Question about Fujitsu 18C1 Air Conditioner
LEAKING SPLIT TYPE AC
WOULD YOU PLS HELP ME TO FIX MY LEAKING SPLIT TYPE WALL MOUNTED AC THE INDOOR UNIT IS LEAKING WHAT WOULD BE THE PROBABLE CAUSES?
  • 1 more comment
  • Anonymous Jan 28, 2009
    HOW DO U FIX ?
  • Anonymous Feb 03, 2009
    air con is leaking water from unit inside split system fijitsu
  • devil244 Feb 08, 2009
    My Inverter leaks (Blocked drain ?) and my drain line is in wall cavity.Has been blown through and water poured into line by authorised tech and appears to show clear line but still 'backs up' and leaks heavily when in use.Tech now hard to get hold of ? Tech did say he thought that spiders/webs could cause partial blockage ??
    Only access is to lift flooring...
    Drain line is 20mm....I am thinking of dropping a lead sinker down the d/line attached to fishing line to clear once and for all.
    Not sure how to access drain line via wall mounted inverter (Model AST24PBA-W)
    Cheers
    tony
    I am
  • 82 Answers
Drain line is more and likely stopped up
Posted on Jan 23, 2009
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
When I turn the heat on my wall unit the air door closes and the cooling light flashes 7 times. Will cool but will not heat.
Pls check indoor to out door 6 wirings. May be interchanged by mistake.
Example- Black wire in N with indoor but connected in C with out door.
And also check whether the sensor wire from indoor to out door has connected.
Tnx
Nov 15, 2013 | LG LMU187HV LMN096HVT LMN096HVT 21 SEER...
What could be causing one of the wall mount units to ice up on a 3 port mini split hp?
Icing is caused by one of two things.
1. The air coming in is too much and has a lot of water vapor in it.
2. The evaporator is too cold. This could be because of a low refrigerant charge
Jun 04, 2013 | Fujitsu ASU7RLF HFI Wall Mounted Mini...
Our Mitsubishi Mr. Slim split a/c unit is wall mounted and is leaking badly from the bottom left side inside our home. We have to use a bucket underneath the unit to catch the leak. Please help us to fix...
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
Dec 06, 2010 | Heating & Cooling
Water leaking from indoor unit against the wall.
It's probably the insulation around your refrigerant pipes. If it is too thin or missing in a section they will condensate.
Jan 16, 2010 | GE Quiet-Aire Ductless Split System Air...
Best height of inside unit of a split AC
which type of mounting is suggested wall or ceiling, if it is suggested that wall mount is nominal then the height is optional, mount it as high as possible. If ceiling mount is suggested then closet to outside wall as possible
Jul 26, 2009 | Friedrich QuietMaster RS10J10 Air...
LG 18000 ac leaks water in the front of unit indoors.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Jun 05, 2009 | LG LS-K1830CL Cool Mini Split Air...
Fujitsu 18C1 Air Conditioner Logo
435 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
