Unable to connect (chat)
Once i click the off button to turn the chat on....a window shows an "unable to connect" sign. (error # 1001).
Please help!!!!
Thanks
Unable to open file:// insufficient permission to access
Right click on the file and click properties, click security, click edit, click add ,Click advanced button and click find. Find your user in the list and double click it. click ok. Highlight your name, and in the box below click full control. click ok again. Make sure you are signed onto your computer as Administrator to do this.
Oct 10, 2015 | VMware Computers & Internet
Tip
Yahoo Messenger can't sign in - Unable to Connect to Yahoo Messenger
If you are having trouble signing into Yahoo Messenger you should read this article for some Tips and Tricks to get signed in.
There are a couple of things you will want to check first as they are common causes for being unable to sign in.
1) Make sure your internet is working. The easiest way to do this is by trying to visit other websites. After you have tried to visit some websites(it is best to test sites you have never been to before) and you confirm your internet is working but still unable to sign in, then continue to the other tips.
If you can't connect to other websites, you can read my tech article on Resolving Internet Connectivity Issues - "Can't connect to the Internet"
2) Sometimes, Yahoo Messenger will be down completely for everybody on a global level. This can be caused by problems Yahoo may be having or just general technical maintenance. Your only option if this is the case is to wait until it is over. You can confirm the Yahoo Messenger status at the Yahoo Messenger Support page.
If none of the above are the issue then continue below with Advanced steps
1) This tip is a recommendation from Yahoo Tech Support
1. Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "Firewall with no proxies" option.
3. Select the correct Internet connection type and country from the pull-down menus.
4. Click the "OK" button at the bottom of the window.
5. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:
2. Enable the "Use proxies" option.
3. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
5. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button.
2) In some cases you may have a local firewall or anti virus program that is blocking Yahoo Messenger or causing connectivity issues with it. You can try to disable any Firewalls you have and Anti Virus programs and see if you can now sign in. If so, then you will probably need to add exceptions in your firewall or anti virus program to allow Yahoo Messenger. If you need assistance with this step you will need to reach out directly to the company that makes the software. A google search by the application name or company name will bring you to the website where you can find help and contact information.
3) I have worked in Technical Support for many years and a simple but often overlooked step that works is to unistall or reinstall the program. There can be any number of causes for Yahoo Messenger program files to be corrupted or lost. A simple reinstall of Yahoo Messenger can get you back up and running. The best way to do this is through Control Panel in Windows.
-Go to Control Panel > Add and Remove Programs and find Yahoo Messenger in the program list.
-Click unistall and once removed go ahead and reboot your computer.
-Once rebooted, download Yahoo Messenger and install. Click here for the files.
-Once installed, reboot your computer again.
-Once rebooted try to launch Messenger and see if you can sign in.
4) At this point, if you have exhausted all the above steps, I recommend you contact Yahoo Messenger Tech Support directly. Click here for Tech Support.
I hope my article was informative. Check out some of my other Tips and Tricks by clicking on my Username at the top of this article and then going to "Tips" under my profile.
Regards,
G33k
Keywords
unable to sign in to yahoo messenger, can't connect to yahoo messenger, can't sign in to yahoo messenger, yahoo messenger not working, connect to yahoo messenger
on Jun 05, 2011 | Yahoo Messenger
Tip
Yahoo messenger : unable to login - Web pages open very slow
Most of the times when you try to login to your yahoo messenger you get errors and you are unable to login through your ID. Kindly remember this solution is not for those who have forgotten their password. This is a yahoo servers problem which you can cunningly bypass and you can get your messenger connected.
