Question about Dell PowerEdge 1800 Server
Machine will not start
Server does not power on at all, changed power supply, but server doesn't power on, no fan, no boot sound, no lights nothing
  • brandon_chu Dec 05, 2008
    it's not a heat related shut down. it was shutdown to be moved to a different office. when we tried to restart it nothing, switch does not even power the board on.  jumped the atx power supply and everything comes on, fans, drives, board lights, but board does not come on at all, no beep, no screen activity no keyboard lights nothing at all.  more then likely motherboard failure. so now the question is what model motherboard is in this unit.
  • 67 Answers
Did you swap out the RAM and/or CPU. Is this a heat related shutdown?
Posted on Dec 02, 2008
IBM server x3400 not starting
This is a Planner issue (Mother Board) . Open side cover and investigate capacitor status . Probably some capacitors are bulged . Check it and replace if necessary .
Good Luck
May 16, 2012 | IBM x3400 Server
My hp ml370 g5 server is not booting when i switch it on i only hear the high sounds of the fans with out stoping till i fed up and power off it manulay . this problem used to happens from time to time...
my hp ml370 g5 server is not booting when i switch it on i only hear the high sounds of the fans with out stoping till i fed up and power off it manulay .
Jun 27, 2011 | HP ProLiant ML370 G5 Server
Compaq dl380 g1 - 1611 Power Supply 1 Fan Failure Detected
it only ur fan problem which one of the four fan or two ,might be stuck or jammed which starts after of couple of restarts, so i sugest u to check the fans when in operation
good day
Jun 01, 2010 | HP Compaq Proliant DL380 G1 Server
No power on my PowerEdge 1800 Server
dells power supplies must come from dell. I would call dell and give then the service tag number of your server and they will be able to tell you about how much a power supply is.
May 02, 2010 | Dell PowerEdge 1800 Server
Compaq proliant 5500 server wont power up
In my experience when a server/computer does absolutely nothing when the power button is pressed it is a dead processor. That may not be the case in your situation. It could be as simple as a defective power switch. Is the switch a soft touch or does it push in and click? Does the switch feel normal when pushed? One of the power supplies could also be bad. Do you have any good power supplies to test in the server? Were there any power outages recently that could have caused damage to the PSU? I would start with checking the switch. You could hook up a circuit tester and see if the switch completes the circuit when depressed. Also take a look inside the server and look for any loose connections on the mainboard. It is possible the wire for the power switch has come loose.
Sep 05, 2009 | Compaq ProLiant 3000/5500 Redundant...
Server board SE7591BR2 wont run
did you connect the internal speaker to listen to the bootup beep code?
Jul 31, 2009 | Intel Server Board SE7501BR2 Motherboard
Server board SE7591
have memory and hard drive with an op sys
Connect HP Proliant ML350 Server.
Please verify if your server power specs support 110 or 220 V. If you are in the US, eventhough you might have connected a 220V cable the line voltage can be 110.
Check with your power company if they can provide you the necessary wattage of the server.(Specs are printed on the power supply. you can read it from HP web also)
Once you are sure that, connect both power suppllies and try booting.
If the error still occurs, it can be a power supply failure or some other hardware failure.
Regs,
Jun 14, 2009 | HP Compaq ProLiant ML350 G3 Server
Booting problem
Hi Yunisa,
I need a little more info on this issue. Do you hear the power supply fan operating when you switch the server on? Did the server still startup even though the monitor is not displaying? Did this problem just occur or where there other signs of a problem coming? This may sound a little foolish to you, but check to make sure that the server is plugged into power and that the monitor is connected properly. There should at least be a message on the monitor indicating there is no signal coming to the monitor. The first thought that comes to mind if all is connected would be that the power supply has failed. Please check this out and get back to me with info.
--RoadHawk
Nov 05, 2007 | Dell PowerEdge 1800 Server
Dell PowerEdge 1800 Server Logo
378 people viewed this question
Alun Cox
