Telewest box can someone help i have a scientific explorer 4200dvb receiver for my cable i cannot get a signal on it when you turn it on it just says tune and it is non responsive can u help please
SOURCE: Cable Box compatibility.
my cable box want turn on
Posted on Jun 20, 2008
SOURCE: No Ranging Response received - T3 time-out
below 55dBmv TX is a lot better. Could be a bad service line. Also if you call the cable company and have them come out again. Have them put their DSAM meters on the house lines as well as the service tap and have them check for upstream ingress. a lot of things can cause this. It could be a loose fitting somewhere in the house. A t.v.'s shielding may be going out causing unwanted frequencies bleeding in and creating all kinds of noise on the upstream spectrum going back to the node. It could even be a neighbor causing this with their own equipment. If that's the case their maintenance techs should be able to find that.
Posted on Mar 11, 2009
  • 22 Answers
SOURCE: Code For Scientific Atlanta Explorer 1840 Cable Box
Try this first:
1. Press and hold SELECT and CBL until all mode keys blink twice.
2. Press 9 7 7. All mode keys blink three times. Then, after a few seconds the CBL key
blinks twice.
This put's the remote back to default. If you need more help let me know.
Posted on Mar 31, 2009
adnanbhatti
  • 1188 Answers
SOURCE: Need Scientific Atlanta 8300HD DVR code
You can follow the two methods I have explained below:
AUTO SEARCH FOR CODE
To program your remote in Auto Search Mode, first turn on the device you wish to program and point the remote toward it.
Then press and hold the SET and POWER buttons until the LED turns on.
Then press the device key ( CATV or RCVR) .
The LED will flash once.
Then press the CH+ button.
Then hold the POWER button for about two seconds until the LED turns on.
Release the POWER button and the LED will flash slowly. Your remote is searching through all of the codes. Continue to point the remote at the device until your device responds.
If your device turns off, turn it back on and press the CH+ button on your remote. Then press the POWER button and CH+ button alternately until the device turns off and the code is correct. Press the ENTER button to confirm and store the code. The LED will flash three times and then turn off.
If the above is not helpful then try manually searching for code:
First, press the device button on your remote.
Then press and hold the SET button. While holding the SET button, press 1 to find the first digit, 2 to find the second digit or 3 to find the third digit.
The LED flashing time will stand for each code number. If it doesn’t flash, it will stand for zero.
For example, the TV code you are trying to find is 102.
Press the SET button and 1. The LED will flash one time.
Press the SET button and 2. The LED will not flash.
Press the SET button and 3. The LED will flash two times.
Hope it helps to find your code. Thank you for using fixya!
Posted on Sep 25, 2009
  • 3 Answers
SOURCE: need new code for telewest
cf 53 0c 33 79 61 71 85
52 5e 8d 45 fc 75 f6 4a
Try this ENJOYYYYYYYYYYYYYYYYY
Posted on Dec 03, 2009
I can't turn on closed captioning on Hitachi with Comcast scientific atlanta explorer 2200 cable box. Any words of wisdom?
Both the set and the box used should have the closed caption feature.
If box is in line to rear audio/video jacks you will have to engage the CC from the box.
I doubt it will work if hooked that way from within the box---go to menu and in CC area in either set or box select CC1 which is the most common one used.
May 25, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Picture/audio problems on my HDTV
This is a cable box problem. Could be a lack of signal stregnth or bad HDMI output.
The SA boxes have a very bad history of this, try using the component video output and see if the problem persists.
The HDMI is a real glass jaw of those boxes; but this problem could absolutly be your incoming signal...high def channels require more signal strength and that is what causes audio drops, pixilation and flicker.
If it was the HDMI in the receiver/tv you would get:
- Black screen, Pink fuzz or green streak dropouts.
- "Fireflies"
- Audio cutting in and out
- Not pixilation!
So what is my approach? If the box is rented or under warranty get it replaced. If the problem persists then call your cable company and arrange a service call at their expense.
If the box is not under warrenty go ahead and call the cable company and complain about a poor signal. If the signal is good, use the component video output...it looks almost identical anyway.
Let me know if this helps,
Cheers!
Feb 03, 2010 | Sony STR-DG820 Receiver
Signal drops out, displays "No Signal"
My best guess is the signal to the Cable box. It is not a hardeware problem if you replaced the box it has to be the cable signal. Loose connections are sometimes the problem.
Nov 08, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Apr 12, 2009 | Onkyo TX-SR705 Receiver
Convert 480i to 720p
Turn off cable box.
Turn on TV.
Hold down media and guide for a few seconds.
On TV pick the resolution you want. Your choices are 480i, 480p, 720p, some wide screen resolutions and 1080i.
Save the results.
You should be good to go.
Jan 25, 2009 | Philips Magnavox Learning Universal Remote
I have the following hardware: Marantz SR-4003 Receiver, Samsung LN52A650 HD TV, Samsung BDP-1500 Blu-Ray player, Scientific Atlanta Explorer 8300HD cable box, two Paradigm Millenia 20 LCR Bookshelf...
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
Jan 25, 2009 | Marantz SR-5600 Receiver
Off Air?
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Jan 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Oct 18, 2007 | Aiwa AV-D57 Receiver
HDMI->DVI cable won't work
Get another cable box, the scientific atlanta are notorios for these type of problems
Mar 26, 2007 | iLO 2600 Television
77 people viewed this question
 Grubhead
Grubhead
