Question about Indesit 24 in. D61 Free-standing Dishwasher
Broken door handle Indesit dishwasher DG 6100
The plastic door handle on my Indesit DG 6100 dishwasher is broken. Please can you advise the best place to obtain a replacement and how to fit it.
  • Charles Colton Feb 03, 2007
    Problem solved by reading "Broken door catch" solution.
  • POR T480 Jan 03, 2009
    I have the same problem
    Scholar:
  • 195 Answers
Broken door handle solution
Posted on Mar 07, 2008
Done this a couple of times.get replacement handle £5 from online or any good spares shop. Take out screws from door panels. top essembley comes off, a bit tricky. remove springs and replace. repeat in reverse. take about 1 hour.
Posted on May 17, 2007
I agree read "broken door catch" solution and be particularly careful in respect of the edges of the stailess steel panels - some of the edges are hidden and they are very sharp.
Posted on Apr 21, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I have an Indesit DV62WHUK dishwasher and the last night the door made a banging sound when it was opened and now it won't close and will fall back under it's own weight. I suspect either a spring, spring...
There is a plastic unit behind the door handle which houses a spring under tension. This latches the door closed and makes the electrical connection to allow the machine to work properly. You need to buy a new unit (£15) which is a bit fiddly to reach but easy to fit (2 screws)
Dec 02, 2010 | Indesit 23 in. DV62 IX Built-in Dishwasher
How to wire indesit dg 6100 door control panel, which wires go where?
You will have to contact the manufacturer and ask them for a wiring schematic of that particular model.
Feb 12, 2010 | Indesit 24 in. D61 Free-standing...
Door lach/handle plastic pins have broken off and two pronge ears attached to door that hold handle in place have also broken off. This is a Maytag Model MDB5600AWW dishwasher.
handle was redesigned with a metal rod through the attachment points to prevent breaking. the handle and latch comes as a complete assembly (you don't have to put it together).
Jan 09, 2010 | Maytag Dishwashers
Amana Dishwasher Mod. ADB1500AWQ, Door won't open.
HI,
Please check whether the plastic pins are broken.
I removed the inner door panel and found the handle broken. It has integrally molded plastic pins that provide a pivot for the handle to push against the release assembly. These were broken off. Also noticed that there were some small fingers molded on the back of the switch panel that were snapped off. I'm not sure what these are for and I can't see how they are needed for the latch operation. My hunch is that they aid in positioning the handle during factory assembly. I'm NOT going to buy a new switch panel to replace these!
I don't know why the handle broke but it did so in stages. I think one pin broke, and then everything else broke because of added misalignment and stress. The good news: a new handle only costs about $10 and I'll have it in a couple of days. Thanks
Apr 24, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Dishwasher door will not open.tried running it another cycle and still nothing.It is a GE profile with the latch that you just push in. The latch/handle seems stiff.
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Sep 28, 2008 | Dishwashers
Indesit IDL530
it will require the door outer casing to be removed and the control panel to be removed as the lock assembly is fitted to the control panel,please make sure appliance is disconected from the mains supply as there are electrical connections there.
Sep 21, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Hi, the handle has broken off my Indesit WA 125 Front Load Washer. I cannot open the door to get my clothes out, any suggestions? Also, would it be possible to buy a door (part of the plastic on the door...
I don't know where you live but in St. Paul and most other cities, there are appliace parts distributers, adn they sell to the public. If you can figure out how to get what is left of the handle off of the machine, you can probably put a new one on.
Sep 05, 2008 | Indesit Washing Machines
Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Jul 10, 2008 | Indesit W 123 Front Load Washer
Indesit d41 dishwasher
try testing the door interlock, actually this is only a micro switch inside the door behind the plastic front panel, there could also be the possibility there is a broken wire behind the door skin just above the hinge part, take care when working on appliances do not force parts to remove them and always unplug at the mains hope i have helped, if so please rate me well
Sep 26, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit DG 6100
the seal on the top drawer is damaged
Oct 05, 2006 | Indesit 24 in. D61 Free-standing...
Indesit 24 in. D61 Free-standing Dishwasher Logo
1,677 people viewed this question
Top Indesit Dishwashers Experts
Marvin
Marvin
NOEL
NOEL
Ngoro
Ngoro
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