This was the question asked by an asker
hi,i m getting problem while i m signing in in messenger.its showing message like please re-enter id n password.when i am using that pass word in my yahoo mail it works n also it works in other id but only my id its showing this error.please give me a solution as i am using yahoo messenger daily. thanks
Here goes the solution
Yahoo messenger presently is undergoing few changes at the server end. In order to login efficiently I use to run two ping commands. To do so, press on start button click on run button type cmd in the box and hit ok button. In the black window now type exactly the same in the bracket remember brackets are not included in the command (ping www.yahoo.com -t) don't forget to put space after .com before typing -t. -t is hyphen t. repeat this message once more and you will be able to login through messenger. Happy chatting
Sorry, I forgot to mention that after the command starts you have to minimize it and login to your messenger. If you are in a chat room. This will increase your speed so that your webcam will be faster and even the voice will be clear. If you wish to further know anything about any of the Chat related or any other technical issues you are most welcome to use fixya. Happy chatting
This is a tiny trick which I rarely tell people. In the organisation where I work thats totally on DSL modem and cat 5 copper cables even they use utp cables when going for more than 150 meters. Local sites open up very easily as the coppers are good but WAN sites from bangalore or delhi would take hours to open. I suffered for around one month then I got this trick. Simply ping the IP of the site to which you wan't to work faster way for you. -t in ping stands for ping continuously non stop till manually stopped. In case you don't know the IP you can simply put the web address like ping www.fixya.com -t and you will see the difference in speed on the links of that site. So enjoy and thanks for rating.
This can also be used in case few sites open very slow on your computer. In order to increase the speed of web page opening time you can always use this.
on Jul 02, 2010 | Computers & Internet
Wireless
I don't know what OS you are using ... below is the process to solve your problem in Win xp.
When you try to logon the wireless network, you may end up getting this error message: "Windows was unable to find a certificate to log you on to the network xxxx".
This particular error is normally related to the authentication on a wireless network, usually because the Windows is looking for 802.1x connection by mistake. We can fix it with the following steps.
Step 1
Click on the Start Menu --> Control panel.
Step 2
Double click on Network Connections in the pop-up window.
Step 3
Right click on wireless network connection, then click on Properties.
Step 4
Now click on the Wireless Networks tab and select the network in the list at the bottom. Click on Properties once you select the wireless network that is having problems.
Step 5
Click on the Authentication tab and now uncheck the Enable IEEE 802.1x authentication for this network box. If the box was checked, then that was why you were getting the "unable to find a certificate to log you on to the network" message because Windows is looking for one, but your wireless router is not setup for certificate security.
Step 6
Click on the Connection taband check the Connect when this network is in range box.
Step 7
Click on the Association tab and uncheck the 'The key is provided for me automatically' box, then choose Network Authentication & Data encryption and type in the Network key according to the wireless settings on your wireless router. Please contact the technician of your wireless router if you have no idea about the information.
Step 8
Click on OK and Click on OK again to save your settings.
As yet, this problem has been successfully fixed, Windows can log you on to the network automatically at once.
Mar 23, 2014 | HP Compaq nc6400 Notebook
Trying logging in yahoo messenger to chat with my friends unable to get that screen
you may have a registry problem download reginout to fix the issue
Mar 10, 2011 | Yahoo Messenger
I get this error while logging to Yahoo Messenger. Unable to login. Connecting to Virtual IP server 98.136.48.32... [FAILED]
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." 2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window. 3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. 4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reginout to fix the issue
Oct 22, 2010 | Yahoo Messenger
Unable to burn DVD, unable to access the video_TS.ifo
Hope This Helps!!! Please Rate my Response!!! Thanks!!!
ROGER
In order for me to better assist you, I will need a copy of your 123 product’s “Log Files”. Below you will find Instructions to assist you in locating these log files for both windows Vista, and Windows XP. I will also need you to include your License ID and/or Customer ID, your version number, and the name of the movie you are trying to copy.
You may reply to this email with the log files or send them to techsupport@123copydvd.com.
WINDOWS VITSA INSTRUCTIONS:
1. Click start, and click the “Computer” button.
2. Once in my computer, double click on the “Local Disk C:” icon, and click on the “Users” folder
3. Double click your User name
4. Once inside the folder, click the “Organize” button in the upper right hand corner of the screen.
5. Click “Folder and Search Options”, and move select the “View” tab.
6. Scroll down to the “Hidden Folder’s” file, and select the “Show Hidden Folders and Files” button. Click “Apply” and “OK”
7. Now you will be to see the “AppData” folder, double click that folder.
8. Once there double click the “Local” folder, then the “Virtual Store Folder”, “Program Files”, “123 Copy DVD”, and finally “Log”.
