Question about Cuisinart DLC-8S Pro Custom Food Processor
Grind beef for chili?
Wanting to grind a beef roast for Chili, Hamburger grind doesn't do, it it just a matter of how long to pulse with the steel blade?
  • 8,596 Answers
The food processor will pulverize the beef in seconds if you do not pulse it. Really, the food processor will tend to make the beef very fine. You can use the 3mm or 4mm slicing disc to make more of a ground beef (noodle-like) cut.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Model 70450 - old model not used for awhile - food chopper. How do I turn on? Will not work on “on”
Hi, some of these older models have a "pulse" button, wher it will only chop or blend whilst holding down the "pulse" button, try it and see
Apr 03, 2018 | Food Processors
Should my blade have started to rust as I thought they were stainless steel?
Stainless steel does rust... titanium doesn't. You should wash and promptly dry the cutter blades with a cloth after each use to prevent rust which will dull the blades must faster. (Pleasure boats use stainless steel bolts and fittings throughout, and they are always slightly corroded.)
Apr 04, 2015 | Food Processors
Hi my mom was using her new processor she got today and she put onions in when she noticed it pureed them and left chunks?
When you are trying to chop things in the magic bullet make sure that you use short pulsing movements, don't just hold it down. This will make things go mushy instead.
This is the advice they give on their website:
http://www.buythebullet.com/
You may be over processing your food by letting your Magic Bullet slip into Lock On Mode (see video demonstration of Lock On Mode) when you should be using the Pulse Technique (see video demonstration of the Pulsing Technique). Please read the Pulse Technique instructions on page 15 of the user manual or follow the steps shown in these video demonstrations and you'll be making perfect chopped onion, salsa and all your favorite textured foods in no time.
Dec 26, 2009 | As Seen On TV Magic Bullet Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Grinding nuts
Try chopping the nuts first and remove them. Prepare the rest of the dish and add the nuts, mixing them in at the last.
Mar 18, 2009 | Hamilton Beach 70450 Food Processor
Need the instruction manual to assemble this appliance Can you e mail set of instructions My e mail address is pegleg29n@yahoo.com thank you
What's to assemble, first of all its a meat grinder, you put the hopper on and insert the grind mechanism which is a shaft that has curled ridges on it, it should lock in, then you need to place the cutting blade on, that looks like four corners, and then either the fine or coase meat grinding wheel with the small or large holes in it, then the plastic part that holds it all together and tighten down, just make sure to wash and clean it right away, also dry the pieces, hot soapy water, they are usually carbon steel and can rust, hope this helps
Mar 09, 2009 | Rival 2275WP Food Processor
Food processor
I phoned the 800 number at Cuisinart (800-243-8540) and the person who answered the phone explained to me what to do: Fill the bowl with the hottest tap water I have (but not boiling) above the entire blade (including the part that fits over the shaft). He said to pulse a few times, then try to pull it off, but not to expect it to work right away. He said to do this until it comes off and that it could take 1/2 hour. I did what he said, and the blade came off after the first pulses. But also, the water was pouring out all over the counter--leaking between the bowl and the base (possibly because my old work bowl is also cracked, but I'm not sure).
I was told that the problem would happen again, and that I needed replace the blade and the shaft (which is cracked, as he guessed), both of which are available from Cuisinart.
Oct 07, 2008 | Cuisinart DLC-5 Food Processor
Cuisinart won't pulse
I started from scratch with the assembly instructions. Got it together correctly and now everything works.
Mar 03, 2008 | Cuisinart DLC-2011 PowerPrep Plus Food...
Cuisinart DLC-8S Pro Custom Food Processor Logo
243 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Greg Cann
Greg Cann
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
