Question about Ricoh FAX5510L Plain Paper Laser
Fax machine error
I'm getting an error that reads " limit reached, replace ADF roller and reset counter " , i would like to know how i get rid of this problem.
HI,my fax machine couldn't send and receive messages.it shows me an error code that read as 0552H call service....what does it mean..? please help me.
Posted on Apr 18, 2011
You'll need to order a replacement ADF roller maintenance kit. I have the 4410L which uses type 300 of this and cost about $50 from JFT Business Systems.
Posted on Jun 28, 2007
SOURCE:
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
Error code for Imagerunner c3170 E000008-0001
The code is for the fixing roller reaching its upper limit. After replacing the fixing roller the counter needs to be reset in service mode
Aug 30, 2012 | Office Equipment & Supplies
ERROR CODE 000008-000001 WHAT IS THIS ERROR?
E008 0001 fixing roller life detection error
Description: The reading of the fixing roller life counter has reached its upper limit
Remedy: Turn off the main power, and replace the fixing roller or the fixing assembly;
then, set '0' to the following in service mode: COPIER>COUNTER>MISC>FX-UPRL.
Jan 21, 2011 | Canon imageRunner C3100N Copier
ADF rollers go up and down.
did you try to clean the rollers?
May 05, 2010 | Office Equipment & Supplies
What is Canon C3100 error code E000008 0001
The reading of the fixing roller life counter has reached its upper limit.just reach the counter reading at svc mode.
Mar 06, 2010 | Canon imageRunner C3100N Copier
Fujitsu fi5650 hispeed duplex scanner
Check the following items:
1 Does the document satisfy the paper specification?
2 Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
3 Replace the Pick roller and the Brake roller and see if the error is resolved. Check the consumable counter in the software operation panel or in the built-in Maintenance mode. When the counter exceeds the values, replace the Pick roller or the Brake roller.
4 Are the cables between the Control PCA and the Feed motor damaged? Are the connectors connected properly?
5 Is the Optical unit ADF installed correctly?
6 Is the Belt ADF installed correctly?
7 Is the Belt ADF damaged?
8 Replace Feed motor and see if the error is resolved.
9 Replace the Optical unit ADF and see if the error is resolved.
10 Replace the ADF unit and see if the error is resolved.
Pls acknowledge of the issue is resolved.
Regards,
Tech Satya
Aug 06, 2009 | Fujitsu fi-5650C
Message: Unable to Clean
machine error 46 means that your printer's purge unit has reached its counter limit and needs replacing, the reason i say this is because your machine has done alot of work and parts will be warn in your m/c, if you just reset the counter you will end up with ink througout your machine, normally when your printer is up for a purge unit its better to get a new machine with new cartridges and a 12 month warranty and no wear.
Jun 01, 2009 | Brother IntelliFAX-2440c Plain Paper...
RICOH IS200E error 1887.
Most of the scanner shows an error and sometimes it wont work because the feed roller counter reaches it life. You might have to replaced the rollers otherwise you can reset the counter by going the the web browser of the machine and look for feed roller counter reset. Then it will start again. Hope this will help.
Mar 28, 2009 | Ricoh Office Equipment & Supplies
No copy and send fax from adf unit
First try reseting the unit by holding the * key and the enter button and the same time turn it on until it starts beeping. This will rest the machine. If this does not work. you need ADF rollers the can be purchased for 20 to 25 bucks
May 08, 2008 | HP LaserJet 3380 All-In-One Printer
Ricoh FAX5510L Plain Paper Laser Logo
928 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