9. Attach to email, and email it to techsupport@123copydvd.com.
WINDOWS XP INSTRUCTIONS:
1. Click start, and click the “My Computer” button.
2. Once in my computer, double click on the “Local Disk C:” icon, and click on the “Program Files” folder.
3. Once inside the folder, specific to your program (Example: 123Movies2PSP or 123CopyDVD)
4. Attach to email, and email it to techsupport@123copydvd.com. Follow Each and Every Step!!!
Feb 17, 2009 | Navarre 123 Copy Dvd Gold for PC
Unable to update my protection after uploading new 2009 Micro Trend Internet Security package using a 64-bit operating system. Error message advises to check my proxy settings. I've done that. System is...
this is the resolution i got from trend micro regarding this error. it worked for me, so i thought i should share: I have reviewed your case and I understand that you are getting an error message that says “Unable To Update Your Protection” when updating the Trend Micro Consumer Product. With regard to your concern, this problem happens if there’s a missing component in your computer’s Registry. Let us configure the registry of your computer using the Registry Editor of Windows. Refer to the following. 1. Click on the Start button or the Windows Orb Button. 2. Windows XP: Click on Run then type regedit on the text field then click on the OK button. Windows Vista: Type regedit on the Start Search above the Windows Orb button then press Enter key on your keyboard. And the Registry Editor window will appear. 3. Click on the plus sign (+) or the arrow sign (>) besides HKEY_LOCAL_MACHINE. 4. Click on the plus sign (+) or the arrow sign (>) besides SOFTWARE. 5. Click on the plus sign (+) or the arrow sign (>) besides Microsoft. 6. Click on the plus sign (+) or the arrow sign (>) besides Windows. 7. Click on the plus sign (+) or the arrow sign (>) besides CurrentVersion. 8. Click on the plus sign (+) or the arrow sign (>) besides Explorer. 9. Click on the Shell Folders. 10. Look for the Common Appdata entry on the right panel. If there’s a Common Appdata entry on the list: - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. If there’s no Common Appdata entry on the list: - Right click on an empty space and options will appear. - Click on New and options will appear. - Click on the String Value option. - Set the name to Common Appdata. - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. 11. Close the Registry Editor window. 12. Restart the computer for the changes to take effect. After doing the suggested solutions, you should now be able to update the program successfully.
Jan 22, 2009 | Computers & Internet
Msn messenger error code 81000306
Windows Live Messenger error code 81000306 Problem description When you start Windows Live Messenger you cannot sign in, and you get error code 81000306 along with the message:
We were unable to sign you in to Windows Live Messenger, possibly because of a problem with the service or with your Internet connection. Please make sure that you are connected to the internet.
Error code: 81000306
Oct 18, 2008 | Computers & Internet
Open Questions:
NY-LA1877/778/89-69Norton Antivirus Tech Support Phone Number? 1-877-778-89-69 Nortan Antivirus service phone number is solve the matter of virus's. 1-877-778-89-69 is loosely used in USA. It offer the ability of 24*7 services. Nortan Antivirus customer care service number's executive able to solve the any virus problem with the assistance of Nortan antivirus support phone number.It doesn't matter from wherever you and at what time you need help. For know about us:-1877+778+89+69 If you want to the best solution for your Antivirus problem you must call our technical phone number 1-877-778-89-69. Our technical experts suggest you to fast and easy way to protect your device. Just Dial Our TollFree Number 1-877-778-89-69 and get full protection for your device.In case of any Antivirus problem must dial our Nortan Antivirus Support phone Number:1-877-778-89-69. Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number,Nortan Antivirus Tech Support Number,Nortan Internet Security Customer Number,Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number.
May 24, 2017 | Norton Computers & Internet
Computers & Internet Logo
46 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
