Question about Zanussi Washing Machines
Zanussi washing machine stopped haflway through cycle
Machine has stopped halfway through cycle but it is trying to do something
  • pedropony2 May 11, 2010
    Has it still got water in?
    Making any noises?
  • 135 Answers
Hope your problem was solved.
Thanks for using Fixya.
Posted on Dec 16, 2008
  • Zanussi Master
  • 3,463 Answers
Sounds like the pump is not working, lay the drain hose down into a bucket or something similar, and let the water syphon out, and then see what happens.
if it is a pump problem then check filter. Hope this helps.
Please leave feedback
Posted on Dec 02, 2008
Manual zanussi essential 1400
You have a bad Drain Pump! It needs replacing. Unplug the machine first, Drain all the water out.
Jan 19, 2014 | Washing Machines
Zanussi zwf1421
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
Apr 28, 2012 | Zanussi F1245W Front Load Washer
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
I have zanussi aquacycle fls1183w and it started stopping halfway through cycle light stays on
Has still a conventional timer clock?
Then most probably a piece broke of.
In the old days on those I would open it up see which tooth broke of by revolving the timer and replace carefully with a little screw after carefully drilling into the plastic, obtaining the same heighth. Happily lived 10 years more.
Apr 16, 2009 | Washing Machines
WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
Apr 04, 2009 | Zanussi FJD1266W Front Load Washer
Zanussi jetsystem 1200 wahser dryer problem
You usually turn off your inlet valve after your washing is done. Well, if it keeps filling after u hv turned off, you have a problem with your inlet valve, which you should replace.
Oct 07, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
