Question about Logitech Computers & Internet
FUNCATION KEY DISABLE
Need step to able funcation key
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on KEY SETTINGS.
3. Then set up the keys by selecting the you want to set.
Hope that will help some. Bud
Posted on Jan 17, 2009
I want on wireless internet on L300 what is the funcation key
go to control panel network setting>advanced settings. enable the wireless card. NOT the miniport
Feb 22, 2012 | Toshiba Satellite A15-S127 Notebook
Pressed the scan button, it says optional network scanner not installed, what does it mean? this there a hardware piece I should buy? what's the part number?
The scan funcation was a option when the copier first came out. This copier is a bit old, to scan you would need to install a PCB to allow it to do it. It may be hard to find the PCB, if you do it may cost more then you really want to put into the copier. It most likely will cost less to buy a new copier with all the funcation from the factory. Good Luck
Nov 15, 2010 | Sharp AR-507 Copier
On Canon NP 7161: what's the 123 symbol flash mean? And the clear powder also flash but it new one empty. Please help
The "123" symbol is that you need to insert the key counter or you need to deposit a coin. It is a control funcation for using the copier.
Sep 09, 2010 | Office Equipment & Supplies
Irc3200 will not boot up
A E0000-001 is a fuser error code.... You may be able to reset it. Press the "Additional Funcation" botton, then the numbers "2" & "8" at the same time, then press the "Additional Funt." botton. The display will change. To reset the code press Funcation, then CLR. then ERR , then press the "OK" on the display. Then turn the Main power "OFF" then back "ON". If this code shows up alot, you may have a power problem, if the code reset. If it will not clear you have a problem with the fixing unit. Good Luck...
May 26, 2009 | Canon imageRUNNER C3200 Copier
LG160 cell phone going to mute funcation automatically
Did you try replacing the battery? If so take it to a cell phone store and get it fixed.
May 10, 2009 | Cell Phones
Medion 2120 stuck on f2 screen
put the cmos battery back in and before you turn it on press and hold down the f2 key should send you to bios where you will have to reset all funcation becase you removed the battery
Dec 11, 2008 | Computers & Internet
Dark horizontal line on canon np6050 copy
Did you try to run the wire cleaning funcation in the add. funcation mode? It could be that a wire cleaner got stuck in that spot and if you Run Wire Clean it may move it bake to Home Position and out of the way... Good Luck
Sep 19, 2008 | Canon NP 6050 Copier
Canon Error Code E000001-0002
Did you press additional funcation? You have to in order to get in to service mode. Then go to copier, then funcation, then CLR/ Clear, then ERR, the hit the OK on the display, then turn the main power switch OFF then back ON. It should reset the code, if not you have a problem with the fixing unit.
Sep 02, 2008 | Canon imageRUNNER 2200
Error code 000002 on cannon image runner
You have to get into service mode and clear the code. First, press the aditional funcation botton on the control pannel then the numbers 2 & 8 at the same time then press the aditional funcation key again. The diplay should change. Press the copier box and the at the top in the middle of the display " Funcation" the display changes again, then in the 2nd colum about half way down you will see "Clr" touch that box and then at the bottom right of the display touch the " OK" box then turn the main power switch off then back on and that should solve the problem. You may have a bad power problem with the wall outlet if it is not the right voltage, it will play havice with the copier. Good Luck
Mar 31, 2008 | Office Equipment & Supplies
Eror 355 how i can resolve.
Enter service mode(additional funcation # ) then scroll down to item 12 ( clear ) and press the set key then scroll to ERR and press the SET key twice then the display should display Clear OK and it should return to the stand by mode. And that is it. Done
Feb 09, 2008 | Canon ImageRUNNER 1670F Copier
Computers & Internet Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
