow to the left of the Position field (bottom right hand section) and select Center. Use Stretch to make the picture fill the entire field. If this solves your issue please don't forget to rate the posting, otherwise give us some additional details as to the exact nature of your issue.
Posted on Jan 29, 2007
I have a dell Inspiron 6000 It is very slow in getting to the desktop screen. When it does, it still takes a long time to load an application. I have norton antivirus software loaded, but when it runs(very...
Probably it has some virus that slows down the booting process.Besides that you might have many startup programs,which you can un-install if you don't need at startup.Also, cleaning your disks will be a good idea.These tips might help solve the sluggish attitude!
Aug 21, 2010 | Dell Inspiron 6000 Notebook
My Dell Inspiron 6000 turns on but then it says there is a problem with it and goes to a blue screen.
It sounds like to have missing o/s startup files, try using your recovery disc to do a repair
Dec 02, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 screen splitting
This is a generic problem in most of Dell Laptops ( mostly inspiron ). It is caused due to a fatal fault or breakage in the Hinge Assembly. You need a new Hinge Assembly. Is it splitting more on decreasing the angle of the monitor. If yes, Hinge assembly is the only culprit. If you are under Warrenty then Dell will be liable for it and replace it free. If not under Warrenty, I approx. costs 300$. Thank you Sir, Have a nice day.
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Replaced inspiron 6000 screen with 6400 screen
the screen is bad just look for something to do about it.
Jul 06, 2009 | Dell Inspiron 6000 Notebook
Hi, I have a Dell Inspiron 6400 Notebook, and I'm having problems with keyboard. When I'm writing something the letters sudenly stop to aper on screen and after few seconds they all appear at once. This...
This because the system might be running mutiple processes. Remove the programs from startup. Download ccleaner. Delete temporary files using it. Check whether disk defragmantation is required
Jun 23, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6000
u need to check the same issue using another monitor or a display device if u get the same 4 screen resolution then its the video card or else the issue is with the LCD.
May 15, 2009 | Dell Inspiron 8600 Notebook
Image on the screen is very faint
It sounds like yout lcd inverter is blown. You can usually get a new one and replace it yourself. I would look on ebay. Its just a small computer chip that fits inside of the monitor housing.
May 14, 2009 | Dell Inspiron 6000 Notebook
Screensaver on my Dell Inspiron 6000 does not work
Several things can interfere with the operation of a screen saver. Usually it is a process of elimintaion as to what is preventing it from working.
Start, RUN, MSCONFIG <enter> will open the system configuration utility. Disable the startup group, reboot, see if issue still occurs.
If screen saver then works, you can go back and add items to the startup group until you ID the item causing the issue.
If disabling startup has no effect, go to the services tab of MSCONFIG, check HIDE ALL Microsoft services, then disable the remaining ones and follow the same process
Apr 01, 2009 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Blank screen
right mouse click on the desktop now show the desktop icons? was this ok?
Sep 18, 2007 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
159 people viewed this question
Clive
Clive
Alun Cox
